2006 Fabia vRS Near Side Rear Door Carrier 6Y0839751AR
Maybe this would be the way to go, rather than secondhand where the plastics will be old and possibly about to break?: SKODA FABIA WINDOW REGULATOR REPAIR KIT REAR LEFT N/S | eBay New genuine via @vindaloo's first part number will be around £70 from a dealer, I believe. New aftermarket of whole panel is probably another good solution if you can find one.
What happens if you charge a car with a '7kw on board charger', from a domestic 13 amp supply?
Selfishness seems to be a major problem with public charging, exacerbating lack of infrastructure. Is 2030 really far enough off, I wonder?
I think that's for electric rear window. What happened to your original?
2008 skoda fabia 1.4 starting issues,
No MAF on this engine, MAP sensor in the inlet manifold instead. Breather/PCV/PCV heater module is on the back of the block with a convoluted output hose up to the inlet mani just under the TB. Item 19 here: cylinder block with pistons; oil sump - Fabia(FAB) [EUROPA 2008 year] (7zap.com) Can get clogged up and cause overpressure/oil leakage elsewhere. Engine coolant temperature sensor is worth looking at if your 'little computer' can read that data from the engine ECU. If that's reading well down on reality it may cause overfuelling. The gauge in the cluster, if there even is one, is heavily 'sanitised' to read mid-range over a wide real range of temps, so can be misleading.
Help needed with engine pipe identification
- Help needed with engine pipe identification
This page randomly found shows the hose you want as a separate item (15) but also mentions referring to a TPI, so it sounds like there's a known issue: Volkswagen / Audi / Skoda Connecting Hose 04E133366EF - LLLParts That diagram also suggests that item 14 does include what you need. Suggest a chat with a Skoda parts counter person.- Help needed with engine pipe identification
I guess you mean the convoluted hose going to the purge valve? Not clear from the parts diagram whether item 14 includes the pipe/hose you want, as well as purge valve and other pipework. Google images for the suffix BE part don't help much: LLLParts- a few problems fabia mk1
No, just drop the lower dash trim and look at the part number on the control unit! Or buy a suitable cheap KKL cable and download VCDS Lite (freeware). Examples of cables on UK ebay: vw kkl | eBay- Wet footwells o/s drivers and rear on Skoda Fabia 06 mk1. When it rains car is soaking inside at footwells?? Please help.🙏🙏
There is a crap piece of design involved especially on the back doors, but it's not the seals. It's the brackets that allow the locks to come out with the assembly carriers (and back in). They actively divert water onto these carriers that would otherwise drip down the middle of the door harmlessly without challenging the carrier seal. You will see watermarks like this on any carrier that is removed, much more so on the rear doors as the quarterlight helps channel it exactly onto the bracket.- How much time do you warm-up your Felicia?
Breezy_Pete replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe wax thermostat (the thing you're pushing with your thumb) has a pin that comes out/extends as the wax melts, which will compress the spring and move the flap/clapet. In this application the wax will have a very low melting point, maybe around 20-30°C, so will soon extend the pin when there is a little warmed air around, and it will remain that way until it cools below that Unfortunately, as they age, they tend to lose wax, which means the pin extrudes less and less, leading to the flap not opening fully, or at all. I would think that in Greece, for most of the year, fixing the flap in the cold air only position will be best, unless you can demonstrate that this thermostat is working well.- Steering Wheel Clock Spring Repair Service
- Battery Options
Do you use the start/stop system, or habitually switch it off?- Fabia power steering problems?
Does your car have the Koyo, or TRW steering system?- Fabia power steering problems?
That user last visited the forum nearly 10 years ago Kharl, so I think the chances of an answer from them are poor. There was a change sometime from a sensor with an integral cable to one with a plug-in cable. You need the same type as you already have if replacing.- Does my car have a GPF?
Looks like it, yeah. Seems to be same thing as this Volkswagen / Audi / Seat / Skoda Exhaust Pipe With Catalyst<Br>And Particulate Filter 2Q0254502HX - LLLParts judging by the dual numbering in this ad: Partikkelfilter til VW Polo, 2017->> (Type VI) (2Q0 254 502 HX|2Q0131723), Motorkode: CHZL, DKLA, Girkode: SST (finndel.no)- My assisted power stering is not working properly
I seem to remember that your fusebox above the battery is a big mess? So maybe a bad contact or wrong fuse installed for the PAS?- a few problems fabia mk1
I keep meaning to do a Guide thread with pictures of the two units, their locations and functions; but never seem to get round to it. It doesn't help that there are so many names for each of them, some of which are very similar.- a few problems fabia mk1
VCDS autoscan will tell you the part number of the Onboard Supply Control unit (often confused with Central Convenience unit which isn't relevant here) at address 09 Central Electronics. Needs to start with 6Q0 or 6Q1 rather than 6Q2, I believe. e.g. (in first orange rectangle)- Dipped beam not working
- ABS sensor harness / loom - where does the other end join to?
Hello, On the basis that this page Flat Contact Housing, 2-pin Germany - OE producer 8T0973702 (skoda-parts.com) suggests 6E0973702 as an equivalent part number for the one you've found, I reckon this looks the part: VW AUDI VAG 2 Pin Connector ABS Speed Sensor 6E0973702 Pre-wired 6E0 973 702 780669637921 | eBay Tempted to get myself one as a standby TBH.- Bonnet stops / buffers
Can be slow delivering, but this lot will probably get you some at a good price https://www.lllparts.co.uk/en/- car issue but only for a second
Inlet manifold to PCV valve, inlet manifold to purge valve, inlet manifold to servo.- Coolant sensor location and radiator fan problem.
In the bottom hose connection area of the radiator, I think.- Fabia mk1 PCV valve
AWY and BMD never had one. AZQ always had, BME had one until end of 2005, then didn't.- car issue but only for a second
BZG engine ECU is powered via an ignition switched relay, so as far as it knows the battery is disconnected every time the ignition is switched off. Just. Saying. - Help needed with engine pipe identification
