Everything posted by Berisford
12v power sockets, are they powered down when you switch ignition off?
Interesting - could you pass on a little more detail please ApertureS.........
New Skoda Driver Question
I'd think you have to do a full factory reset on the infotainment system......'Car - Settings - Factory Settings'.
KESS model, Superb, how to effectivelly prevent keys being scanned?
It disables the Kessy part of the system whilst the car is parked, only pressing the fob will get you in - admittedly, the temporary state is cleared when you press the fob to open but the advantage is you don’t need to use the little bag or a box.
2023 280ps L&K replaced 2016 220ps Style
- Auto-dipping mirror - view?
I sympathise Patent, the Superb door mirrors are very poor for rear wheel area sighting - I wish I’d had the presence of mind to check on my test drive before ordering. I paid for area view too and that is equally poor.- Engine Cover Dealer Delete
Car has been in for 1st year service today - they were none too happy that I’d removed the engine cover - had me sign a declaration that I’d presented the car without cover because of it being lost / destroyed…………- Engine Cover Dealer Delete
My Golf TDI had a couple of broken engine cover mounting studs and so I presented for test without the cover. The tester (miserable git) was taking forever to do the paperwork - when I pressed him he said he had concerns about the missing engine cover and was busy looking for the relevant rule. In the end he gave up but was convinced the missing cover was a problem.- Engine Cover Dealer Delete
Just booked my 280 in for it's first service. Dealer tells me that the engine cover has a recall (I knew, but been ignoring the letters 'cause after a quick look under the bonnet last summer that cover was well secure) and the action required is to remove and destroy the engine cover, no replacement.....! I've just been under the bonnet to remove it and see that even if it did vibrate loose there is no way it can work its way down to the exhaust, it's all too tight. However, more concerning for me is how ****e the engine looks without its cover.- Offside Rear fog lamp not working (4.5.1 (a) (ii))
A single rear fog is always fitted to the offside/drivers side..........- "Coasting" in other modes than ECO?
My 2022 L&K 280 estate doesn't ‘coast’ in any setting - very little information in the handbook.- Center dashboard Ambient light not working
I'm not inclined to go out in this weather and check but I have a recollection of my wife mentioning the lack of colour across the front back in the summer......I'm sure you can switch off the dash or dim it until it disappears.- Center dashboard Ambient light not working
Is it switched on / off in the 'background lighting' options menu?- Ctek battery charging
I got one of those CTEK 'traffic light' cables about 10 years ago - very poor - it spent most of its time in a state of confusion. Even when the CTEK showed a fully charged battery the green light on the indicator lead never showed. They only cost about a tenner so go ahead, give it a try, but I'm 99% sure you'll be disappointed.- Expert help required please
3 - 5 months, if the battery is still good I'll be very surprised.........mine can run down in just a month if locked.- Interior mirror Superb 2020
Can't help with your problem 'brygus' but this is the sort of problem you only find after living with the motor for a while. I wish I'd noticed on a test drive how poor the door mirrors are - not only do they not fold in sufficiently but they can't be tilted down enough to see adequately alongside. Add to which the expensive 'area view' becomes almost useless when in a tight spot, not that it's particularly good at the best of times.- Free suspension and interior bits for all.
I hope you're not giving up on the Superb range are you ApertureS? Your knowledge and expertise in all things Superb would be greatly missed.........- Sat nav sd card
I still have the Skoda card mentioned above - £10.- Laurin&Klement Superb
You don't really want that tacky cheap and nasty L&K badge on the wings do you? Mine were off and in the bin within 20 minutes of being delivered. The gear knob decal 'DSG 4x4' was quickly replaced too.- Fuel flap is stuck and won't open
I adapted the catch on our Karoq by trimming / filing to avert any potential ‘stuck’ at the petrol station scenario - by trimming the catch I was able to prise the flap open without causing damage but still locked sufficiently - doesn’t help you today but the Karoq forum highlighted the fact that many vehicles were suffering fuel flap solenoid failure.- Steering Assist
Thanks guys but there appeared to be something different in the latest models inasmuch as The only options I have are ‘Lane Assist’ off / on and ‘Steering Wheel Vibrate’ off / on - seemingly no further menu’s……….- Steering Assist
Not sure if ‘steering assist’ is the correct title - but, my Superb used to follow the road and complain if I let go of the wheel - the whole business irritated me and I somehow turned it off, how I don’t know. Messing with the settings yesterday I noticed all driver assist gizmos are switched ‘on’ but the semi ‘self steering’ is limited to wobbling the wheel and putting some resistance in the wheel if I try to cross a line without indicating. Is there a sub-menu somewhere I’m missing?- Slow Engagement of Drive - DSG DQ200
I get that on my Golf occasionally, move into drive after starting up and nothing - move the selector back to neutral and into drive again - all OK. Like you say, never happens after stop-start. I'm living with it .- preventing a flat battery caused by stupidity
- 12v battery low alert - ideas?
There’s a ‘default’ setting in VCDS for non codable batteries such as the Bosch I’m sure, certainly there’s a work-around……….- Manoeuvre braking, Park Assist, Front Assist all disabled
Sudden battery voltage drop maybe? Should / could / might clear with short run. - Auto-dipping mirror - view?
