Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Paint code of kodiaq
Skoda Fabia vrs exhaust hangers
Go here and find the relevant diagrams and so part numbers https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/225/2
Help with new radio installation (elektricity cable scheme, reversing cable problem)
8d pin 3, according to what it says right there.
Yes, just cut the pink wire and tape over both ends.
Electric front windows
Probably the module, not the switches, but see if the switches light up if the car's lights are switched on. That tests for unbroken earth connection to switch pack, if they do illuminate, very unlikely that both switches failed at same time. Message me with the VIN if you'd like me to check part number of motor module, without any door disassembly.
Try operating the windows by turning the key in driver's side door lock and holding it fully turned. (Start with locked car). Doors should all unlock and if you keep key fully turned, windows should start lowering together. That effectively bypasses the switches to test the motor itself.
Octavia Scout (2008) 2.0TDI Rear Brake disc size (PR Code 1KF)
260 x 12mm is the disc size for 1KF on Octy2 2008. Pads to suit have genuine part number 1K0698451G. Look at images of those and see if they match what you currently have fitted to the car.
- 2010 Fabia VRS rear hubs
Greetings from the South of France
Yup
Welcome to Briskoda. Good choice of car. Spent a very happy summer near Beziers a long time ago, teaching windsurfing on the beach.
1.4 TSI twincharger oil spec - VW 502.00 vs 504.00
Not those.
There's actually another pair of VW specs visible on erWin if you make a login and then click on the Approved oils link on the homepage. VW 508 88, and VW509 99. There are currently 19 oils showing as approved to these, all SAE 5W-40. I know nothing more about them nor the reason they exist; but to set off speculation, the genuine VW one is called 'maxi performance'. Perhaps they've taken note of what George has been telling us? Go to a Skoda parts counter and ask, maybe? Doubt they're cheap.
MOT Advisories, thoughts?
Check the OSR (and the fronts come to that), not unheard of for things to be noted down wrongly.
Skoda Fabia Air con fan cutting in then out
https://www.briskoda.net/forums/topic/404143-radiator-fan-repair-courtesy-of-vortex-here-and-uk-mkiv-forum/
The fan is twin speed, and the low speed function has failed. Common fault. Can be repairable with a large external resistor wired in, or more straightforwardly by fitting a new fan.
Primarily because @Rooted thinks it's better, and says it most days, I think. 😁
- Battery gone dead
This clamp is leaking on my 1.0 TSI - does anyone know the size?
Rear Central Locking Wiring Schematic
If you peel the rubber boot back from one or other of those ends, you're going to find a plug/socket connection, I feel. Item 2 here: Skoda Wiring Set For Door 5J6971161L - LLLParts
That's a mk2 schematic though?
Surprised by lack of connectors at B pillars. Photo?
F222 is lock module on rear left door, 223 the other side. T11 connectors are at B pillars. Circled numbers 76, 77 go to BCM inputs. All other circled numbers are earth points in looms (splices); or bolted earths to chassis metal. Look for broken wires or corrosion of connector contacts.
ABS sensor wire **** up!
Dunno, but some of these sensors are active/polarised, I seem to remember. Experiment if you're keen.
What year is the car?
One of them is black, yes? That came out of connector pin 1 (will be numbered somewhere, possibly wire entry side).
