Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Paint code of kodiaq
2008 Roomster Driver Door Connectors blocks
I even took pics, apparently. Different arrangement on the mk1 Fabia though, four separate male connectors within the overall black 'carrier', which - unlike yours - appears to itself have to be inserted from the outside. So on the Fabia it looks like the (4 individual) loom connectors get posted out through the hole, clipped into the back of the carrier and then that clipped into the hole from outside inwards.
I think that may be able to come out outwards, rather than having to be got at from inside the cabin (from mk1 Fabia experience). I was pleasantly surprised to find - for once - that there was even a few (2 or 3?) inches of slack in the cabling behind it. I don't really understand why it should be able to come out that way, 'cos it wouldn't be installed that way, but I distinctly remember doing it.
Run the ABS pump in Fabia vRS
Up to you, but bear in mind that the same workshop manual suggests in the context of rear shoe fitment: ❑ Cover the whole contact surface of the brake shoe with solid lubricant paste - G 000 650- I'd love to know how many apprentices have taken that the wrong way 😁
VCDS Lite (freeware) in its registered form (99USD) with a cheap FTDI/KKL cable (<£20) will do it I think; but there's really no need unless you know air has somehow been allowed into the ABS pump.
Front N/S Door Removal
However you manage to get the white bit out, you definitely want to refit the rubber boot to it before you fit it back in at the end of the job. It's a real struggle to get the boot properly onto it in-situ, but really easy when it's out with all the cables unplugged.
The white bit is intended to come out with the rubber boot still fitted to it, squeezing the vertical edges in towards each other should release the clips. Easier said than done TBF. Then there are individual release catches on each of the four connectors that you will have slightly better access to with boot and white surround pulled as far back as poss along the wiring.
Wiring Diagrams
I think the answer is that the front door modules are data-connected to/by the convenience CANbus; but the rear door window modules are only connected by single wire LIN bus to their respective/same-side front door modules. So although the rear may have all its wiring intact, if its same-side companion front door module isn't operational, it won't get command info from anywhere central.
Wiring Diagrams
Yes.
Flashing glow plug light - error code P0572 brake switch
There are two switches involved, one causing the brake lights to come on, the other one informing the engine ECU that the brakes are being applied. They're both in the same housing. The brake lights working doesn't prove that the other is, unfortunately. On your car I expect the switch(es) are on the underside of the brake master cylinder rather than at the pedal. The wire from the relevant switch going to the ECU may be a white/green one from pin 1 of the 4-way at the switch connector to ECU pin 21. Access is not easy, I believe, on RHD cars. I would be inspecting that wiring and connections prior to purchasing anything, if it were my car.
Alarm Issue
I'd be very surprised if it didn't.
car recommendation?
Private sale, sold as seen; I expect.
O2 sensor for Octavia 1 1.6L petrol
Same for both according to that ETKA page.
Is there a sticker on top of the cambelt cover? Or one in/near the spare wheel well. A photo of either of those would show it.
jars' 2005 Fabia vRS
Dunno what to say other than good luck on Friday, and look forward to hearing about the success soon after.
rear window roller
Good find, that'll be useful for more than just you I reckon.
rear window roller
The bottom of the door, probably. Any scrapyard mk1 Fabia, alternatively.
AnnoyingPentium's 2006 Fabia 1.2 12v Ambiente-ish
Maybe just leave it off rather than replace? That way it's already fixed.
I bet! The screws may be fun to remove, as at least one of them is quite hidden behind the drive flange/hub ISTR. Hard to get tools on. The screw heads have typically corroded to unrecognisable shapes.
Is that the stoneguard come away completely and made its way there? Item 6? floating caliper brake; brake caliper housing; bra... - Fabia(FAB) [EUROPA 2006 year] (7zap.com)
Your engine code is either AEH or AKL, your oxygen sensor should be part number 06A906262AK.
That's not your engine code, but I may be able to figure out what it is from that part number. Hang on while I look.
Front windows and mirror adjustment stopped working
There are surely more mk2 Fabias driving around with broken wiring than fully intact wiring in those door bellows. Proper cockup of a design those 'straight across' bellows.
Yep.
Have a look at fuse 11, and the black/blue wire from it via pin 7 of the 28-way at a-pillar. Thinner of the brown earths also possibly implicated.
Reduce speed limits to support Ukraine?
Blowhards should expect to be mocked, and bring it on themselves. Hope this helps.
