Cairus
Everything posted by Cairus
  1. As a little extra, even the VW R models, Audi RS3, and Mercedes A-Class AMG, Cupra etc...have a multi-plate friction clutch; only the high-performance models have two of them, and the preload is achieved differently. However, the complete system isn't a VW or Audi development. It also comes from our company. Currently, we're offering the electrification of this model. 😜
  2. Gen 6 Controller ist no include in the Pump
  3. Just a quick point: the transfer case for the rear axle of the 4x4 is a Haldex Gen 6, manufactured by BorgWarner. As a former supplier of the complete transfer case, I can tell you that VW themselves extend the maintenance interval. BorgWarner has completely different recommendations 😜
  4. More Compact and with disable Start Stop 😏
  5. Good morning. The pACC system, or rather the automatic speed control, should be able to be deactivated in the driver assistance systems menu. This topic is in the Kodiaq 2 section, where SFD 2 is a bigger issue. The camera can probably be coded to deactivate traffic sign recognition, but you likely can't or won't want to modify control unit 5F or 13. SFD 2 tokens currently cost around €400 if purchased separately. So, test whether simply deactivating the camera function is sufficient and doesn't trigger any visual error messages for the driver. Which Car exact?
  6. There can always be variations in quality. Otherwise, try swapping the LED bulbs around and see if the fault moves. In a worst-case scenario, you can usually code the error message so that it no longer appears.
  7. You have Change Xenon To LED?
  8. This will change your service interval to a fixed interval.
  9. Finish new Generation steering wheel Made the converter own
  10. Pro Account?
  11. So, I solved the problem with a homemade converter. Cost: €15. Required: KL15/KL31 and CAN Comfort.
  12. Superb 3 dont have SFD
  13. You need Patch or Skoda because CP and Funktion restore etc etc
  14. Yes, i think Software brick
  15. Which HW and SW Version HT have your Unit on the Sticker in the unit Chassis?
  16. https://mega.nz/file/lrc1BaCD#nq_LSllnN-vDCL_fK6YVGXCMPosigM-ZrRJ0RBJsNqA
  17. 1) Hardware Retrofit 2) Software Coding 3) Software Lisenc for driving Mode (Gateway) By ESP Button, you have to Check, If it Possible with your HW
  18. Both need wire. Drive Mode also have SwaP Protection
  19. Yes to Support it... You need the document that describes the channels. This list might help: https://www.t4-wiki.de/wiki/Messwertblock
