Breezy_Pete
Sponsor
  1. Hi, I'll email you in a bit, just giving blood.
  2. A few on ebay, maybe see if any are within collecting range? 6q0 407 256 ac: Search Result | eBay
  3. Bunch of chancers. Fight hard for more money back and vote with your feet by never returning there again.
  4. You'll need to be more specific about the engine. There appears to be 5 possible 1.2 engines that you might have: Škoda Rapid (2012) - Wikipedia At least one of those has an oil cooler near the oil filter (item 13 here): LLLParts Is the car losing coolant?
  5. No date-code I can make out there, and no sign of a VAG part number either which there would be if OEM.
  6. Just noticed the improvised earth connection on the strut tower. You did scrape away paint down to bare steel under that crimp terminal before screwing that down, right? That'll be making a poor connection otherwise, as that screw is going into a threaded insert in the rubber top-mount, not some nice conductive material.
  7. I don't think so, but if there are any date-codes decipherable on them that would give a good clue. Keep the removed ones as spares, because at least one of them is probably fine. OEM are usually Eldor, I think. Was the first photo before you touched anything? Cyl 1 pack appears to be sat a few mm high of fully on?
  8. Level sensor isn't connected through the cap, it's just behind, in the main part of reservoir, see e.g. second pic here Skoda Fabia Brake Master Cylinder 1.6 Diesel CAYC 2013 | eBay Not sure if driving off without having released handbrake fully gives same warnings as OP experienced, I would suggest experimenting with that if - when checked - the brake fluid isn't very low. Clutch circuit fluid would only get changed with brake fluid if the garage/person who did it was quite thorough and bled at the clutch slave, which I doubt happens widely. Hasn't changed anything noticeable in brake or clutch function when I've changed out fluid, I'll say. Still worth doing if there's nothing recent in the service record about it.
  9. Thanks Lee. I suppose a missing 'executive summary' is that if you want one for a RHD mk1 Fabia, where the existing unit will have SK240DDRS as that bottom line of the label, get one that says exactly the same there, as well as the main 6Y2959802 part number. For LHD mk1 Fabia you'll want a 6Y1959801 instead, with SK240DDLS as that line. In both cases this only applies to later cars from approx July 2004 onwards, earlier cars will have parts with numbers starting 6Q, which have connector/wiring/functional/comms protocol differences that make them non-interchangeable.
  10. It's not that critical, just pump it up until it doesn't look 'soft' and squidged at the bottom. How long do you plan to drive around on it? Surely only 'til the normal tyre is repaired or replaced? A day or two?
  11. I would've thought it would be quite quick and easy to replace, after having removed any engine undercover which may be obstructing access. The two fasteners/screws that hold it in place may have been lost, but I'm sure any garage could find something usable kicking about.
  12. The part number on it confirms @J.R.'s idea 100%. 1j0407721g | eBay That (O/S) driveshaft will have been removed to improve access to the EGR.
  13. You need to obtain a Freedom membership before you can sell here. Link to the page where you can select one: Membership Options (Freedom) - BRISKODA
  14. I believe it's part of this chunk here, that all the heavy-gauge wires bolt to. Often the left-most stud, I think. (see if that wire goes to the alt.). If you have 12V on each of those studs I'd say the fuses are all intact. Careful not to short anything out while checking.
  15. Can you post a picture of the fusebox under the bonnet, including the face that's nearest the front of the car if poss.
  16. Adding this info to the thread as this thread comes fairly well up the google results when searching 6Y2959802: Some part numbering info that I have recently, I think, understood. There is much more info on this label than just in the 9-digit VW group part number at the top of the label. The key thing to note about that 6Yx95980x number is that on passenger side modules, the 3rd and 9th digit are always different, on driver's side modules they are always the same. You need a driver's side module on the driver's side! It's the master in the system. Suffix A (on this 6Y... series) after the 9th digit indicates a module made for a car with all four windows electric With reference to this photo, and the colour coding I've added to the bottom line, here is my best understanding so far of what this info means, and most or all of the variants you may see. The green box identifies the brand the module was made/programmed for. Always either SK for Skoda, or VW for Volkswagen. The three-numeral section underlined in orange is model identification. 240 for VW Polo and Skoda Fabia Mk1; 250 for Skoda Fabia Mk2, 258 for Skoda Roomster, and 750 for VW Transporter. The two letters underlined in blue are always either DD or PD. As far as I can see this always means Driver's Door and Passenger Door respectively. There may be a numeral 2 or 4 in between these two letters, 4 meaning all four windows are electric. Not sure what 2 indicates, it's often omitted as in the above photo. Might only appear on early examples. The last two characters underlined in red (RS or LS) indicate whether the module was made for a Right-Hand Drive car or Left-Hand Drive. "Right Steering" or "Left Steering" Hope this proves useful, comments welcome. Cheers, Pete
  17. Yes it is. Always numbered from engine to exhaust tip.
  18. Have you managed to loosen the fill plug OK? Best not to drain the box before making sure you can...
  19. Attempting it after a longish drive or after a hair dryer is applied to the general area for several minutes ought to help prior to any chiselling or similar. The alloy of the gearbox should expand quite a lot more than the steel plug.
  20. Remove fuse 20 and put your current meter in series with the contacts where it plugs in, see if there's half an Amp going through it. You could measure mV across its ends with it still in position if it's the fuse type that has exposed metal pads on the top surface, see here: https://www.briskoda.net/forums/topic/377587-technical-bulletin-about-parasitic-current-draw-measurement/ Measure all the other fuses if that one doesn't register any mV. I've personally found in a few cars I've looked at that 30 minutes is a good time to leave things to shut down, and that having doors open and car not locked doesn't matter. May well vary with model.
  21. Which engine and gearbox does the car have? Can you post a photo of the state of the plug,
  22. It will have 4. It's a hall effect sensor integrated with two 'virtual' switches to simulate the old pedal type. Check cabin fuse no.2 (5 amp), if your engine code is AZV or BKD. If it's neither of those, what is it?
  23. The switch you changed had 4 wires, right?
  24. Correction: I think @vindaloo's numbers should end 655 and 656 rather than 755/756?
