PetrolDave
Joined
Last visited
Currently
Viewing Forum: Reviews
Multiple Faults - ABS ?
All those systems need speed information, so I agree with Paws4Thot.
Unable to log in to Skoda Connect via infotainment system
The language of this forum is English, please post only in English.
the truth about electric cars
That's really the point I was making, clean energy generation is essential but it must be done sympathetically. There are plenty of great locations for wind, solar, hydro, tidal, etc. that do not cause unacceptable quality of life issues (or loss of productive farmland) for more than a handful of people, who must then be appropriately compensated.
An interesting question, but how it belongs in this thread about electric cars I fail to see - so I'm not going to clutter up this thread with my reply.
I love the way you go completely off-grid with some of your posts π
A few years ago I stayed a few miles from a wind farm near Dieppe, it was really difficult to get a good nights sleep whenever it was windy due to ground carried vibration from the wind turbines (yes I did look outside to check on which nights the turbines were operating).
But those of us who do drive, either because of necessity (work, non-existent public transport, etc.) or because we like driving, will have no choice from 2030 onwards when we buy new to buy an EV (I'm ignoring Hydrogen vehicles as the refuelling infrastructure and model choice is so limited). So Government policy IS forcing anyone who drives to switch to an EV in the coming years.
Timing belt
Supposedly "for life" but IIRC inspections are recommended after 120,000 miles. Skoda UK used to ridiculously advise every 5 years which no other part of the worldwide VAG empire did, recently they've "seen the light" and removed this crazy advice.
Hot Passenger - Cold Driver- but not H Matrix!
Very unlikely, the passenger and driver side heating comes from one common heater matrix. Far more likely is a problem with the temperature flaps in the HVAC system, you really need to get a scan done with a diagnostic tool such as OBDeleven or VCDS to get the details.
Weird idle issue - 1.5 TSI
Lots of discussion on here about the micro-regenerative charging system on these cars - even one recently who said his alternator was faulty because the voltage varied between just over 12V and over 14V when driving, which is perfectly correct and normal for this system. I have a USB device from Amazon that I plug into the 12V socket in the centre console that shows the voltage, as an engineer it's quite enlightening to see how the voltage changes depending on time since starting, whether on trailing throttle, etc. https://www.amazon.co.uk/gp/product/B0878Z3BMX
Whats the most up-to-date software?
But did the dealer say whether it was a software update to the SOS module or the infotainment - they're completely different software controlled modules. Your Octavia probably has at least 20 (often many more) software controlled modules, so you cannot assume that quoting the infotainment software version is relevant to faults in other modules.
Was the battery management coding updated when the new battery was fitted? If not it will still be assuming the old battery is fitted.
Tyre size question
Always happy to learn new tricks π
Tyre size question
+1 Never seen an option in the instruments to recalibrate for different rolling circumference...
Infotainment Not Responding
π
I'd be nervous if all they're offering replace is the screen, as the real infotainment 'brain' isn't in the screen. I'd make a fully working infotainment a condition of the purchase, possibly with an additional parts and labour commitment from them?
At what distance do your front parking sensors work?
That's a really nice feature, on my Mk3 I have to look down at the infotainment screen to see where the object it's complaining about is.
Drivers fwd seat belt replacement
Those errors come up because of disconnecting the battery and usually disappear after a short drive.
The car does not respond the key
What new battery did you fit in the fob? The fobs are incredibly sensitive to the battery voltage and internal resistance.
Octavia Scout 2016 - Flip the direction of gearchanges
The gear shifter is actually a complex switch mechanism with switches for both active and inactive positions (as a cross check of each other). In theory you might be able to rewire the manual mode switches to operate the opposite way, you would need to get a wiring diagram and do some thinking and planning. BTW I agree the manual modes work the wrong way, to me push forward should be downchange and pull back should be upchange - so that the inertia of braking and accelerating assist the change instead of resisting it (this is how my previous Toyots Aygo worked).
Adding Maps and Reversing Camera
It actually says /Nav - which means no Nav (the / means without).
Multiple issues - common cause?
Skoda (in fact all VAG) temperature gauges show 90 degs for a wide range of temperatures (too many owners were reporting problems which were just normal variation in temperature when going downhill or driving hard), so don't believe the temperature gauge as an accurate measure of actual coolant temperature.
Mpg adjustment
With short journeys and the colder weather it makes any mpg comparison pretty meaningless as the engine will spend a much longer time in warm up phase when consumption is higher.
Whatβs this button?
πππ
He's referring to the often mentioned silica bag in the coolant header tank. See if your coolant header tank has the words "mit silicat" on it?
