Breezy_Pete
Sponsor
  1. I've been expecting this news, sadly. Was this diagnosed by compression testing? Fitting a new engine is only really economically viable if you can do it yourself, and even then is a gamble unless you know the history of the donor car.
  2. Have you been using any fuel additives? Everything you need to know about lambda sensors - Garagewire "Fuel/Engine Additive Contamination Similar to anti-freeze, the sensor nose will be contaminated with white or red deposits."
  3. Well done. Let's hope this sensor lasts longer than the last one. What did the removed one look like? Any obvious damage/dirtiness?
  4. 1KJ for 286mm rears is there in the first row. Front brake PR codes likely not to be there, so much so that I won't bother double-checking.
  5. @rainford if a battery is EFB or AGM it is usually quite clearly marked as such on the top face. Can you post a photo of the top?
  6. P0171 is 'too lean' fault code I think, so most likely a vacuum leak somewhere. See if there's a little port/vent on the top rim of the PCV valve near the oil filler cap. Stick a finger over it with engine running and see if anything changes. How many miles on the car?
  7. Hmm, the shape of both bits looks quite different to me, making me think that what you have there probably is aftermarket, hence the lack of useful markings (and value).
  8. I'll dig out some photos in a bit of one I got fixed with a new flexi. Can't remember if there are any markings visible but the shapes may show similarities/differences.
  9. Well if you're not sure if the female thread is actually damaged, you should find that out first, just use the other (undamaged?) guide pin as a tester to see if it goes in OK and tightens up without slipping. The repair kits exist because this is such a common knob-up caused by failing to get the caliper back in position properly before starting to do up the guide pins.
  10. It'll be one of the numbers here, depending on chassis number, and manual/auto gearbox: Will you send me 10% of what you make? Might be aftermarket though if there are no VW group logos anywhere to be seen, in which case it's probably worth about £5 for both bits.
  11. You can buy repair kits for the threads, or fit a helicoil. I think the top four or five results here are the sort of thing that'll do the job. Considerably less work than replacing the whole shebang. m9 caliper repair: Search Result | eBay
  12. Have a look at that servo hose, and look at the sticker in the spare wheel well or service book for your engine code.
  13. Sounds like a good thing but actually indicates something's wrong. Is it an AZQ or BME engine code?
  14. Best full tank average on our 1.2/12v is a shade under 52mpg, long-term cumulative average over last ten years is 42. @nevsummer have you ever checked your brake servo vacuum hose for splits at the junctions of the hard plastic sections with the non-return valve. Possibility that your car is running lean. Do you have any means of scanning for fault codes?
  15. @TheWanderer, why not walk away now that you've had your say?
  16. Did you check the wiring inside the rubber boots on both front doors?
  17. Possibly some worn areas on the potentiometers such that the position signal is unreliable.
  18. Well ETKA confirms that I was 100% wrong about you changing the wrong thing, item 15, clearly described as V71, clearly described as recirc motor: evaporator housing; air distribution housing; evap... - Fabia(FAB) [EUROPA 2012 year] (7zap.com) Apologies for my confusion. As far as testing used motors, I can't suggest much beyond what you've tried, fit and test.
  19. I'm more wrong than I thought. Can't see V154 on Climatronic wiring diagram, only Climatic version, so you're probably right that it's called V71 in Climatronic, strangely. Still reckon two dead secondhand motors is very possible.
  20. I'm wrong too. V68 is the temperature flap motor. V71 is the one on climatronic systems that does vent selection.
  21. I think you may be wrong. V71 varies the ratio of cold/hot air in the heart of the system, not the external/internal air source selection, I think.
  22. Where is the one you're changing? In the middle of the car or at the end of the dashboard? Recirculation motor is at end of dashboard, V71 is near centreline, I think?
  23. Actually, hang on, recirculation motor is V154 isn't it? Have you replaced the right thing? Photo?
  24. One of the more common failures in Fabias, so chances of getting a working one secondhand quite low in my opinion.
