Fuel tank pump relay switching power
Engine code or VIN will help a lot in answering this.
2007 Roomster 1.6 16v
I can probably figure it out with the VIN from the circuit diagrams, but it's not a 2 minute job, cos there are lots of different options with correspondingly different looms. No circuit diagram just starts with that connector and shows where everything goes from there, unfortunately.
Valve stem seals gone after head gasket repair
@Catherine41 Have we yet established which engine type this is? @xman asked, but I see no answer. If you can share the VIN or a photo of the engine bay we can see.
Petrol Fuel filter 1.4 16v change
Just in front of rear right wheel, inboard of sill, viewable from outside car, I think.
Nearside driveshaft part number ?
Have a look here, and send me your VIN if you can't find it: Car Parts Catalog - LLLParts
Skoda Mk1 Roomster - electric window not working
I guess you've not seen this?:
TSI engines
I know they exist, but where does it say the 1.0TSI in a Karoq has one?
TSI engines
Where did you see that info? Doesn't sound like reality to me.
Remote control for central locking
Not sure if this has been found by any of the recent posters here, but this is what I used to convert a key-in-door C/L Polo 9N3 to remote C/L a few years back: https://www.clubpolo.co.uk/topic/204921-guide-how-to-install-oem-remote-central-locking-in-a-polo-9n-with-original-parts/ Not sure what differences there are for mk2 Fabia, possibly not much at all for early, pre-facelift ones.
- Window motor repair service
Oil light flashing red
CAYC engine. Not heard much about oil pressure problems on them. @Crasher is probably someone with best experience and ideas.
SOLVED - Door open warning light on, (was not Door Latch Micro switch, was not Loom bellows, but it was the Window Motor/Door Module)
I've looked at a few of this version recently, and can confirm that under that connector seems to be where moisture is causing trouble, by corroding copper tracks and planes. Awkward to remove. I cut a slice of thick copper sheet that just fitted between the rows of pins on the bottom of the board, then wetted that to all the pins with solder and heated up until the connector dropped out. Could no doubt do it with hot air too, but might be tricky to avoid collateral damage.
- SOLVED - Door open warning light on, (was not Door Latch Micro switch, was not Loom bellows, but it was the Window Motor/Door Module)
Skoda Fabia MK2 exhaust manifold red glow....??? is that normal
I really don't know then, but if you do find out, please come back and update the thread, unlike the previous guy who said he'd solved his. 👍
- 69 replies
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
Check the chain timing by fitting crank and cam locking devices simultaneously.
- 69 replies
- 1
- 1.2mpi
- 3 cylinder
- fabia2
- skoda fabia
Tagged with:
- Can't get the cabin air filter replaced, Can't locate nor remove it
1.8TFSI 4x4 Springs
Yes, that is a VW group (genuine OEM) part number. Sometimes get better search results by removing the spaces. Both of the 0 characters are zeros. No idea who made the OE ones, sorry.
1.8TFSI 4x4 Springs
Yes, orange 1K0 411 105 DL Coil spring 4 colour strokes orange PR:L61
1.8TFSI 4x4 Springs
Might they be orange dots, rather than red? VIN would get me there quickest @Aumeisters
2021 Kodiaq RS - Towbar
rear springs
Just found these in my shed. Been waiting for one of the original springs at the back of our 05 Fabia to break for several years since I bought them off ebay.
Lane assist
- Real world mpg figures for 1.5 Monte Carlo
Go to spritmonitor.de where you'll probably find a fair bit of crowd-sourced data. Just need to pick a language and enter the details of the model of interest to you. - Real world mpg figures for 1.5 Monte Carlo
