Both front electric windows stopped working
Depends on the balance of skills versus richness/ poorness. I'd repair, personally. Lots of kits to do so on ebay. fabia door loom repair | eBay
Maybe; the mk2 has an unfortunate design here where the wires go straight across from body to door, so they must bend/straighten every time the door is moved. On the Mk1 there's a vertical dogleg in the boot, so the principal movement of the loom is a twist rather than a bend, which seems to result in far fewer problems. Intermittent problem makes it less likely to be a broken wire though.
Intermittent, or stone dead? Door bellows wiring is a prime suspect on mk2s
Following a little research on the last page of the Fabia Guides section, it seems Model Year 2005 was probably the start of the use of the new-style (6Y...part numbers) window motor modules, as it started on 2nd August 2004. That fits with the July/August 2004 change info in ETKA. The last MY2004 car went out of the factory on 31st July; probably with the old style modules. You can look up your production date from VIN, to within less than a month, using these threads and the pdfs contained. Tenth digit of your VIN is the Model Year number. 4=2004, 5=2005, obviously.
Maybe there was a gap in production, so none were actually made in August/Sept 2004? Is summer shutdown a thing in Skoda factories? Got a feeling it might be.
Probably; it's odd Ryan, if you look at ETKA for part numbers, the changeover is between July and August 2004, but if you look at the circuit diagrams, the change comes at start of October 2004? When was the facelift exactly, please?
What year was your Fabia built @tbuccetti? There are two different types of window motor modules, the changeover was sometime between July and October 2004 I believe, They aren't interchangeable due to different connector arrangements, and different communications, CAN-based on earlier cars with modules having part numbers starting 6Q, LIN-based on the later cars with modules of part number 6Y...
Nothing amiss?
The clips (which are rivetted to/ part of the pads so hard not to change with the pads!) were probably just a lot less shiny on the old pads, so not so noticeable. Good news is they've put that one in the right place, as an outer pad. There are subtle differences between clips on inner and outer. This image shows an inner pad on the left, and an outer on the right.
Looking for schematics of the cabling distribution of the canbus
The HVAC module is on the convenience CAN bus isn't it? I don't know my way round a Yeti, but that ought to be close by?
When was the car made?
Windows issue
The main power fuse (and the contacts in the fusebox) for the passenger window module would be good to check if not already examined.
Windows issue
Don't think it'll help actually. A 54-reg mk1 is likely to have the system where the two (driver's and passenger side) modules communicate with one another, but nothing central, including the diagnostics. Effectively invisible to VCDS. @Jamesmaher63, it's not clear to me whether you previously replaced the driver's side regulator (wires and mechanism) or motor module? Please clarify. It also sounds like you may just need to reset the one-touch function on driver's side as it is actually moving the window? I wonder if the single comms wire from driver's side module to passenger side one is busted? The result of sep's suggested test will be useful info.
Handbrake issues
Phone a UK VW/Skoda dealer for a price. Should be ballpark 50p each, e.g. Volkswagen / Audi / Seat / Skoda Glide Piece 6N0609589 - LLLParts
2009 superb front coil spring part number
If the springs on the car are the factory originals they will have a sequence of paint marks on them. This is the key to working out the part number.
Thoughts please - Skoda Yeti 1.2TSI Battery Replacement - Factory fitted Battery is non stop start.
@TruckbusUK If you follow the ebay link I posted earlier, you'll see that genuine batteries are indeed sometimes Exide branded. Another example here, with VWAG engraved near the negative post and the VWAG part number top right. REMK UP CITIGO AKUMULATOR 1S0915105A 59Ah 320A EFB - 7651917745 - oficjalne archiwum Allegro Maybe the OP could look at his negative (battery!) post and see if it has a date code engraved on the top like in the 2nd image of that latest link?
MK1 Fabia - Replacing the front window regulator
I think it may be just you, worked fine for me two seconds ago.
My personal opinion is that if the replacement is also an EFB type, and the capacity (Ah) figure is the same or similar, coding will be inessential.
Wait, this sentence seems to have a contradiction in it. I've italicised the two bits that conflict. An EFB is a start stop type of battery, albeit the cheaper version.
Does it not say "EFB" somewhere not far from the +ve terminal, like the one in this image: Genuine Volkswagen Battery 640 Amp 1S0915105A for sale online | eBay
Fabia 2 VRS - Door Lock Wiring diagram
Mend the broken ones, or all. Lots of kits on ebay.
One or more busted wires in the door bellows, surely.
Power Steering / Electrical Issue, code 01288.
Steering pump/reservoir is shown in the yellow box here. Access is good with front bumper removed. The main permanent power connector is the one with the two fat wires in the middle, red goes up to one of the strip fuses in the fuseholder above battery, brown earth wire goes to the stud arrowed in brown.
What is this sound (video)? cv joint, drive shaft....
When you say low oil light, is that a yellow warning light? MK1 Fabias sold in the UK market didn't get oil level sensors, so they're not much discussed here.
Service message just a coincidence, I think, as long as you don't mean a low oil pressure red light? CV joint and whole driveshaft part numbers can be found on this page. Filter by engine code ASY in the 'data model' column. View on computer, not phone to see all of the info: drive shaft; for manual gearbox - Fabia(FAB) [EUROPA 2002 year] (7zap.com) Inner (and outer?) CV joints appear to the same part number on the ASY as on both of the 1.2 engine codes AWY, AZQ.
Can anyone think why the fuel pipe clip here would have been removed?
Oh, for some reason I'd got the idea it had just had this service very recently.
