Everything posted by Gizmo
Steering wheel retrofit - three-spoke
The Superb and Octavia use different buttons so these won’t work on your car. If your blanks are the same shape then yes they’ll fit, as I’ve swapped Octavia / Superb / Yeti buttons / wheels around on what is essentially the same wheel.
Bluetooth + smartlink update
@venom171@Miro85 please post in the forums language (English) as stipulated in the rules. (even if that through an online translator).
How to run cable from engine bay to cabin?
What are you trying to power? Can it not go to the fusebox?
Wheel bolts versus studs
Purely for cost I would imagine one of these will make life much easier https://www.ebay.co.uk/itm/223490102530?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=rEXkH2ETQbO&sssrc=4429486&ssuid=G0CEmgoeS--&var=&widget_ver=artemis&media=COPY
vcds hastings
Happy to do that if you want a short drive?
SOLD - Ford Fiesta Zetec 90, 1.6 TDCI 5 door, 28,000 miles
I’ve just done about 750 miles in it whilst waiting for my ID.7 to be built and despite it not being my kind of car I must admit I was very impressed with it.
For sale is my late MIL's Ford Fiesta Zetec 90, 1.6 TDCI 5 door. Registered new in 2009 Just had a fresh 12 months MOT with no advisories. Lovely Fiesta with VERY low miles at just 28,000 miles! Serviced yearly by Ford, (last service was 1,000 miles ago) The car has never wanted for anything, everything works as it should and it drives like new. Manual, A/C is ice cold, Central locking, Parking sensors, Heated windscreen, Electric windows, Alloys, Spare wheel, It has always been garaged from new. Very economical motoring with up to 70 mpg and just £20 road tax. Car is in New Romney, Kent, TN28 Sold
Lane assist camera
It's not that simple, you need the proper boards to calibrate the camera. (I assume you already changed the windscreen as well?)
Doing own service!
Threads merged (which is why the comments look a bit disjointed)
Potřebuji aktualizaci svého rádia Swing na Octavii 2017...
@Detman please use the forums default language English... even if it's through a web translator.
'72 plate Superb Mk111 no jack as there's no spare wheel?
You will need a 17mm socket for the bolts. The Superb also has a 5x112 PCD bolt pattern which is different to your V70.
Not much use for a jack when you have no spare wheel. You only get the jack etc if you order the spare wheel from the factory. You need 8D0 012 44A to remove the bolt caps https://www.akstuning.co.uk/shop/home/2095-all-categories-selected-template.html
Superb 2.0 TDI L&K alloy wheels/rims
Stop paying for this info, most of it is freely available on the internet. A good site to decode the option sticker in the book / handbook is: https://igorweb.org/equidec.aspx
STD they came on 18” but 19” was also an option. Used 17” and 19” winter wheels / tyres on my 2015 L&K. As the car has DCC there was very little difference in comfort, however the car looked crap (IMO) on 17’s.
12v socket in boot
It wasn’t possible on a December 2015 car.
EV Optimum Battery Charging and Real World Range
Charging to 100% and using the car below 20% isn't an issue, the issues come if you leave the car parked below 20% or above 80% for several hours. Range will vary dramatically depending on how you drive, drive 'normally' at the NSL (like an ICE) then 3 miles per kWh should be your bench mark to work out your figures especially when it's cold.
VCDS Security acces code for 09 control electronics in Superb mk2
Actually now I think about it you are right, it’s been a while since I’ve done a MK2
Did you swap your cable as per your other post? If so then try 31347.
VCDS what do I need? - READ BEFORE BUYING
No most of the V2 interfaces will be locked. you can scan a car without using up a VIN but not code anything. Im not sure if it uses a VIN if you clear all DTC’s
Swing radio code
Moved to a more relevant section.
Trouble with vcds in superb 2
You need HEX+CAN or the latest HEX-V2 (or HEX-NET) for a MKII Superb.
Couple de serrage
Welcome The only language to be used on Briskoda is English, using a translator service (google etc) is absolutely fine.
SOLD - Superb Propus Aero 18" alloys in pristine condition with Continental Ecocontact 6 tyres
I could be interested in just the wheels if someone wanted the tyres?
*SOLD* Octavia vRS 18" Gemini Wheels x4
Ideally I need 8”, but I’ll keep an eye on these. 👍🏻
Airbag Error
Yes send someone who has VCDS a message there is a link in my signature.
