Everything posted by CJJE
Travel assist steering wheel sensor faulty
An update. The intermittent warnings disappeared last spring and were fine until December 2022. They then returned very intermittently, (without the Lane Assist Unavailable and other error messages that came with it in 2021), and seemed to be triggered by turning sharply into parking bays etc. Over the winter they occurred once or twice a month, and always disappeared on their own after a single beep. But now they're getting more frequent again, and clearly aren't linked to using the heated steering wheel. The Lane Assist camera and adaptive cruise control sensors seem to be working fine, so I'm convinced it's down to the capacitive sensors in the steering wheel which are designed to detect you releasing the steering wheel (and also trigger the Emergency Assist should the driver pass out!) It's booked in to my dealer for a day's investigation next June (which is the earliest they could provide a courtesy car! There have also been some other electronic glitches. Once or twice the trip odometer in the digital instrument panel has reset itself at around 150 miles or so, and the digital instrument panel itself once lost my preferred setup with a live map in the centre. Chris
Infotainment system 😱
The volume control seems to be working like it does for traffic announcements and sat nav guidance, and preserves the chosen volume for each application, regardless of the radio or media volume. Once it's been set for each application that is.
Infotainment system
A Bolero doesn't have sat nav, and the same system with sat nav is the Amundsen.
Re satnav: a typical residential post code covers quite a wide area, so the satnav is just pinpointing its centre. I've found entering the address I want in simple English (120 Badminton Road Stafford for example) will take me to my required destination. (Note the quoted address is fictitious so don't expect it to work ) I have never had to make or receive a call in my car, so can't help you on answering a call. But I think other threads have mentioned a button you push to accept a call.
Bulbs
The 2020 Sportline only uses a WY16W bulb for the rear indicators, and a W16W for the reversing light. All others are LED clusters. Chris
Negative battery lead and fuel consumption readings
My trip odometer resets itself occasionally, so I've given up relying on it to calculate my MPG. The readings in the central display of MPGs also resets but the overall odometer isn't affected.
What are these icons?
If your phone has QI charging, and you have the QI Phone Box, it also shows that your phone is being charged.
Karoq Current Delivery Lead Time - 8-10 Weeks Dealer Optimism?
There seem to be major problems at Emden according to this report: Dealers complain new VW, Audi and Porsche cars stuck in huge German port backlog – Car Dealer Magazine and of course Skoda also use this for shipments to the Midlands and north, as well as VW, Audi etc! So just getting your car built, may not guarantee an early delivery! Chris
Fob battery
In mine the battery type is printed inside the key fob itself. And I change them annually to avoid problems.
1.5TSI or 2.0TSI?
I went for the 2.0 TSI 4x4, on the basis that I only drive less than 10,000 miles a year now, so the extra fuel consumption wouldn't be too disastrous. In practice I get around 35 mpg on shopping trips and 40+ on longer journeys. I don't off-road, but the 4x4 prevents wheelspin on icy or damp roads and feels very reassuring. It also seems to be balancing out the tyre wear for me as all wheels are being down at the same rate. Mine squeaked under the £40k boundary as I bought it back in 2020 (despite the many visits to the option list!).
TMC traffic events no longer being received...firmware update required?
Does it need you to have a valid Connect licence perhaps? And if so have you renewed it? Chris
Sunroof glass rattle when roof window opened opened
If it's partially open (ie lifted up at the rear) it could be bouncing on its support struts. But if it's fully lifted or slid back then I'd be surprised if it rattles. Can you move it up and down by your hand? Chris
Mine have never rattled either. Is yours fully closed? Chris
Umbrella
Is there a part number on the umbrella or wrapper? According to the Horton's website, the under seat umbrella has Part Number 000087600L, and is 25cm long when folded. But confusingly they also say this fits in the front door for the Karoq! However the umbrella for the front door of a Kodiaq is Part Number 000087600G9B9, and is 26.5 cm long. My MY21 car has a holder under the passenger seat for its umbrella rather than the hole in the edge of the front door, and I'm assuming your facelifted car is the same. If so, then I'd suggest your dealer has supplied the wrong umbrella with your car. Chris
Amundsen and USB-c
Where did you copy the music file from? If it is also on your PC's hard disk, what does file explorer show when you add the appropriate columns to the screen? I'd assumed it was all just saved as Metadata in the MP3 file? The only thing iTunes adds to the files as far as I can see is the album cover art. Chris
Amundsen and USB-c
My music files have been saved to my PC via iTunes (ripped from CDs). On the PC, the iTunes library shows all the tracks per album, with details of the artist and genre. So when I copy the files to a USB drive all that info goes with them. My Amundsen then lists the music by artist alphabetically, and if I choose one, then displays a list of their albums to choose. I also save chosen artists, and genres as favourites to access them quickly. Does this help? Chris
Amundsen and USB-c
Correction to my earlier post, which was too late at night! The music files on my USB drive are MP3 files, stored in folders and sub-folders as Artist / Album / Track. Chris
Karoq cam belt change - start saving now !
