Everything posted by Gizmo
Be very wary of V6.0.1 OTA update
On the VW app it’s just under the battery care mode, I would be surprised if Škoda doesn’t have it as it’s basically the same software / car.
No that’s different. The ‘Optimised battery use’ is supposed to keep the 12v topped up from the traction battery so in theory the 12v should never flatten itself. But as it’s VAG software it doesn’t always work.
Do you have the “Optimised battery use” enabled in the app? As this should prevent the 12v going flat. ‘By using the high-voltage battery, more energy is available in the vehicle for operating via the app (affects range).”
- Airbag light after glovebox removal. VCDS in Ayrshire/Glasgow/Stirling to clear it?
Unleashing the Power of OBDeleven: A Must-Have for SKODA Owners
Probably yes as it’s mainly MY24 onwards cars affected. I own OBDII, VCDS (HEX-NET) and also had VCP. For me VCDS was / is always my ‘go to’ device.
Coding failure
Why not just return it to the said workshop and get them to revert the coding? ATEOTD it's their error. Surely they saved a backup copy before changing the coding? Not sure if Autel saves a copy of any changes made? Simply copying and pasting someone else's coding is nearly as daft as not saving a copy of the original coding on the car before changing it, no two cars are identical so you are opening up a can of worms.
- S3 owners - electric tailgate / hatch closing from inside
- Remove Enyaq Tailgate Interior trim
Rattle in drivers door
May I suggest you have a read of the rules that you agreed to when you joined. https://www.briskoda.net/forums/guidelines/ Of course a reply to a 11yr old thread would bump it back to the top. The action taken was actually quite tame, 18 pointless posts simply to boost your post count would usually have won you an instant ban (as a spammer)
Rear brake pads
You need a device such as VCDS to put the brakes into ‘service position’ before you change them.
Will OBDII work with my car? SFD2?
Highly unlikely a 2024 car will allow you to code anything as it'll be SFD2. On a 2020 car you will be able to code once you turn off SFD (note this isn't SFD2) SFD was introduced in 2020, so not all if any of the car will be locked down. Unfortunately coding anything SFD2 protected doesn't look promising in the near future... if ever.
What age is your car? AIUI anything 2024 onwards is SFD2
Do I need VCDS to read a code?
Cheapest way would be to contact a local member who has HEX-V2 or HEX-NET VCDS.
VCDS or ODBEleven or ???
OBDEleven can’t unlock SFD2 (used on new VAG cars in the last 12+ months). I own both and ALWAYS use VCDS, support is brilliant (compared to almost non existent support with OBDEleven … and their one click apps aren’t healthy to use.) If you REALLY need to use on a mobile then the HEX-NET will do that, but at a cost.
Can you code with it? No. Once this can be done by unlocking SFD2 then yes it’s progress, until then it’s a step backwards for anyone with a newish car.
You may want to do some research…. Volkswagen Group (VAG) vehicles New Volkswagen Group (VAG) models from 2024 have updated security features (UNECE R155 and R156) to protect the car’s software. This new layer of protection, sometimes called “SFD2,” safeguards the car’s control units from unauthorized access, particularly for updates performed over the air (OTA). Under these new security measures, OBDeleven can only fully communicate with the car's main diagnostic part – the gateway control unit. This means we can’t fully scan or interact with other control units as we do with other car models. https://support.obdeleven.com/en/articles/9187989-does-obdeleven-work-with-vag-and-bmw-vehicles-manufactured-from-2024
It's certainly not 'the future' as it can't do anything with SFD2
Driver's door central locking issue
Check the wiring loom between the door and A post, common issue
Converting the Superb 3 Pre FL to the Superb 3 FL Matrix Light any experience?
No all you have done is taken one step closer to be banned…
Airbag Error
Yes, airbag DTC’s always require clearing with an OBD tool. To prevent this, never disconnect an airbag plug without disconnecting the battery first.
Clone VCDS
Briskoda doesn’t condone clones Therefore this will be locked.
Retrofiting reverse parking cam to Mk3
@nickytheshaft please don’t link to pirated interfaces or software on Briskoda.
Led stripes with DRL/side lights
Are you 100% sure you have the lights? They all have the stripes, not all are lit.
Charging ever bigger batteries
Unless you are on a decent FiT then at the moment it makes financial sense to send everything you produce back to the grid, then charge your batteries overnight at less than half the cost your energy company has paid you for exporting. Since our panels and batteries were installed in February’24 we haven’t used ANY peak rate electricity, we’ve also been paid £1,600 for what we’ve exported 👍🏻
