Breezy_Pete
Sponsor
  1. Ever-tighter particulates and NOx emissions targets have made fuel economy more and more difficult to achieve, especially with diesels. Shame really, cos obviously (real world) CO2 output goes up as fuel economy worsens.
  2. @Murdockman you seem to be talking about the mk1 Fabia console bushes, which @26DIPP might be needing but only if his daughter's mk2 is a very early one, they changed to the style Carlston showed very early in the mk2 history. Chassis numbers either side of the change are shown in the titles of the first two diagrams here front axle, steering Fabia (FAB) [EUROPA 2007 year] (7zap.com)
  3. Pretty sure I read somewhere - probably on Brisky - that the flushing involves a large number of iterations of fill, run around, drain.
  4. Wonder if much of it is made in Ukraine?
  5. Yes, I tend to agree sep, and had intended to say that, but failed.
  6. Possibility that Screwfix are adjusting their prices 'cos of an error, stock may return at a higher price? How long has it been 'super-cheap'? Or is the Toolstation price a lot more than the going rate? Doesn't seem that much to me, £2.20 per litre? How long would 10l last?
  7. Not sure what Screwfix were/are charging, but I tend to use Toolstation as an equivalent outlet for hardware: Redex AdBlue 10L | Toolstation
  8. UK market cars didn't get oil level warning sensors, so presumably what you saw was a red light and sonic warning, which is related to oil pressure, not level. Pressure switch is on the front of the head of the engine, close to the EGR valve, with a green plastic body (from memory), examine for oiliness, particularly within the single-wire electrical connector, as this has come 'through' the switch as the diaphragm fails, if you find such contamination. Wire breakage is another possibility.
  9. BBZ engine MAP sensor and PCV valve positions shown with red and blue arrows respectively:
  10. LCD display means Climatronic, which has the electronic module instead of the resistor pack to control fan speed. 6Q2907521A for RHD car, much more expensive than the resistor version. Not sure how to diagnose with certainty that this part is the problem, rather than the fan itself or even a sensor or the control unit. Climatronic has its own built in self-diagnostics - I believe - so maybe google or ask here how to run that and see if it can tell you anything useful.
  11. This looks like a repair loom for the job? Trim for the Glowplugs Škoda 038971782C (skoda-parts.com) Shipping cost may be high from that site though, so not necessarily the place to get one from.
  12. My favourite type of fix, a free one!
  13. Double-check the door open microswitch functions by leaving the lights on, remove ignition key and open driver's door. See if you get a warning tone 'lights left on'?
  14. I think you'll find the part number as indicated here, possibly minus the SK3 suffix (not always printed on the part number label, in my experience of other VAG models). Eyeball confirmation would be wise before spending.
  15. I wouldn't have thought a motor module change would need removal of that panel? A secondhand module with identical full part number, from a car of same age should be OK, I would've thought. What age is the car?
  16. Grand tour of local scrapyards seems like your only option, sadly; hoping to find a 'not too long ago replaced with new' one of these sensors. Or a new old stock one surfacing.
  17. Sounds believable to be honest. Are you 100% sure the sensor is what's wrong?
  18. You could test that hypothesis by unplugging the cable that goes to it and see if the same symptoms return.
  19. That's why I asked this question:
  20. Maybe try to find a secondhand (or new aftermarket?) LHD one going reasonably cheaply on e.g. ebay.de to experiment with? Definitely look at images first though, it may simply not fit.
  21. Looking at images of the 6q2 vs 6q1 parts may give clues about whether they can physically be mounted the same.
  22. I'm afraid your choices appear to be gambling on a secondhand part from scrappie/ebay, or hoping that the only difference between the LHD and RHD versions is the cable length. I'd not like to pioneer that route myself - certainly not on a £200 new one, but it could be that extending the cable of a LHD one may work? Beyond that you could replace whole rack with new style and fit the 'non-captive cable' sensor plus connecting loom. Lots of cost and effort.
  23. Do you want to retain/fix the alarm, or would you happy without it? Finding and removing the sounder will solve the problem if you're not bothered. I think there's no chance it'll be anything to do with the car battery.
  24. 2006 ETKA page relevantly cropped and highlighted. 3rd digit is what differentiates LHD/RHD, various other different characters for petrol/diesel/automatic/manual. I suspect a 56-plate vRS is going to have the 6Q2721503H variant, penultimate in list of '15' s.
