Everything posted by Cairus
What have you done to your Kodiaq today?
Rear heated seats and Varioflex: where the harness pass?
I think the heating is Not in the Central Connector
New Skoda steering wheel design without LIN adapter
So, a minor setback... The menu selection in the on-board computer isn't working in the car. Who or what is to blame, those damn Skoda developers or someone else...? Skoda decided to have the menu scroll from top to bottom. That's precisely the problem. The signal from the new steering wheel is left or right. That's why my setup with the Seat instrument cluster worked; menu selection works left or right... I'll keep you posted.
Octavia MK3 Smartlink Activation
Buy mib2 Navi Low, Patch it Coding and have fun
- Kodiaq (2019) - cannot start engine
@pab567 – Need help with MST2_EU_SK_ZR_P0891T firmware (Octavia 2017 5Q0035864C)
No, FeC is Status: Invalid Flash Firmware with Patch, or Take ToolBox
It's no secret that when (p)ACC is active, the rear axle brakes more frequently for comfort reasons.
Halogen to Bi-LED
poor LED bulbs that cannot handle PWM
I Look for OEM solution I also See a different in the BCM. Pre Facelift 5Q0 and Facelift 5Q1 But on the table was 5Q0 with SW 0312 Yesterday i start the Mod in the Car
Retrofit reverse camera
Normal you Take KL30&KL31 and Yellow RCA is the Reverse light
How To - Reverse Camera Fitting Guide
IT IS no OEM
Intermittent SOS error - OCU software update needed?
No, you can update the OCU yourself. However, very few people know how to do it correctly. It has a boot component and an app component.
So, the monster lives! 😜 Successfully using the MFL (multifunction steering wheel) at the table today. Here's the configuration: The new MFL buttons (sub 19) Gateway (19) Multimedia System (5F) Steering column control unit (16) "Analog" speedometer (17) Coding, adaptation, and data set creation were all done, of course. The starting point was a Conti 3Q0907530C as hardware and AA as software.
Coding of Steering Wheel controls
Proactive Occupant Protection fault
What you do is entirely your decision...what the dealer does, he does at his own risk. To receive money from Skoda for working on your car, the dealer must adhere to Skoda's rules.
Reverse camera help
Yes y every mib2 works with OEM Camera
- Skoda Kodiaq MK1 Passenger side warmer than the drivers
A TPI (Technical Product Information) is simply technical product information. It doesn't obligate the retailer to do anything.
- Swapping out infotainment plug and play
I don't want to discourage you, but Skoda won't accept your acquaintance's diagnostic report. What tool did he use to read the error code? The keyword here is "phantom error." Furthermore, Skoda recently published a 17-page TPI (Technical Product Information) document where seemingly every control unit receives an update.
New software available version 1989
That is correct. Update make Problems by some Users
HELLA module mounting instructions
Keyless Antenna
Off Road Button
Offroad is a Option with SwaP/FoD
With one SD Slot, you have To make the URART.
