Columbus replacement?
Best person to answer that is @pab567
As I said Canton is separate amplifier, which can be added to Amundsen, Columbus, etc. Is there any wording such as Canton on the speaker grille on the front doors? If not then the glovebox unit is the problem, if there is Canton written on the front speaker grille then the problem is the separate amplifier.
Do you have Canton? That is a separate amplifier, so if you have Canton the problem will be the amplifier not the glovebox unit.
Upgrading/swapping radio to support bluetooth?
Every Google search I do says that the 5E0035812A DOES have Bluetooth???
VRS 2019 Sat Nav problem
You can buy genuine Skoda 32GB SD cards off eBay etc for a sensible price.
Wales new reduced to 20 mph speed limit in built up areas starts on Sunday 17th September 2023.
But set against that it is claimed that the risk of being struck by a car travelling at 20mph is higher as drivers spend more time looking at their speedo instead of the road.
Laura's voice getting deeper overnight
Count me confused? 87.1MHz is an FM frequency, not a MW frequency (531-1602kHz).
Front Assist frightening experience - anyone else?
Then you need to buy an older car, the Golf 8 (and related cars like the Octavia 4) have been released with many software faults and VAG are being very slow fixing them (and in some cases even accepting that they exist).
The stroke of the brake pedal has shortened after coding + ABS parameterization
Is the parameterisation and coding correct for the new software? Sometimes that changes between software versions.
DRL don’t work. Switch position auto. MK3 R/S facelift
Could also be that a previous owner has changed the BCM settings.
Spce Saver wheel + toolkit
You're obviously several years out of date with the variable displacement compressors that are fitted to cars. The fuel usage can start from almost zero and never reaches the mpg levels of older electromagnetic clutch systems in the UK climate.
Update Maxidot graphic
- Amundsen MIB2 Firmware Update
A software update won't enable CarPlay and Android Auto - they require an FEC (Feature Enabling Code) to enable them that is VIN specific, or there are companies that can enable them using a tool such as MIB Toolkit.- wait times/lead times
There is a huge long thread on delivery times in this forum - main reasons quoted are: - shortage of semiconductors due to surge in demand post Covid - loss of factory in Ukraine used to manufacture wiring looms - more orders than expected for hybrid versions- the truth about electric cars
But how many well designed EV's are there? Given many families desire for SUV style EV's there's currently little incentive on the manufacturers to save weight. Surely the concerns about the ability of multi-storey car parks to cope with a mostly EV population are not just scare mongering?- the truth about electric cars
That relies on the garage correctly recording the mileage - I say this because on checking the MOTs of my deceased uncle's Toyota the garage (he always used the same one) recorded the mileage on 3 consecutive years as (approx values) .... 27,000; 101,000; 27,500 Given that he never drove outside of his own town then doing 74,000 miles in one year (207 miles every day) was clearly implausible so they should have noticed their error and corrected it.- Software Updates Mk4
That's true of the software version of the infotainment system, but to see the software version of the other electronic modules in the car (of which there are many, sometimes 30+) you need to use a diagnostic scan tool such as VCDS or OBD11.- the truth about electric cars
Perhaps VED should be based on vehicle weight, then EVs will tend to pay more due to the weight of the batteries.- Phone not charging from cigarette lighter or USB port...
Looks like either your battery isn't holding charge, you've got a load not turning off (no coolbox in the boot?) or the alternator isn't charging , which makes the BMS turn off loads such as the 12V sockets. Check the battery voltage with the engine running, if that's OK then the battery is your problem - not surprising if it's 8 years old.- Digital Switchover 2025 - End of Landlines just 2 years away
For me the elephant in the room with Digital Voice is what happens when there is a power cut, because it relies on mains power to a router or analogue adapter you cannot make or receive calls. You can request a battery backup, but that only lasts 1 hour - so if you're in a mobile 'not spot' you can't call the energy provider or any emergency service. This isn't a theoretical problem as many people who were affected by the recent winter storm didn't have power for days and some were in mobile 'not spots' and had to drive several miles for their mobile to get coverage. IMHO the obligation on BT to provide emergency call coverage should not have been cast away so easily.- Engine bay foam ends
No, petrols have it as well - both my previous 1.4TSI and my current 1.8TSI have them.- the truth about electric cars
OFF TOPIC WARNING The last time I was pulled over into one of these was on the A303 in the Wylye Valley - in 1998 while driving a motorhome. The advice they gave was ridiculous - move a heavy weight (electric scooter motor and gearbox assembly) from low down on the floor at the rear to over the cab in the luton - to reduce the rear axle weight by 30kg. That amount of weight nearly 7 feet up made the handling questionable to say the least... Back to the topic, I think this thread now contains too much personal points scoring and maybe has run it's course and that a halt (temporary or permanent) might be a good idea?- My second car I owned many years ago, fond memories.
My second car was an Austin 1300 in dark green, I bought it for £365 from a family who were emigrating to Australia the next day so were desperate to sell it. Sold it 3 years later for £350, depreciation of £5 per year isn't bad!!!- Infotainment System Query
You don't need a NAV button to have Smart-Link for Android Auto or Apple CarPlay. You do need a MIB2 or MIB2.5 infotainment system, which a 2016 model will have (MIB1 was discontinued in mid-2016 production). Enabling needs a FEC (Feature Enabling Code) or some companies can enable it using software (MIB Toolkit).- Started car / engaged Drive / car stalled - start car manually message
That's just one of several possibilities. I would measure the battery voltage under several conditions before jumping to conclusions: - first thing in the morning before ignition on or starting - immediately after starting - whilst driving if possible - when getting home in the evening I found this useful for monitoring battery voltage. - Amundsen MIB2 Firmware Update
