Everything posted by CJJE
Deactivate lane assist function possible ?
Odd... on my Karoq I can set the Lane Assist to be on or off via a button on the steering wheel (which gives access to the Assist System menu) and it then remembers my setting. I just wish it would also remember that I use the Speed Limiter function rather than the Adaptive Cruise Control as I have to reset that every time I start the car! Chris
Locking Wheel Nut?
The puller for the plastic covers was missing from my car, but it's cheap enough to replace. Chris
Karoq Boot Lid Broken Pull Handle
There is an older thread at which talks about this problem, and may give you some help, or at least people to contact. Best of luck, Chris
Unexpected recall.
When I had the SOS problem back in November 2021, my dealer updated the main software level from 0270 to 0276. Later cars have had further updates to the software but it seems that these are not installed to older cars when they are serviced, despite my invoices saying that they have checked to see if there any software updates required. (I am told it takes hours to download the updated software from Skoda's servers so can understand why it is only updated if will cure a reported fault.) Note that this software cannot be updated over air like the navigation database and 'shop' screens, but you can check which version is installed by using the Menu / Settings / System Settings / System Information screen. Mine tells me that I software version 0276, and navigation database version 22.12 at present. Chris
Problem with selecting Driving Modes, other than Normal.
Emission regulations mean that the car has to start in the mode used for the tests - which is the normal drive mode since not all models have a choice. So regardless of whether you left in Sport or Eco, it will restart in normal. But my car MY21 does exactly that... it doesn't get confused and still try to kid me that it is in Eco when it isn't! Chris
Sportline Alloy Wheel Blemish
All it needs to do is cause a hairline crack in the varnish coat. Water will do the rest. Chris
I'm sure a dealer would call it fair wear and tear. The plastic centre caps on all VW cars are also susceptible to the same problem, but it costs much less to replace them! Chris
2020 Sportline Rear Fog light condensation
Not noticed it in my rear fogs, but common in the front lights as the LED bulbs don't run hot like tungsten bulbs to burn it off. (One benefit of having tungsten bulbs as rear lights and rear indicators perhaps?) Chris
Looks like water has got under the varnish. It only takes a stone to hit the wheel to crack the seal. But it's a common problem with diamond cut alloys. The only cure is a refurb when it gets bad enough to be obvious. I'm thinking of having mine painted all black when they need it. Chris
Voice assistant 'Laura' changing the gender?
For the satnav voice, you can choose a male or female voice when you choose the language. Does this carry over to Laura perhaps? Chris
3rd Generation (MIB3) Infotainment System Problems
On my MY21 car, you just press the Station List virtual button, then scroll down to see all the available stations, both DAB and FM. If you only wish to see FM stations, go into the Radio settings menu / advanced settings and then select see only FM instead of DAB and FM. The radio settings also let you choose to step through all available stations by pressing the arrow 'buttons'. Note that the settings menu will also let you choose whether or not the radio will switch between DAB and FM transmissions for a station depending on which has the best signal. And I think there is also a setting that allows you to see a manual frequency scale for FM so you can set the radio to a particular frequency (although I've never tried this). Finally, you can then save the desired radio station to a preset. Chris
trip odometer
I have a different problem with mine! I have the Virtual Cockpit, and so normally resetting the trip odometer needs a trip into the settings menu... but twice now, it has reset itself! Each time I have only driven around 300 miles since it was last reset, and I haven't noticed any other software updates causing it. But it's annoying as I use it to record my mileage each time I fill up with fuel (luckily I record the total mileage as well so my records are still correct.) Chris
Can you see the files on the TV still? If not, it sounds like you removed it before the files had been closed by the TV. Chris
Hi DaniC, There is no way that I have seen for the Amundsen to format a USB disk. Instead, it will read files on any USB disk that has been formatted already using the VFAT, FAT16, FAT32, exFAT or NTFS file system. Details were in my digital owners manual, in the Amundsen / Media / Supported Sources and Files section. Presumably the web-based owners manual for your newer car will have the same details somewhere. Best Wishes, Chris
Karoq cam belt change - start saving now !