🤣🤣🤣 It's 8 or 9 years old I think, with around 56k miles on it. No idea if its the V6 or not. Chris
The SOS call/infotainment failure again. Can Skoda sort?
On my Karoq it's on the Menu / Settings / System Settings / Information screen on the Amundsen screen. There is a thread on here talking about updating the software yourself via a USB port, but the thought of trying that and it failing to update fills me with horror! I dread to think what the cost would be of getting a dealer to reinstall the software on a car if you brick it!! Chris
Just had a phone call from my son with a Range Rover Sport. He wanted to get his car serviced last month, and was told it would take a day as he needed the cam belt changed. He booked it in, to be told the day before it was due that they'd need it for two days as it was a big job. Went to pick it up yesterday to be told they hadn't been able to change the cambelt as they were out of stock and on back order! They also couldn't MOT it as there was an airbag warning light up, which needed a new wiring loom to cure. They also couldn't give him a courtesy car as he needed it to take his cats to a catttery before they went on a short holiday - and animals weren't allowed in their courtesy cars, even when they were confined in carrying crates! Perhaps Skoda dealers aren't so bad after all? He's tried several dealers in Suffolk, but none of them seem any good 😞 Chris
With Karoqs this seems to trigger a software update by the dealer. Mine went from 0270 to 0276, and the fault hasn't returned. I know the current software versions are at least 0306 now, but dealers only seem to update a car when you report a fault that the update should clear. If your Scala is out of warranty, it'll be interesting to see if they accept it's a design fault that is still covered or not. Chris
Amundsen and USB-c
I've added more info to my reply, so you need to re-read that too. You can format the USB drive in VFAT, FAT16, FAT32, exFAT or NTFS, and I just copied the MP4 files from my PC in a folder for each CD/album. They are then displayed with the artist, track name, album name etc (and usefully you can set favourite artists, genres, or albums to quickly select the desired tracks). I don't know if you need to be set up as a primary user to use a USB drive (I wouldn't have thought so to be honest) but this does need to be resolved. Is there an existing user that needs to be removed first perhaps? I was able to set myself up fairly quickly, but the procedure is quite strict on how you do it. (I did it back in November 2020 so my memory is a bit hazy now.) But I remember I needed to have all the car keys with me, and my phone. If you can download a user manual that should guide you through it, otherwise complain to the dealer who sold you the car. My car came with a printed manual, but even that referred me to a downloadable manual for details of the Amundsen (but that was when the MIB3 units had just been released). I also hate this "green" idea of not providing written user manuals, but I'm of a generation who received a bookshelf of manuals back in the 1980s when I first installed MS Office onto a PC! Chris
Amundsen and USB-c
The maps will update automatically whenever you drive into an area with updated maps (as long as you have a current online licence). My car is on software version 0276 still but the maps are currently showing as version 22.12. You can check this via the Menu / Settings / System Settings / System Information screen on the Amundsen display. But if you are having problems registering as a primary user, then this could be a problem. You are stuck with the radio logos provided by Skoda as there is no way to add your own as we used to on older systems. But I have no problem playing music from a USB-C drive in the socket in front of the gear lever. I use one of these: Integral 128GB Fusion Dual USB-C & USB 3.1 Flash Drive - 200MB/s £19.99 - Free Delivery | MyMemory The facelifted car will have the same infotainment system as cars made since August 2020 I believe, but it is easy to tell which you have as the rear lights look very different. See here for an example: Skoda Karoq (2022) - picture 64 of 232 - 1024x768 (netcarshow.com) The facelifted car was announced in November 2021 (see The new ŠKODA KAROQ is here - Škoda Storyboard (skoda-storyboard.com) so yours could well have been produced in February in preparation for its launch in the UK early 2022. Chris
Unexpected recall.
It's 140Nm in my manual for a July 2020 (MY21) car.
Digital dash
I think I've read elsewhere that Karoqs now come with a digital instrument panel rather than the analogue one as standard. But some people are querying whether it is a smaller and simpler unit than the one that was optional for my MY21 car. I wonder if the cost of the Amundsen Plus option is justified by including the bigger one, that lets you display the map at the centre of the instrument panel rather than on the central display? I suspect you need to visit a dealer and look at showroom Karoqs to get the answer - and don't believe a salesman unless he can prove what he tells you! Chris
