Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Paint code of kodiaq
Oil Pressure Switch Malfunction
Part numbers for your engine shown as item 7s here: LLLParts
My favourite Youtube health video
Yes mate, cut down massively in a few stages. Almost within gov guidelines now! 😆 Weight continues to drop nicely, but more and more slowly as I run out of body fat to dump. Currently at about 13%, my target possibly a touch less but not much. Difficult to know how much of the weight loss is because of the booze reduction, and how much the other carbs; almost certainly a bit of both. Another video I can thoroughly recommend: Also recently enjoyed: Amazon.co.uk : drink david nutt
A need the code for the Plug 4-Pin of coolant sensor
Breezy_Pete replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman357919754 | eBay I think
Wipers act strangely - won't turn off
Must be the relay I think. Contacts welded themselves together so it's always on.
Octavia1.6tdi in limp mode after new glow plugs
No, it's a temperature sensor.
How to clean the catalytic converter with vcds?
forced regeneration diesel particulate filter vcds - YouTube Must be something useful in one of these videos?
Glow Plugs.
Seems to be the case, yes: LLLParts
Front passenger door handle
Both reported.
I'll take a guess that this means how to force a DPF regen with VCDS?
Oil Cooler on standard oil pump?
There's this one, by the oil filter (item 14) oil filter bracket; oil filter - Octavia(OCT) [EUROPA 2002 year] (7zap.com)
skoda fabia failed MOT on emissions
I think VCDS Lite does it, cos that's all I have. Engine ECU measuring block 033.
Could do with reading the voltage on precat sensor with VCDS instead to see if it's just that app which is reading it wrongly
Front passenger door deadlocked. Cannot open at all...
There are on ours! Item 35 here: door trim panels - Fabia(FAB) [EUROPA 2005 year] (7zap.com)
I was under the impression that the 3 screws at the bottom edge of the card were completely inaccessible with door shut, but a quick feel suggests they can be got at. Problem will be freeing the front quarter of the card as it overlaps the end of the dash quite a bit, with very little clearance. Destruction of some of the trim clips and fittings that hold them on the card seems likely.
On a traditional sensor, yes. On a wideband sensor, no. I posted the workshop manual info before, but here it is again, I think somewhere previously it mentioned a pre-requisite of the engine being up to temperature, but my experience is that it gets to the quoted number and maintains it from with a minute approx. of cold start. :
Mean. How would you take it off if you can't open the door? The only way I can see is destructively, so maybe buy a matching spare first?
Comfort module/voltage regulator issues
Vehicle voltage control unit is not the the thing on the alternator, it's a name that Skoda decided to call the Central Electronics control unit in early mk2 Fabia, (not the Central Convenience unit, that's another) Voltage regulator = part of alternator that should be keeping system voltage around 14.3V Vehicle voltage control unit = VCDS address 09 = J519 in wiring diagrams = Onboard supply control unit (what Skoda called it in mk1 Fabia) = BCM (name for it in later mk2s) = what I have pictured in linked post with burnt capacitor, it lives above the accelerator pedal on RHD cars, above clutch pedal on LHD. Central convenience unit is a different module (VCDS address 46; J393 in wiring diagrams) which lives nearer to the centreline of the car, it deals with locks and alarm mostly. I don't see any evidence for its involvement in your problems, unless I missed something.
Took me ages to find these pictures! https://www.briskoda.net/forums/topic/490993-fabia-vrs-wipers-not-working/?do=findComment&comment=5514418
Central convenience module isn't in that list of things supplied by fuse 22, but the suffix B version doesn't seem to be compatible with suffix A, judging by its non-appearance in the short list of equivalent part numbers here: https://www.skoda-parts.com/spare-part/5j0959433a-central-control-unit-24088.html I'd be tempted to extract the voltage control unit (the one I pictured above) from the car, open it and examine for any signs of damaged components. On the earlier versions (suffix C, D) there was a surface mount capacitor that sometimes seemed to burn out, and cause current drain problems. Maybe the suffix-F has inherited this genetic flaw.
Quick and dirty parasitic current measurement
That's why you flick the bonnet latch over, so the car sees it as shut.
Fabia Mk1 - Window Glass Attachment Clamp
Sure enough, new regulator with a full complement of intact runners has removed the up/down weirdness. What a grim job on later cars with riveted panels though. 😢
Helpful Video: Key Fob Battery Replacement
Haven't watched it but love Big Clive's other stuff. Does he mention cleaning the contacts that touch the battery while you're at it? Well worth doing in my recent experience, where just doing that fixed a fob that the new battery didn't.
Wideband ones tend to sit at a pretty solid, constant value, as they are controlling the fuelling accurately in real time to maintain lambda=1. I posted the expected value range upthread somewhere. No idea how or where you've measured a CO2 number from. CO is measured at MOT, not CO2, so it may not even be relevant.
How To: Centre Console Cup Holder
Nice one. I can't remember where I bought ours, but seem to remember it being around 40-odd quid; perhaps 6 or 7 years back. If you can buy a new one at all it looks like being hard to justify: 6Y0862531H47H - LLLParts
Drivers window. Up = Down . Down=Up
Not sure if you can get a view of the motor without full door card removal, but if you can, see if the VAG part number label is visible on that metal can around the motor. If it's facing the door and not visible, it's probably been accidentally switcherood.