Makes me glad my 2.0 TSI has a cam chain instead - or so I'm told!
Travel assist unavailable alarm
Agreed KaroqCZ. This is a long-standing design fault that has been affecting many VAG cars and not just Skodas. My previous Golf Sportsvan sounded an alarm when it thought I wasn't turning the steering wheel often enough - and so gave false alarms on long straight motorways. So I'd hoped the capacitive sensors might be an improvement. But now it's looking like we were all mis-sold a feature that hadn't been designed properly. Perhaps we are due a refund of the money we paid for this option?? Chris
Thanks for the info. My car had been silent for the last few weeks, until I used the heated steering wheel this week. It was OK when first switched on, but the TA warning came up shortly after turning it off. Now one of the sensors required by the TA is the capacitive sensor in the steering wheel that ensures you have your hands on the wheel. I now believe that using the heated steering wheel affects this sensor (through expansion?) as when not using it, I do not get the TA warning. So perhaps the other solution is to get my driving gloves out again rather than lose the Emergency Assist function?? Chris
New owner- help
Correct. My copy of the owner's manual states "To complete the activation it is necessary to have two original vehicle keys with you." (Page 159 in mine, under Online Services, User registration and activation of the Skoda Connect services.) Chris
New owner- help
The built-in SIM? It should be automatically connected, unless you have redirected it to your home WiFi, but you can check via the Menu / Settings / Data Connection / Integrated data connection (eSIM) settings. I was able to set mine up by following the Online Services section of the owner's manual carefully, But I didn't already have a Skoda ID etc so was doing it completely from scratch. Chris
New owner- help
No, Skoda provide a restricted data plan for you. It's required to provide online updates for the maps and some software in the car, and to keep the SOS function working. The only need I've found for an extra (and expensive) dataplan is if you want to use the Web Radio - which you can also access via your mobile phone if you really want to. Chris
New owner- help
It might be worth trying to connect via its inbuilt SIM out in the open air. That's how I did mine. But this really emphasises that sales people need to give their customers more support in using the software built in to modern cars.
New owner- help
The software update has to be done by a dealer, and takes quite a time to download. Generally it will only be done if you report a problem which can be cured by the update, and not as standard. (Despite the annual service apparently checking to see if the software is up to date!) For registering as the primary user, have you deleted any previous registered users from the car? Chris
It was an option on my car, which seems to turn on the Adaptive Cruise Control (ACC) and Lane Assist. I often use Lane Assist but prefer to use the Speed Limiter function instead of Cruise Control for most journeys. The Travel Assist also seems to use the capacitive sensors in the steering wheel to detect if you have removed your hands from the wheel - and I now suspect that if these sensors are playing up, you get the 'Travel Assist Not Currently Available' warning. It is more prevalent in cold weather I find, but is not linked to whether I have turned on the heated steering wheel or not. Chris
Deleting Travel Assist also seems to remove the Emergency Assist feature - which was an option when I bought my Karoq, and one I had added for its safety implications. Over the last two days, the Travel Assist not currently available warning has re-occurred repeatedly, usually disappearing again after a few miles. This fault is being reported over a wide variety of Skoda, VW and SEAT models, so I am disgusted that VAG have sold such an unreliable feature to so many owners, and can't work out what's wrong with it.
Converting Karoq SE-L with space saver spare wheel to full-size spare wheel
My 4x4 can only take a spacesaver as boot floor is higher up and there's no room for the full size spare. But it is really only an emergency option designed to let drive (slowly) to get the original tyre replaced or repaired. I've use mine once to drive for a couple of miles to my local tyre repair shop and the car's handling felt very odd! I can quite understand owners wanting a full size spare that they can leave in place after changing over, especially if the puncture happens on a long journey, or in a remote rural area. Chris
