Everything posted by inspectorman
Pollen filter replacement
When you take the old one out, observe the dirt and insects on the upper surface. This confirms the air comes from outside - up in the plenum chamber area - and passes down to the fan motor underneath. So airflow arrow points down - as one of the prior photos shows.
Spaceback folding boot floor repair
This is my wife's spare with the tool insert in; tyre size happens to be 185/60 R15. Wheel might be a 6Jx15 ET38 but you'd have to check.
Charging voltage at idle
General upper limit for charging AGM batteries is stated at anywhere from 14.8 to 15.0V. But this is often quoted for a standard - maybe 20 or 25C. Below that the absorption voltage rises for each degree C drop. That gives us some pretty high theoretical voltages for charging a cold AGM battery - but it's the battery temperature we are considering here, not the ambient temperature. Self-heating during charging will bring the battery temperature up. A very smart charging system would have some form of temperature measurement on the battery to take account of this. A step too far for car use. So your "high" voltage may be normal and you are sensitized by having to fork out recently for a new battery. Are you reading the car voltage values from the ECU or are you using one of those cigarette lighter plugins? Or something else?
I think, something is wrong with my new rear brake pads, help, please...
Reasonable to believe they have fitted the wrong pads - looks like the ears of the pads aren't right for the caliper. Try any of the major brake pad catalogues to get to the correct part number and fitment for your engine and year. Sometimes there will be multiple choices - it helps at this point if you can find the correct three letter code (for example 1LK or 1LM or 1LU, maybe) in your vehicle documentation. Used to be on a sticker in the boot but later came as a sticker in the vehicle handbook. ERWIN can tell you the exact build codes for your car for a small fee if you have no record anywhere of the codes for the brake sizes. I can't find any fitment for Skoda for GA8135FG after a brief search. May be different for your country.
- Whats the most up-to-date software?
Interior lights LED types
Left is W5W. Right is a festoon bulb - and all you need is a ruler to measure the length.
luggage louver holder malfunction
Look for pictures of those part numbers. It looks as if the part is only placed in position from above by gravity, and secured in location by trim clips into other parts of the boot. Work out where those clips are then use a body trim removal tool to release the clip. You may have to remove the lining of the boot, below the shelf support, to gain access to those clips. Take your time and don't force anything. If it won't move, you've missed a clip or there might be a securing screw.
Those supporting pegs appear to be part of the moulding of the parcel shelf support and therefore not individually replaceable. You will need to replace each side. Try looking for 5E6867762 and 5e6867761, maybe. If you dismantle the car first, the part numbers are often visible on the hidden side. İyi şanslar!
1.5 TSI (sorry)
I'd forgotten how terrible some of them were. I've even changed carb for a Weber because the fitted Pierburg was so bad. Never went as far as my perfectionist friend who fitted a microswitch and warning light to remind his wife the new (manual ) choke he'd fitted was engaged, though.
1.5 TSI (sorry)
Kangarooing not an issue on 2020 Octavias. Seems to have been restricted to earlier cars; and don't forget the anti-stall feature (where the car will increase engine revs slightly if it thinks you're going to stall it) may be confused with kangarooing by some. For those of us who grew up juggling manual chokes with throttle position on cold engines ( and sometimes advance/retard controls as well ) modern systems are a huge improvement. An overnight test drive will answer your question since you will then know without doubt you're starting a cold engine. Try asking the sales person if he / she can demonstrate what version of infotainment software is loaded. A small test as to whether he/she has any clue what they're selling. Buried somewhere down the Car / system setting from memory but may be different in different infotainment setups. Don't forget it is entirely possible to have an up to date infotainment software, but many of the other modules have their own software load which may or may not be properly up to date. These parameters are not easy to access. But a decent service history might give you more confidence everything has been addressed.
OBD reads battery voltage lower than multimeter
Your multimeter - and whatever the ECU is using to measure volts - are not calibrated devices. In addition, you have no idea at what point the ECU is looking to give out a voltage reading. It may even be a compound of four or five different sensors. The main thing is you have a new battery and the charging system appears to be functioning. Cross fingers for the hub magnet / sensor change fixing your warning lights.
