Kamiq 1.5 Petrol starting issue
Oh yeah, wonder if it was petrol though.
Any refuelling occur?
Tempting to imagine that this problem was why the previous owner offloaded it. Might indicate potential for a frustrating time if retained.
The dreaded same old faults...
Since some of the lock module signals connect to/through the window motor module, and could be corrupted by faults within that, see what happens if you unplug the window motor. If lock activity calms down, consider acquiring and test-fitting a replacement window motor module. I have a suitable item available, let me know if you might like it to try.
Central locking question Fabia mk2
Extremely common. Good practice to take off the battery negative clamp before such work, yes.
Check for broken wires inside the bellows at the A-pillar.
how do I remove the starter motor "top bolt" (the one that the gnd strap connects on to)? 1.4l 16v
I think a manual 1.4/16v will have an 02T family box. From memory it's a 13mm nut that holds the change lever down on its splined post. (May be bigger, memory not really trustworthy). It only fits in one orientation too, again from memory, so need need to mark alignment.
Even if you can loosen both of the 18mm-head bolts, you'll need to remove the gearbox linkage top bit to get the top bolt out, I think. So you may as well remove that first to improve access.
18mm is correct, I believe, for the long starter motor bolt heads. The one that has the M8 stud coming out of it will need a ring spanner or deep socket. You've checked that the non-crank isn't the usual broken, or nearly broken solenoid wire?
Part number request
5Q0907643D, superseded by 5Q0907643E (£88.80 + VAT at Skoda).
Brake lights works even when ignition is off
It's normal and I doubt it's alterable. Won't flatten the battery unless the brake pedal is pushed continuously.
Tyre Pressure system on Mark 2 - question
Standard valve.
Issues with Key after battery replacement
I wasn't asking what it was, I was showing you what Alasdair meant, but which you thought would be soldered to, or part of the PCB. So look for it in the fob and see whether it looks damaged or absent.
2014 Octavia Mk3 RS - Does mine have an alarm?
Message me with the VIN if you would like me to check via the car data (this evening).
I think the part Alasdair is referring to is this, which has no electrical connection to anything in the fob. Known as ID48, "immobiliser chip", or "bugger, that was fragile" depending on the circumstances. I'm not sure if a 2017 keyfob still has such a device.
2017 MIB 2 Screen retrofit 5E0 919 605 M
The current requirement to have posted 20 times before outbound personal messaging becomes available to new members is a bit of an obstacle in this situation.
2012 Skoda fabia greenline 1.2 TDi
Photo quality is too poor to even see if that's a cam belt or an auxiliary belt.
How to find engine code for waterpump/timing belt replacement
This reg has a BUD engine. Belt kit (not inc WP) is part number 036198119C. Part number for genuine water pump is 036121008M.
- Fabia Mk1 electric window problem
Something that works briefly after an intervention such as a blast of heat doesn't necessarily demonstrate something that will keep working. Passenger window will work independently from its own switch for a short time after each time it's powered up/reconnected. Not evidence of comms from driver's module.
