Everything posted by Cairus
Centre consol button panel - change of button order
Normally it is an 8 or 10 pin connector, so only 1 connector for all buttons
you would have to take the unit which is more fully occupied, then change the cover and re-pin
Traffic Sign Recognition activation
The lane keeping assistant is with an adapted data set I find quite pleasant to drive
Update To Infotainment Version 1985 - Download Link and Guide
You have To Update Manuel Firmware 16xx>17xx>18xx> 19xx....
STG A5 > Coding > Byte 16 > Activate Bit 4 STG 17 > Coding > Byte 05 > Activate Bit 2 STG 5F > Adaptation > … > Channel "Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21" > Set value to "activated" > Channel "Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus" > Set value to "Data Bus Extended" > Channel "Car_Function_Adaptations_Gen2-menu_display_road_sign_identification" > Set value to "activated" > Channel "Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high" > Set value to "activated"
Yes only Coding
Firmware update
Offiziell you can Not Update from Firmware 02XX To Firmware 03XX
5Q0035840C Fault code 7237 U111100 "Function restriction due to missing message" - how to resolve it?
You have a Picture from the Error Message from the Tool?
Replacing the rear brake MQB Classic to MQB EVO
Today the rear brake from a MQB EVO model was installed in a MQB Classic vehicle... both vehicles have PR code 1KE.... everything fits, however the complete 1KE MQB EVO brake is required... that means caliper and motor for the EPB, as well as pads and discs... what I immediately noticed when driving, the EPB drive is much smoother, quieter and simply much more comfortable... for me it is definitely an upgrade
Power Tailgate Fault
Sorry, I have to disappoint you.
Facelift Crystal Style taillights in the VFL
Unfortunately, I had to process the information that the facelift was more modified than expected at the rear..... that means the new upper part of the bumper is needed as well as various other things unfortunately... the following parts are only needed for the conversion so that the facelift taillights are properly installed: 565807421B — Upper Bumper Section 565945105B — Left Reflector 565945106B — Right Reflector 565807393C — Left Bumper Guide (Small) 565807394C — Right Bumper Guide (Small) 565807393D — Left Bumper Guide 565807394D — Right Bumper Guide 565907455D — Left Blind Spot Radar Bracket 565907456D — Right Blind Spot Radar Bracket 565807863A — Bar with Clamps (Center Bumper Bracket) 565945207B — Left Taillight 565945208B — Right Taillight 565945307E — Left Taillight inside 565945308F — Right taillight inside 565945311 — Left taillight cover 565945312 — Right taillight cover The complete retrofit will cost us around €1,000. Everything was rebuilt and coded by ourselves, of course.
It's nice if you say no basic is needed. That helps vehicles where the wires have been repaired, but not if the tailgate no longer opens and closes automatically and the control unit reports the error message "no basic setting." But apparently you know better. With that in mind, I wish you a nice evening.
what don't you understand about it?
At my last customer, yellow and blue were broken, it was no longer possible without basic adjustment
Dont forget the Basic Setting
So, that's the next project. The starting point is the following: Skoda Kodiaq model year 2019 PR code for SBBR light: 8SK BCM: HW 5Q0937086BR HW Version 036 SW 5Q0937086BR SW Version 0265 Destination: Skoda Kodiaq model year 2021 facelift Item number SBBR light 565945207B 565945208B 565945308F 565945307E This requires re-routing the cables into the tailgate. I still need to clarify the BCM software version to see if it needs to be updated. As for the animation, the BCM definitely needs to be replaced, but it's not needed.
- Upgrading/swapping radio to support bluetooth?
- Facelift Crystal Style taillights in the VFL
Complete loss of power
Such updates, where there is a bug in the firmware, are free of charge by us
Škoda Kodiaq 2019 MIB 2 Software update
PW write me PM https://mega.nz/#P!AgGWtzUFoIPj5lShzsBR5Xi7-OSUeQCK2_pY8P37bWVL8l2tiN2ZVufNU34rUqUMTqcbqZBDC-FSppw-3Eb_BtW9YMLV1guO4HZnj9oS1kV-qpB-rMwgA67QNvz3BgFM6qCijAZQN8A
Need urgent advice – Fog light damage & headlight washer nozzle issue before holiday
I think we have a problem with the translation...
read the topic Skoda quality parts on the topic: removing the bumper and assessing the damage
Yes, but Austria
as a quality spare part from Skoda directly, speaking for left-hand drive, 370€ each
