Everything posted by Sanqhar
Recall - Sunroof
Not safety related. tom
Map routing
2018 SeL with Amundsen (SD card type) navigation. I find the satnav routing very frustrating. I find the three choices impossible to get my mind around. Zooming in to make a reasoned choice is difficult. Restricting the route choice to one seems to be based on pot luck. Too many times it just takes me direct through towns or cities. All I want is to set up the system for the quickest route not the most direct. Examples: Travelling to a destination on the outskirts of Norwich, on a Sunday, I saw the delights of Carrow Road whereas the A47 would have been much better. Yesterday, on another trip I was taken through the centre of Oxford in the rush hour. My 15 year old Garmin Zumo 550 on its original mapping does better. Any pointers or tips for my old brain to grasp would be most welcome. tom
Lowering the SE L suspension similar to Sportline
... or even the 300HP Cupra Ateca! tom
Thinking of buying a new Karoq 1.5 TSi DSG thoughts please
Don't blame me!
I thought kangarooing only applied to manuals. My 2018 DSG never showed any signs. tom
Mystery fastening
No guilty conscience problem with mine. The Passat went in under under the Scrappage scheme. Anything removable was removed. Glad I did this as the Yeti I bought just had the gloop puncture repair, pump and nothing else. The Passat jack etc fitted perfectly in the boot cutouts. tom
Mystery fastening
When you buy one make sure it fits the space. I have one from a previously owned Passat. It doesn't fit. Just like the underseat umbrella, Skoda/VW have two different lengths of black compact umbrella. Needless to say only one fits. tom
Karoq Fuel Consumption
Have you not checked out Honest John Real MPG. These are real world figures as submitted by readers. https://www.honestjohn.co.uk/realmpg/skoda/karoq-2017 This is the best motoring website around. tom
Petrol Lid Sticking
Can it be lubricated? Where would you squirt the WD40? tom
Approaching 3 years of ownership, the good the bad and the ugly!
Would be nice to know what caused that damage. Usually replacement discs are due to rust or worn down pads. tom
Satnav ...again
My life is just a litany of senior moments. tom
Satnav ...again
Thanks. for the suggestions. I have age related interface problems. varoom. Thanks, The Manual I had downloaded back in January 2018 was an earlier wrong version that didn't have the coloured routes option. I have the correct one now. One interface sorted. I still have difficulty understanding it! Karock. Can't find recent "journeys" just recent destinations. In general navigating destinations isn't an issue (I still have a problem remembering how to delete them). When I try "Routes" it shows there are none saved. It's the car/user interface that gives me the most problems. I am seriously considering getting out my old Garmin Zumo 550 (with 2007 mapping), never had a problem with that. Thanks again tom
Satnav ...again
2018 1.5 tsi dsg with Amundsen. If I set a destination and successfully drive the route is it possible to then save the route for next time. As a separate thing I thought the system remembered regular routes used. I have not quite worked out. how to utilise/access this. Any help would be much appreciated. tom
Loosing coolant
Classic (meaning old fashioned) indicator for a blown head gasket is to take off the oil filler cap and see if you can see anything looking like mayonnaise inside. if you do then it's an urgent visit to the dealer. tom
Driving on the left France etc
On my 2018 1.5 Tsi SeL the sequence using the centre screen is: Car (button)>Light>Travel Mode>then ✓ either "L-hand traffic" or "R-hand traffic". tom
Not sure. It certainly does it if it senses pollutants. tom
How about first activating recirculate to help getting the interior cool, then back to normal. tom
Replacing headlight halogens with Philips Led
Missed that bit! tom
I thought such bulb replacements in cars are an automatic MoT failure. tom
Karoq 1.5 tsi ACTUAL fuel economy
I only get 10 miles per litre (45 mpg) with my 1.5Tsi DSG if I am on a journey, even then I have to think a bit regarding how I am driving to achieve this. I keep my aircon permanently on, summer and winter. My journey profile has changed dramatically since I changed from my diesel Yeti in late 2018. I went from nearly 20,000 miles a year to around 5,000 (thus buying a petrol). Another factor to consider is the effect aircon has on fuel consumption that of course being in hot climate is probably on its internal software more aggressive setting. tom
Enyaq towing capacity???
Autocar 29 Jun 2022 did a test of an Enyaq 80 towing a Bailey Discovery 4-2. They reported an approximate 50% reduction in range. Makes you think. What is needed is for a caravan manufacturers to just build a van with batteries in the flat floor, that will sort out the range anxiety. You could then just charge the van, or the car, or both. The knock on effect would be the increase in weight which would then cause complications with the max-train weight. tom
inspection in 29 days,,?
That's a new one on me! Could it be due to some sort of recall? tom
Regional Accent
Don’t understand why this post was moved. It is specific to the Karoq satnav voice. The pronunciation can be weird e.g. when needing a u-turn it says “Make a u-turn if passable” not “...if possible”. Tom
Regional Accent
I live in Suffolk and yesterday made a trip northwards into the wild Norfolk countryside. Nearing Norfolk's major town I realised that the Satnav voice had adopted a regional accent. Norwich would normally be pronounced similar to how it is written "nor-witch". However I realised the Satnav lady was saying "nar-witch". Simply clever! tom
Karoq windscreen washer cap question
At my age I have a similar problem. tom
