Everything posted by Aldfort
Kamiq Start Stop Issues
We were talking about a coding change, which cannot be done on newer vehicles. For sure there are gizmo's on ali express that can do what you have done, they probably also void your warrantee.
How remove front headrest - 2020 Scala
The only movement instruction I can find is this one: It might vary be territory. Front head restraints are mandatory in the UK.
I am not sure removal is permitted.
Scala steering wheel slightly off-center — anyone else noticed this?
Couple of things, either the wheel alignment has been set with the steering wheel off centre. Or the wheel alignment needs checking, or the steering wheel was fitted not quite right from new. Is there evidence of unequal wear on the tyres?
- Upgrading audio on 2022 Kamiq Monte Carlo ?
- Screen Protector
Dynamic Road Sign Display Not Working
Yep! bird poo on the windscreen in front of the camera will do it. Failure of the camera will also do it. Try a reset of the infotainment. Press and hold the on off button until you see the clock, keep holding until the system starts to reboot.
SOS Warning Sign Shows Up
Because we also run a Golf from 2021 I have a little knowledge. As has been mentioned either of the aerials can be faulty, or it can be software or the actual SOS module in the car. In some cases it can be linked to faulty steering wheel buttons. Faulty cable normally translates to "fat finger syndrome" in the factory.
- I can’t become primary user
- SOS Warning Sign Shows Up
Electric Folding Mirrors
Well from what you say the setting were changed. If not the valeters then possibly due to an OTA software update.
This is not unusual, valeters don't want the mirrors folded in.
How to read OBD Error Codes
You had a bulb fail warning only or you had a bulb fail warning and the bulb was failed / not working as it should? To answer the question, there are two levels of fault code, one is universal, it means the same irrespective of make and model of car. The second level is manufacturer specific, these codes may or may not be recorded in the car memory. Generally codes that effect engine / drivetrain life and or emission control and or safety are recorded. Something light a failed light is more of a grey area as it easy to see the bulb has gone or not.
You need to be aware, to avoid scaring yourself, that the car will collect lots of error codes all the time. The ECU then makes a judgement, based on programming, about how serious the code is. To use the jargon, if the code becomes persistent then a warning light will appear on your dashboard. If the code is a transient, then despite the fact it is recorded it will not trigger a warning light. However, several of the same transient within a time period will cause a warning light. I can't be more specific as the manufacturer decides the time period and number of codes within that period. To make it worse it will be different for every type of fault code. Eventually transients are erased by the ECU.
Main beam LED replacement
Argo H4 Headlight Bulbs 55w Xenon White 6000k 12v Car Headlight Bulb High Low Dipped Main Beam Headlamp Super Bright Halogen Upgrade Car Light Bulbs 472 P43t 472c Headlight Bulbs : Amazon.co.uk: Automotive Probably the cheapest way to go. If you have the bulb failure warning system then fitting LED's might trigger it off as the resistance is different.
You are probably just better off going for a whiter halogen bulb. The colour temperature should not vary that much between main and dipped beam so best check for any signs of corrosion on the connectors. Plenty of companies offer whiter / brighter halogen bulbs.
- Tailgate struts replacement?
PCP settlement figure seems unfair and possibly illegal?
Pretty sure the days of getting the money off and then cancelling the PCP are long gone. Others may take a different view.
Water entering the car interior through rear doors
Quite a lot will get in through the window seal. It should all drain out via the weep holes. If is is not then clear the weep holes out until water will run out freely. If there is water in the bottom of the door it is a big problem.
Don't take any nonsense. Explain how you park your car. Explain that Skoda Garage has told you why the speaker is a problem. Ask for a better speaker with a water shield and for the speaker to be sealed into the door with a non hardening mastic. Also ask all screw holes to be sealed. I once had a similar problem and cured it by sealing a sheet of plastic inside the inner skin with mastic so the speaker was protected.
Battery just replaced, unusual voltage reading
nta16 I have you on ignore. First time in ages I've felt the need to block any member on a forum.
Bluetooth won't turn on / Skoda Connect deactivated?
Yes, to use the car infotainment (well most of it) now you must "register" as the user. This means you need the Skoda App. If the car has a previous "registration" I think the dealer has to cancel it. Skoda seem to have their system set up as discoverable (this is minimum privacy the way Volkswagen describe it.) But either way the tiny globe must not be greyed out and if you have the "man in a hat" symbol this must not show maximum privacy. My dealer advised me to set the app up 24 hours before I collected the car. This way registration proceeds quickly. If you try to register and then link to the car at the same time it can take a while.
You have generated good evidence. I think it is clear that the parking on a side slope is allowing the water that gets in at the base of the window to drip onto the inner door skin. This inner skin is full of holes and areas where water could get out into the car. The only other thing you could try is putting the water onto the window on the low side of the car and checking it runs out via the weep holes. If it does then you have enough info for the dealer to fix it.
Sorry @logiclee we are at cross purposes. Yes if you obtain an early settlement figure you can keep the additional services. If you think you get to keep them for free you are living in another world. The residual cost is calculated and taken account of in the settlement figure. If you cancel a PCP contract, as the OP seems to want to do, you'll lose these additional services. Try reading the info I linked for the OP
