PetrolDave
  1. I've seen similar problems with CR2025 batteries, my theory is battery internal resistance differences (causing voltage drop under load) as they measured the same voltage down to the 1mV level on my 3 1/2 digit DMM on no load. I always uses CR2032 batteries now (a bit of a tight fit) and have had no repeat problems.
  2. It's intermittent and only happened once - clear the fault and see if it ever comes back or whether it was just the module having a hissy fit.
  3. Sender mechanically working, gauge working - what's left? Wiring and sender electrical side. Check the sender resistance changes when you move the float, if that's OK then it's time to check the wiring between the gauge and the instruments.
  4. GPS is sufficient - but VAG have a long history of getting clock setting wrong, e.g. on the B7 Audi A4 even if you have sat nav fitted it ignored the GPS time when setting the time on the instruments and even offered the option to set the time on the sat nav from the (wrong time) on the instruments!
  5. ... except on the van, my brothers 1970 Mini van still had the sliding windows (yes the upgrade from a van to a Clubman Estate 2 years later was very welcome!).
  6. Electrical loose joint, any number of other problems meaning the engine can't idle correctly...
  7. Strange - works great for me ⁉️
  8. My brothers 1972 Mini Clubman estate had the board fitted in production, as did my 1983 Mini 1000 saloon.
  9. On your previous Mk3 Octavia there was a simple VCDS/OBDeleven coding change to enable auto DST change - I've done it on both my Mk3 Octavias.
  10. Read the thread about updating to 1941 firmware...
  11. Toyota Aygo mark 2? Simple to drive and maintain and reliable.
  12. Older cars used fixed vane compressors and a clutch - so the compressor was either off or fully on - but for several years cars have used variable vane compressors which only use as much energy as needed. In my book that's a significant move on in technology, and fuel saving.
  13. Continual random rebooting.
  14. Low Rolling Resistance is achieved by a harder compound which has less grip. Personally I studiously avoid any tyre labelled as "eco" because I'd rather have grip and protect my life and property.
  15. The key word there is option, that's the price DIFFERENCE between the base spec radio and the Columbus upgrade not the full price of the Columbus - so many people make this mistake.
  16. Look at the serial number on the cable, maybe even post it here (Ross-Tech will ask you to do that).
  17. AFAIK Skoda don't publish the speed of the Diagnostic CAN bus, you'll have to use the trial and error method.
  18. My 2016 Octavia stays in ECO or D mode as I select using the Individual Mode option.
  19. The CAN bus speed depends on which of the CAN busses you mean - there are many e.g. Powertrain CAN, Infotainment CAN, Comfort CAN, Extended CAN, ... What do you mean by DBC file?
  20. Diesel glow plugs not turning on? Checked the fuses etc?
  21. Be aware that as you have a 2015 model it's a MIB1 Amundsen and that the latest maps available are 2020 maps - no newer ones will be available.
  22. Folding mirrors were only standard on some models and years.
  23. We know you have a 2017 Octavia, but not what engine it has???
