Breezy_Pete
Sponsor
  1. One of the more common failures in Fabias, so chances of getting a working one secondhand quite low in my opinion.
  2. With this being a mk2 Fabia, broken wire(s) in the front door wiring bellows would seem like the most likely explanation for the symptoms you're seeing, I think. Grey/white wire broken would be my guess.
  3. Most connector housings will have their part number somewhere on them, albeit often in tiny characters.
  4. VCDS Lite is the single most useful tool you can have.
  5. The only things that you'll need to do after the battery change is reset the time and reset the one-touch window opening/closing. Virtually any battery that physically fits, with +ve and -ve terminals in the same positions will do.
  6. Check cabin fuse 3 (5 amp). Did you never get VCDS and suitable cable?
  7. With window half open, gently try lifting the glass by hand near the rear of the pane. I think you'll find a lot of movement there compared to doing the same further forward. That'll be the rear slider broken, and the front one doing all the work.
  8. Check compression of all 3 cylinders and see if cylinder 1 looks low relative to the other two.
  9. A loose battery terminal is the simplest explanation for symptoms like these.
  10. Carefully grind a pair of flats onto the outside of the socket so you can spanner it round? Or molegrips straight on the socket if you have a pair that'll get in there?
  11. This (or equivalent from another factor) is probably what they will fit, and they will likely get it for a little less than this: React Catalytic Converter (Front) | Euro Car Parts Might be an idea to get another quote for fitting only if you supply? I wouldn't usually recommend that approach, but the labour/sundries that gets you from £108 to £260 seems a little OTT. They'll also get a few tens of pounds by recycling your old cat.
  12. It might be one of these - N 10104501 M7 x 18 12-point head. If so, try a 12 point 9mm socket for fit.N 10104501N 10104501 N 10104501
  13. VCDS Lite with cheap FT232 cable. Then you get numbers that look like workshop manual stuff.
  14. Or go to @Tech1e's uploads...
  15. Here you go: Note 15 says 'for AZQ engine'
  16. I will check the specs for the precat sensor in a little while, I think the expected number is quite strange, and your 1.299 is actually lower than it should be.
  17. Can you see the output voltage of the pre-cat sensor?
  18. So does this tool literally say "open loop operation" or "closed loop operation"? Or are you looking at pre-cat oxygen sensor voltage?
  19. What measure are you using to distinguish between open and closed loop operation?
  20. Can you see if there is a specific G62 temperature when it goes from misbehaving to being OK?
  21. Small prize for anyone who can show a VCDS logfile with G143 maintained at any point other than fully open or fully closed. 😁
  22. I'll have a look at those videos this evening if I don't have other stuff to do. I'll see if I have that SSP @J.R. The primary daftness with the recirc flap is the 'closing very time you select reverse' fanciness. Just serves to wear out the motor/pot/gears for such negligible benefit. Solved a problem that never really existed.
  23. The odd thing is that even on cars with A/C, the recirc flap is still only ever driven fully open or closed - to the best of my knowledge - so there's never any need for potentiometer feedback really. It's only the warm air/cold air flap motor that gets actively positioned at intermediate settings (as far as I understand, can't say I've ever monitored/seen it in action).