Dealer not covering blocked screenwash jets under warranty!!! Responses needed ASAP please :-(
You seem to be unlucky - I have never in the past 30 years of Skoda ownership been persuaded to buy the unicorn tears VAG sell for screenwash. But I have mostly stuck with Sonax rather than chopping and changing supplier. Your response depends on how much you value your time. I would be rinsing out the washer bottle with repeated fills of warm water to see if I could improve the flow. Emptying the reservoir should be easy enough with a suitable length of hose to siphon the contents out. Applying back pressure from the hose to the nozzles might also help dislodge anything on the filter. But I am a cheapskate.
Options on Winter Alloys/wheels ?
Should be fine. Some claim up to 15mm difference is unimportant but I disagree. And it's the easier option - outwards - so no fouling issues. Great price.
Hi beam h7 how to replace
H7 or Xenons? Xenons here... https://www.youtube.com/watch?v=I_x__hnOffI
MK3 written off, should I upgrade to MK4?
"If you are looking at an early Mk4 I don't think it's an unreasonable request to ask a dealer to ensure the firmware versions of problematic models are at a minimum version as part of the deal. If they refuse, then walk away. If they oblige then it's an easy task for them to provide a written document to prove the modules are at the versions they need to be. If it makes the difference between a sale and a 'no sale' I'd think most dealers would find a way to get it done. It's a shame it does effectively come down to this, as people are starting to avoid the earlier cars. I know if I were looking to buy anothe early / first edition Mk4 I'd be insisting the firmware be updated. As others have commented the vehicle mechanically is fine. Good engines, comfortable, economical. All of my issues have been software related - and most other people in this forum too." Absolutely this. I'd even get the VIN and run it through ERWIN as well to see if any outstanding actions are required. It's taken four years and six visits to kill all of the software irritations so far. It would have been three but I couldn't face schlepping up to the dealer at the three year point for the relentless upselling and did the oil and filters myself. Had they been on top of their TPIs I would have been contacted before that.. ""please inform customers immediately/urgently (Bolded and underlined) the customers with the vehicles affected". Fat chance. But - it is a big, comfortable, economical drive with a high spec interior (SEL trim) and it does do what I wanted it to do. So have a chat with the dealer to see if he has any clue about what the problems were, how the dealership coped, and what state the possible purchase is in with regard to those updates. You should be able to work out pretty quickly if you're dealing with a 24 carat bullsh*tter or a genuine guy.
Unusual electrics
Window switch? Cheap and easy to replace.
Infotainment System Restarting endlessly
Indeed. My post sought to amplfy spcdust's statement about other control modules needing to be updated. I did not claim the infotainment SW version would be changed. Peace and clear skies.
VCDS Scan - What's The Diagnosis
Has this ever been flooded? The corrosion is strong in this one.
Some more information for you. 14 months ago Skoda released a TPI adressing this issue advising that existing customers should be urgently/immediately contacted to have campaign 48S5 carried out on their vehicles. (I leave you to guess whether or not my local dealer did this....) Anyway, you can either check on the Skoda's recalls/campaigns website to see if it's listed , or pay ERWIN 7 euros to get a full breakdown of all sorts of interesting info on your car. But a decent dealer should be aware of this TPI and best of all my dealer didn't charge. They may charge for the update to 1941 or 1969 if they're suitable for your car. The service droid admitted to me that they were delivering 24 plate cars with software faults.... for which no fix was currently available. I bet the new owners are impressed. At least it looks as if there is a fix for your issues.
Front windscreen wipers.
Given the wipers work when the car is moving / vibrating, I wonder if the bonnet microswitch is playing up? This cuts power to the wipers if the bonnet is open. As far as I know there is no adjustment so replacement is the only answer. Get someone to jiggle down on the bonnet with the car stationary and engine running - and try that.
Potential purchase - any red flags here?
..and don't forget to tell the dealer to get his finger out and update the mapping database. 5+ years out of date.
Jemm
Removing multimedia unit in glovebox - 2018 Rapid
The manuals are downloaded from Erwin - 7€ gets you an hour's access to add much as you can. You can also download the exact build spec of your car - this will get you stuff like the important three letter code detailing which brakes you have, for example. Not the most user friendly website but keep clicking.
Sat Nav Updates
Is the 250GB USB stick too big? Try with a 32 or 64GB stick.
