Cairus
Everything posted by Cairus
  1. I think you have a known problem with a certain hardware and software version that sporadically loses its basic settings on its own. Only a control unit update will help here.
  2. Google Gemini: An SVM check at Skoda refers to the Software Version Management (SVM) coding, which is necessary to integrate new control units into a vehicle or to make changes to the software, often in connection with recalls or retrofits. The process requires access to the official manufacturer's diagnostic tool (ODIS), the matching of activation codes (SVM codes), and the execution of automatic adaptations to the control units to ensure the software functions correctly. How the SVM check works: Preparation: First, the retrofit kit or the new control unit is installed in the vehicle. Connection to the diagnostic tool: The manufacturer's diagnostic tool (ODIS) is connected to the vehicle. Starting the software adaptation: The "Perform retrofit/upgrade with license protection" function or a similar option is started via the "Special functions" menu. Entering the activation codes: The check prompts for the necessary activation codes (e.g., code 1, code 2, code 3), which are often supplied with the new control unit. Automatic Execution: After entering the codes, the activation is performed automatically and all necessary control units are adapted. Completion and Verification: Finally, the fault memory is cleared and the correct function of the retrofit is verified. SVM Code The SVM code (also called license coding) is a unique code that ensures only authentic and new control units are used. It is usually found in the packaging of the new control unit. Without this code, the software adaptation cannot be performed.
  3. Which Radio System you have? HW Version? SW Version? SW Number of Version?
  4. Thats the Problem Made SVM by Skoda Service Station
  5. Which Part of light have the Error?
  6. You have a 5Q0 camera, right? The FLA (Front Light Assist) is activated differently on this camera than on the 3Q0 camera. I've never had any problems with it.
  7. You need DSP also for this System
  8. Replacing the plexiglass with the speedometer removed takes less than 5 minutes and is usually self-explanatory.
  9. Where did you get the information that there is supposed to be a firmware version 05xx?
  10. The cable has now been installed on the passenger side. Removing the glove box and all the trim panels is the quickest and easiest way...
  11. I need 332 please Maybe this Help : https://mega.nz/file/RyV2WTaJ#iGLjdK0CBUpAeK_AU4OvZlDzFfnQGUxhTfowQzG3bp4 https://mega.nz/file/MyFGyA5C#_9nLrTnVdK_YWWPsbXcfmcIyrqU3wdcCLMts6aYh57o https://mega.nz/file/RvlwlZaB#VAEL04R0dUY1HSzoYyzIe2lpuuPPake0-RuqMD-wKYo https://mega.nz/file/pzlAGBpD#bZEOg82t7NKvPc91etLUHAzi42wPMtfr-rRtCPZj7rM
  12. I use: Standard: 2,5bar Komfort: 2,7bar Full: 3,0 bar
  13. Password PM https://mega.nz/#P!AgEmq2aVtlKs5wj12sq3YAnkTMCdGOvQQS22B0llLhs1apozcMgXg8FRoCgwaEn_PvIV9-zW9eHooiy3GEsviZ-g_08STkAKZn2CMMvLEc057yf5eQTLfMLGnKMQh7Gp75lCeU6M6MU
  14. No, i will check The Number later
  15. With This Change, you Stopped PWM
