- Poor aircon effect
Any good guides for a Timing Belt change for a CJZD, 1.2TSI 81kW
First you register and login. Then from the homepage drop the Individual Vehicle Information tab down and pick Repair Information; then choose your model (Fabia 3). Then pick Info Medium = Repair manuals; then choose Power Transmission, then the one(s) you need, the fifth one in the list for your engine in a mk3 Fabia by the looks of it. Click on that link then you'll see a button that says Order flat rate, go there and pay your money and then you'll get a download button for that pdf. Can't remember if you have to navigate back to that page or it just appears with the download button.
I'm surprised there's nothing helpful there. You can get the official workshop manual for your engine via erWin Skoda for under a tenner. Not quite as user friendly as Haynes but should be reliable info.
Have you tried YouTube?
citigo 2019 service
What a bunch of crooks.
Roof Box - Maximum Size
Perhaps the OP could comment on likely weight of roof box contents, so we know if there's any relevance.
Nobody asked for advice about heavy loads on the roof, it's merely size being asked about. Just saying.
Fabia BBZ problems
I don't know if that's possible. If the engine really did overheat due to fan malfunction or water pump problem, you would lose coolant from the expansion tank I think, as the pressure would cause the cap to release steam. Is that happening?
Fabia BBZ problems
Now I'm on a big screen I can say that if the car has A/C then battery fusebox fuse 9 (5 Amp blade fuse) supplies an ignition switched 12V to the fan control module (pin 1 of the 6-way connector). Battery fusebox blade fuse number 8 (30 Amp) powers the low speed fans' function via one of the fan control module's relays, in on pin 3 of the 4-way connector, out on pin 2. Strip fuse number 3 (40A) powers high speed fan function via the other relay inside the module, in on pin 1 out on pin 4 of the 4-way. Earth connections to both fans are directly from the 3-way rectangular connectors nearest the fan motors, to a chassis earth point nearby.
Fabia BBZ problems
Does the car have air conditioning?
Fabia BBZ problems
The thin strip fuses, yes, but there are also a few more further over, under a cover that unclips. You can see wires going to them, but not the fuses until the cover is removed towards the firewall.
Fabia BBZ problems
The ones above the battery, including the blade fuses that hide under a plastic cover?
How do I advertise selling a car
You need to have a paid 'Freedom' membership to post in the for sale/classifieds area.
Fabia BBZ problems
The first thing to check is the relevant fuses. I can look up which those are a little later for you. Another thing to be aware of is that the fans shouldn't come on until the coolant at the thermoswitch is above 96C, and the thermoswitch is after the radiator in flow terms.
Emission light coming on.
What's the fault code that the garage have read?
Immobiliser or starter problem?
Check the starter solenoid wire, just where it goes into the single pin connector housing. I suspect you'll find it's almost or actually broken.
throttle body removal
Good news, well done. Bet it feels good having fixed it yourself too.
Find the nearest VCDS owner who preferably has experience of similar engines to yours.
VCDS owners MAP - Diagnostics & VCDS - BRISKODA
The green ring is what (and all) it should have on your car. If the TB has been removed, it is possible that it's not been put back properly and is now leaking past the ring. There are two locating pegs that go into holes in the alloy of the TB. These holes can furr up with oxide over time making the TB hard to remove and hard to replace properly. Cleaning this oxide away so the locating pegs fit in easily is the answer. Make sure the four mounting screws go back into the original threads in the plastic too, by turning them anticlockwise until they drop into the existing thread, then doing them up.
Help! 69 plate 1.0 TSI SE manual clutch gone after 2721 miles!!!!
Independent inspector sounds like an excellent move to me.
Fabia 2 electrical problem
Good plan. Makes footwell-based work far easier, and takes very little time to do. Make sure you use the correct XZN bit, they're not Torx.
Best climate control setting for driving through a Coronavirus hotspot?
Recirc mode must be better as long as switched on before hot zone.
What's your location? Doesn't look like many wires involved.
Skoda Fabia Combi should I buy ?
That's a great recommendation, and I agree. @Lando98 there are two different versions of the 1.4/16v, a 75bhp one and a 100bhp. Most manual gearbox Fabias in the UK have the 100bhp, all of the automatic ones have the 75bhp. Basically the same engine, some minor hardware differences and different mapping in the ECU. As said, one of the best petrol engines in the mk1.
