Everything posted by Evolution13
First bong this Autumn.
First Bong might well be tomorrow if out early enough. Below 4"oC forecast, showing as possible 2*oC or lower.
Tire size conundrum
The Authorised Service Centre or the Tech / Fitter doing a PDI changes nothing in the settings. Maybe Takes it out of 'In transit setting'. Might change Variable Servicing to Fixed Servicing, and might reset the TPMS when they change the pressure from that they come off a transporter at.
Tire size conundrum
@Mariosti I thought you started out bothering about splashing some cash on tyres that cost a bit more for winter use,. now there is this stuff about different wheels, weight saving. You seem to have all the answers and knowledge so seems funny you asked in the first place.
the truth about electric cars
ULEZ and other similar schemes we are being told are all about clean air for everybody but are they really just a means of making money from motorists?
Check the oil level (2019, TDI)
@OrvilleTheDuck Had it increased? Did you not remove oil? "reduce oil level'" Too much oi. "Reduced oil level" not enough!!! Does your car have a Dip Stick? Did you dip the oil when you first got the warning. As the Manual tells you to. @ Normal Operating Temperature, parked on the flat after a few minutes? Then compare that to Once the engine and oil had cooled to ambient temperature?
Tire size conundrum
@Lee Public Road and not Racing or Timing. @Mariosti The cars speedometer from the Factory over reads and a slight circumference increase usually has the speed more accurate. Very few would change settings in the ECU for New Tyres with more tread and run at higher pressures or for more worn and lower pressures. various circumferences. PS, Winter Tyres / All Season for road, none track use just getting about, does the UNSPUNG weight really matter. ?? PS. I have had in the past few years Alpin 5 & Alpin 6 and various CrossClimates, First Edition, + and SUV and have CrossClimate 3 on my EV right now. I should have gone with Pirelli Cinturato AS SF3 Self Sealers as i have no spare wheel. Had 2 punctures and replace 1 CrossClimate 3 already in the first 3 months.
- Startup stumble/chugging when engine is already warm (Octavia VRS TFSI MK2)
@Graham Butcher 'Experts' that are local residents reckon that Private Flights during the Grouse Shooting season or during Golf Events in the Region are a cause of increased pollution. Their answer seams to be closure of the airport. Ignoring the fact the private flights will land someplace else maybe less that 30 miles away increasing pollution there. http://thecourier.co.uk/fp/business-environment/transport/5574581/experts-dundee-air-pollution-airport
Odd loss of power / 1.0TSI (DLAA) 81kW / 90 000km
@Johngerard You could use an Octane Booster with 95 Ron E10 bought in the RoI. In the UK the E5 is sold as 97 Ron Minimum or 88 Ron minimum. There has not been 98 Ron Minimum sold in the UK for over a decade.(VW FAQ site has never recognised that as being the case.) Not all E5 in the UK contains Ethanol. It is Regions / Depots & Distribution dependent.
Tire size conundrum
All Season 3PMSF (Three Peak Mountain Snowflake) tyres might be all that is needed if you do not require FULL SNOW Tyres. Plenty All-Seasons suitable for use in Snow or pisted or non pisted roads and even if Snow Chains are needed. @Mariosti The ABS / TPMS / TC will not give a monkeys if there are different widths or circumference of tyres fitted. Reset the TPMS. But you are intending changing the Diameter / Circumference. Maybe just fit narrower treads / sidewall to sidewall if cost is an issue. Set your Winter Tyre speed warning on the car if Winter / Snow Tyres are fitted.
Skoda enyaq 2022 full electric won’t start after crash
Welcome to the forum. Do they have a trained EV technician? Was that just the Pyro Fuse that was changed then? The Electrician needs to be Speaking to another Electrician that is trained on working with EV,s I suspect.
I was thinking of Smokey and the Bandit. Never a truer thing in a song. The UK needs to get a move on with things.
Brake pads wear indicator does fabia colour edition have brake pads wear indicator light on dash ?
As it is just an location location location thing and usage. Maybe more necessary seaside or where winter salting is more common. And if you own cars as keepers and not rent / lease them and hand back or trade in every 3 years. Then lack of use or low miles might mean more surface rust on discs when they are moved. A manual hand / parking brake can mean user to get some rust off discs than cars with e-brakes. PS, untill 2019 Skoda UK servicing still showed 'remove wheels' remove Drums'. Some inspection of drum brake cars were done without wheels off. Right they used inspection hols on rear drum plate. Not. So mBy cars never had the alloys off in 3 or more years that it was an effort to get them off. Many a sad tale at puncture times.
UK Public Charger Network & price increases as they are announced. Please post here as you become aware of any changes in the costs.
Dealer Diagnostics
@HowardBury Does that Invoice show all work done, time and parts used even if you are not paying. That is for your Records as the Owner / Driver. It is not supposed to be the SKODA SECRET SERVICE. Lose lips cost lives. Yet Dealerships seem to think it is all on a Need to know basis and customers need not know.
Skoda Service Plan - paying for spark plugs
@JB88 If they were going by some Service Regime like that shown by Skoda UK the Air Filter was due to be replaced at 6 Years / 60,000 miles. Was it ? Actually it should be inspected at every service if a service is worth a damn.
With Skoda / VW it is common that NEW DISCS are required sooner than pads or at the same time. Long gone are the days of several sets of pads before the discs need replaced. But then Skoda main dealer servicing might have Brake Fluid changed but not SERVICING of the Brakes, strip and grease pins etc.
Dealer Diagnostics
Clearing the fault after dealing with the issue or fault and then road testing it and checking for fault codes is just 'Simply Clever' or a necessity'. Did they road test your vehicle before handing back the keys having given you the invoice. Plus the report on the checks they did while they had the car with them?
@lol-lol lets stick with the UK and what is what now and coming soon. Even ZAPMAP is crap but somehow they think they are the dogs dangles.
Rust around fuel filler door
It is cobblers. Not specified anyplace & whoever came up with the tripe needs to show where they come up with this. Skoda have covered nothing, they are at it. Have you seen the Final Decisions of the Ombudsman in writing concerning other claims. There are those that have successfully made claims under the warranty on exactly the same corrosion issue in exactly the same location on the car.
Knocking noise/rattle from DCC - Sportline 2.0 Petrol
Skoda or whoever is telling this nonsense should know that there are vehicles out there that they failed to engineer into the 'Normal operational noise'. Where is this person based and are they an Automotive Engineer or a desk jokey?
Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
Haldex is at 3 years / 30,000 miles. So i would be wanting it done know as well as the Brake Fluid change if not done in the past 2 years. As far as the DSG i would want that now and the Warranty covering it. Not left till 80,000 miles.
- Check the oil level (2019, TDI)
