CJJE
Everything posted by CJJE
  1. CJJE replied to chatlow's topic in Skoda Karoq
    They have a flat profile that fits on the top of the roof rail (with a flexible rubber section that flattens out) and the rubber strip under the roof rail pulls it down. So there is no 'claw' to fit under the roof rail. This shows them, but fitted to a wingbar :
  2. CJJE replied to chatlow's topic in Skoda Karoq
    I use Thule 775 feet on 127cm Aerobars, which are items I already had from my previous Golfs. (Note: the 775 is not a typo (!) for your 757 feet, they have a strap that runs under the roof rail and clasp the feet down onto the rail.) Chris
  3. If it's not leaking from a hose, and visible on the ground under the car (but beware confusion with the water that drips from the aircon after use in hot temperatures), then it could be a failed gasket with the coolant leaking into the cylinders (expensive!!) How much coolant are you losing? Chris
  4. CJJE replied to Shuttlebasher's topic in Skoda Karoq
    Never noticed it myself! Chris
  5. CJJE replied to AScoob's topic in Skoda Karoq
    I transferred all my music files onto one of these: MyMemory 128GB Dual USB-C & USB 3.1 Flash Drive - 200MB/s £22.99 - Free Delivery | MyMemory It fits under the sliding cover and gives me no problems. (You can also get similar devices with more memory if needed.) Chris PS: the MIB3 infotainment system also lets you set favourites for the memory card - such as individual albums. artists or genres.
  6. Who needs a heated steering wheel with that!! Chris
  7. CJJE replied to Schtum's topic in Skoda Karoq
    My car is a MY21, built in October 2020 with the MIB3 system, and so I don't know if this will apply to your car. But hopefully you will still be able to identify the software version now installed. If you press the Menu button on my MIB3 Amundsen system, then choose Settings, System Settings and System Information you'll see the software version fitted to your car. Mine originally came with version 0270, but was updated to 0276 to cure faults such as the User Profile failing to load, and the failure of the SOS/Emergency Call system. No doubt yours will have been updated to avoid any problems that have been identified in the older software (but I would have hoped your Service Manager could have explained this to you and not just fobbed you off.) It does seem at times that Briskoda members get more information about their cars than the dealers do! Chris
  8. Ahh, I can beat you as I bought my first car (a 1950ish Vauxhall Velox) in 1963. With Citroens I always suspected that there was a restriction in the carburettor on delivery to limit the power for the first 500 miles, which was removed at the first service. Chris
  9. These youngsters!!! 😉😉 I well remember having to change the oil every 5000 miles (Duckhams 20/50 please) and cleaning and gapping spark plugs. In fact when I was buying new Citroens in the 1980s, they needed an oil change after the first 500 miles! For one car this was interesting because just after buying it I was driving to the south of France, so I took it into a French dealership for its first service! Chris
  10. I agree. I changed my batteries for Duracells from Boots (well within their sell-by dates but still got the message to change the battery. I then bought some Panasonic ones from Radiospares which had a higher voltage when tested and these were fine. The KESSY keys seem very sensitive to the battery type and of course transmit a radio signal all the time (or when they're moving for cars from MY20 on) saying "I'm here!!". As a result the batteries run down a lot faster than the non-KESSY keys and I plan to change them each year as a precaution. Chris
  11. CJJE replied to CJJE's topic in Skoda Karoq
    The alarm did sound briefly, but it wasn't the car horn, and we were in the back of the house watching TV so didn't hear it the first time. It seems to be a higher-pitched siren than the normal horn. Chris
  12. CJJE posted a topic in Skoda Karoq
    Had an interesting experience last night... Just before 10 pm the My Skoda app on my phone reported that my anti-theft alarm had been triggered, so I went to have a look at my Karoq which was parked on my drive as usual. Sure enough the indicators were flashing, but there was no-one about and the external lights on my house hadn't been triggered (normally they will come on whenever a neighbouring cat walks past!). So I unlocked and relocked the car to clear the alarm. A few minutes later the app told me the alarm had been triggered again, so I went outside to check, but again there was no-one around. I opened and closed the doors, checked the windows were closed and relocked the car. But as I was about to return to the house the alarm went off again! By this time I was wondering if it was being triggered by a spider inside the car, so I sat in it to have a look, and found a large moth with a very chunky body fluttering around. I opened the doors to let it out, relocked the car and problem solved as I've had no more alarms since. But... 1) I hadn't been in the car since last Thursday (4 days ago) so where had the moth been? Had it pupated inside the car somewhere? Or had it somehow entered via the ventilation system? 2) The Remote Access part of the My Skoda app seems to work very well as each time the car alarm was triggered I got a warning on my phone from the app, and also an email! Chris
