1.6tdi oil leak and notchy steering (related?)
Any chance the car has travelled a little sideways into a kerb in the last two weeks?
Sticking accelerator on '56 Fabia vRS
I didn't find any obvious problem with the one you kindly sent me Ryan. Didn't get round to trying it in my car, and realistically that may never happen.
Private sale or dealer?
clutch squealing
I don't think the noise matters to anything except your ears, but I suppose it might seize up completely one day. Bearing is cheap, labour to get to it - not at all cheap (same as for fitting new clutch, hence waiting til then). You have bigger fish to fry. Maybe another reason in favour of ditching this car?
clutch squealing
Fit a new release bearing if/when you ever need a new clutch.
Help! Catalytic converter and dpf Fabia 1.6tdi 77kw
Ta.
Just out of curiosity @JGrindel how do you know that the parts aren't the other way round, DPF first, cat after?
On? What's on?
- On? What's on?
Pull it out to connect the vent system into that little cubby. Keep something cool when/if A/C is on, warm if heating is on. Never used by most. Asked about by almost everyone.- Engine management light
Great advice. Genuine Skoda switch only around £15 I believe.- Engine management light
Good stuff. The fact that there were no hiccups with the emissions test suggests that the flexi was what was leading to the fault code/light, I should think. If those console bushes have not been done previously, they've lasted remarkably long, 20 years!- Engine management light
Actually, surprisingly perhaps, it doesn't matter if it's on, so don't worry too much. Just screenshot this and point it out to the tester if they try to fail your car for EML on. Your car is too old for the EML to be testable:- Electrical help please
Your electric windows are independent of any central control, only communicating between themselves (drivers and passenger side modules). On mk2 Fabias the most likely failure is wire breakage in the rubber bellows between front doors and A-pillars. If you've not checked both of those yet, that should be your first step. Does the car have radio remote central locking or only 'key in door' version? If the latter, a problem with window motor module on driver's side can affect central locking too. No idea about seatbelt warning.- Locking/Unlocking with key without remote control
Might be worth trying one of these repair kits: vw lock barrel repair kit: Search Result | eBay- Clutch Oddity
Two screws to remove to pull that cylinder out a little and see if there's any sign of leakage at the business end. If the problem hasn't happened again since the 'foot hook' I'd be inclined not to investigate further until it does though.- Recent pics of your fabia for no reason, just stick em up!
Leave the thread alone if it doesn't interest you, muppet.- best way to save my car
Wait and hope for 'Crasher' to reply, he's in the trade, so will have far more knowledge and experience of the options than I do.- best way to save my car
Dunno. If you had a known good head that they could swap on that would save a bunch of time, toing and froing etc, but I suspect they will be hard to find in guaranteed good condition.- best way to save my car
That doesn't surprise me. @Crasher might be kind enough to offer a view on relative costs of head refurb versus engine swap labour costs. I know that 'back in the day' there used to be repair kits for the 3-potters including whole new head, cat etc, for not that much money, not sure if that's true of the BZG generation?- HELP, Coolant leak after using the organic one!
Well, change the coolant and see if things improve. Much easier than changing the gasket!- best way to save my car
No, I mean they think the refurb will be more expensive than to swap in another engine. Maybe they just don't fancy the refurb job. Much easier to swap in another engine, in my opinion. Having just looked at the going rate for BZGs on ebay I'm a bit surprised by how much they go for (~£600+). There must be tons of them in scrapyards by now.- best way to save my car
Very dependent on local labour costs, so at least you're in the right half of the country. The fact that the garage suggested replacing engine rather than refurbishing the head is probably a clue though.- best way to save my car
You could get a quote for head refurb, but it will be a lot of money I fear.- HELP, Coolant leak after using the organic one!
So that's looking upwards towards the head/block joint? Looks like you need a new gasket if it is.- HELP, Coolant leak after using the organic one!
Where? - On? What's on?