  13. I suspect the 4x4 kicks in more often than I'd expected. After driving FWD cars for many years I've become accustomed to swapping wheels around at 10,000 miles or so to equalise wear. (I prefer to change them all at the same time so I can switch all 4 wheels to a new make or to all-season.) But when I measured my tread depth at 7000 miles all 4 wheels were much the same! I'm thinking that on FWD cars the front tyres wear down more under acceleration, but on a Haldex car the rear wheels are helping out so the tyre wear is equalised? Chris
  14. If its in the ACC menu then I suspect it only affects the acceleration when the cruise control regains your set speed. I'm surprised to see a Comfort setting though, as in my car (with the optional Dynamic Chassis Control) Comfort mode alters the damper settings rather than the engine. Chris
  15. CJJE replied to paco's topic in Skoda Karoq
    After January 2017 a new aircon gas HFO-1234yf had to be used in cars (to reduce hydrocarbon pollutants). Perhaps this also has reduced the efficiency of the aircon units? Chris
  16. My MPG (measured by filling the tank each time and calculating the litres added and miles driven) is around 42mpg for long motorway journeys at 70mph, and 35mpg for short shopping runs. I've done 7000 miles so far and it still gradually improving, so yours could be better - and of course driving styles can affect this greatly. I use Eco mode occasionally, snicking into Sport mode for fast overtaking when needed, but haven't noticed any reliable difference in economy. I suspect Drive mode with a sensitive foot on the throttle is just as good. I used E5 petrol at first, but changed to E10 when the prices escalated, and haven't noticed any difference in MPG. Chris
  17. Very true... I'd missed the point that Elson had a 2019 car. As you say the new KESSY key was fitted to MY20 cars (which have 'L' as the10th character in the VIN). Chris
  18. You can turn off the KESSY receiver in the car each time you lock it by pressing the lock button on the key and then touching the outer dimple. I do it whenever I'm parking up overnight or in dodgy areas. This is really belt and braces though as the key turns off its KESSY transmitter after being motionless for 5 minutes. I also turned off the Soundaktor noise generator which makes a fake engine noise in some driving modes. You can do this in the settings for the Individual mode, but I did it permanently with OBD11. Check that the last owner's ID has been deleted from the car settings, and set yourself up as the new owner. Check the engine cover is firmly fixed in place. There was a VAG-wide recall recently for cars fitted with the 2.0TSI engine as the cover could move under harsh acceleration into a hot area and catch fire. The Karoq wasn't included in the cars listed, so it could be that the engine compartment is sufficiently different that it's not affected, but I check mine every now and again anyway. (The recall was to simply remove the engine cover for the time being until they can supply a safe replacement.) Enjoy it... but not too much with the price of petrol at the moment! Chris
  19. Assuming it's the same as my MY21 Karoq, it needs the ignition on, and the car stationary (I think). So each time you stop at a traffic light or junction a bit more gets downloaded and installed. It continues where it left off each time you turn the ignition off and on again so once you've told it to go ahead you just let it do its thing. Chris
  20. From the April 2022 brochure I think that the SE Drive and SE L trims have halogen headlights as standard (with the SE L having LED running lights). The LED Matrix lights are standard on the Sportline and optional for the SE L (the 'ordinary' LED headlights fitted as standard or optionally to pre-facelift cars don't seem to be offered any more.) Chris
  21. CJJE replied to CJJE's topic in Skoda Karoq
    I also like analogue watches, but love the flexibility in my digital instrument panel. You can still set it up to display the traditional round instruments, but choose the info to display inside the dials and between the dials. (I have the average fuel consumption and driving range, with the map between the dials. The dials themselves also display the speed you've set on the cruise control/speed limiter, and the actual speed limit. Chris
  22. CJJE replied to Colchristie's topic in Skoda Karoq
    When I bought my 2.0TSI I thought I'd treat it by using E5, but with the recent price increases I've decided to save money by using E10 instead. (For me that's about £1.93 per litre instead of £2.00.) I record my fuel consumption each time I refill and can't see any difference in fuel economy, or if there is it's been masked by the difference in the trips I'm making. Chris
  23. CJJE replied to CJJE's topic in Skoda Karoq
    I really like mine, but added several options that are no longer available - like the 360 degree camera - that I find invaluable. And the bundling of options is annoying as I love the heated windscreen but wouldn't have to buy heated rear seats as well to get it. I rarely have people in the back of my car, and anyone using car seats for children would find it pointless as well. But that's the way it's going. Apparently Renault are now offering a fast track manufacture and delivery if you agree to a severely limited choice of options - even down to a choice of white, black or grey as a colour!! Chris
  24. CJJE replied to CJJE's topic in Skoda Karoq
    I'd believe Skoda UK's press release and June brochure over AutoExpress. And the press release tells you what has been added - like the 8 inch digital display being standard and the new options/ Chris
  25. CJJE replied to CJJE's topic in Skoda Karoq
    It's still shown as an option in the June 22 brochure.
