Breezy_Pete
Sponsor
Joined
Last visited
Currently
Viewing Topic: Cairus's Leon FR
Radiator Fan Relay
That VIN gives the part number(s) shown in this ebay listing for your fan. I've highlighted the four-way connection block. Two high current wires, two slim ones. Look for this arrangement on your car to confirm. Circuit shows J293 radiator fan control unit, and radiator fan V7 as a single schematic block. Optionally with a second 'daughter' fan powered from it too. Fuses involved are a 50 Amp fuse in fuseholder A position 5, the rightmost fuse with wire coming off it, front of engine bay fusebox (permanent power feed for fan) as well as the one you have already identified which is more of a 'wake up we're running' feed. The other wire on pin 3 of the pictured connector is from engine ECU, the control feed for the fan module. This ebay listing was just used for a quick screengrab, not as a recommendation of where to buy from.
L&K rear coil springs...
I offered to help with this but you posted something almost at the same moment, and maybe didn't see? Just message me with the VIN.
1.5tsi ACT cambelt change interval revision?
It means there is no replacement interval defined by Skoda. Unless you live in a dust rich environment. Not too sure why that makes s difference, since the belt is fully enclosed.
I can look up part number with VIN, but expect I'll see same answer.
It should be interpreted that they are looking at a table similar to the one that Ootohere posted a little further up this page, and they are looking at replacement interval for toothed belt on a petrol engine in a non-dusty country and seeing a - (like there is in that table for Karoq), which means there is no recommendation for replacement.
Wiring diagram for the windows in a Mk2 1.4TDI Fabia
Yellow/blue wire from pin 5 of the 10-way connector at lock module, to pin 3 of the 16-way at front window motors. Confusing symptoms. The fact that the rear windows open/close OK via key in driver's door proves that the LIN connection from driver's side (master) module is intact to those two (slave) motors, I think. Also proves that driver's side module is correctly receiving and passing on the door lock key position status. Strange that the front windows are not responding. Check LIN connection to passenger front motor particularly, I think. Are all four motors the factory fitted originals, as far as you know? Is there a keyhole in passenger front door? If so what happens if you command global opening/closing from there? Will send you a private message shortly.
Yes, BCM has no data comms with any of the window motors. All it gets is an input from the door open microswitches on the lock modules- which also go to the window motors - no other involvement. I will try to grab some circuits. VIN would be useful to pin down build date precisely.
Octavia MK2 Timing belt change advice
And that's exactly what you'll get here too. 😁 I'd leave it another few years if it was mine.
Data line is the grey/white wire labelled LIN. It goes into the main body wiring loom at pin 5 of each of the 28-way A-pillar connections (T28a, T28b). Rear door motors will have the same colour LIN wires commoned into the same bus connection. On this and previous generation of motors the LIN connection is purely between the two or four window motors, not to any central module. What is and isn't working with the windows?
Battery discharge - fuse 39?
OK, with correct VIN I'm now seeing 1K8 951 605B as the installed part number, now superseded by 1K0 951 605F; RRP is £215 + VAT. LLL look remarkably good value compared with Dealership prices, as usual: Volkswagen / Audi / Seat / Skoda Electronic Siren 1K0951605F - LLLParts
Edit. Ignore previous version here. Wrong VIN pasted.
Car is not starting
On earlier Fabias, silent non-crank non-start was/is often caused by breakage of the starter solenoid wire adjacent to the connector where it goes onto the solenoid. Not sure which angle it might be visible from on a mk2 1.2 TSI, possibly easier to see from below.
Changing AGM battery from one with 650 CCA to 750 CCA do I need to get car recoded
Yes, same capacity, same technology (AGM), so least chance of any problems. Doom-mongers may be along soon to tell you that the battery management system will start damaging it immediately by treating it like the old battery (whatever that means) but I suspect most of that is unfounded in reality.
The Amp hour capacity is the relevant number in this context. I see the replacement is rated at 60Ah, but can't tell what the current one is from the info given. If the capacity is the same, or very near, there's less reason to bother coding anything.
Nominal charging voltage 1.2TSI ?
VCDS is available from a few distributors in the UK. I've used Ilexa.co.uk recently and found them excellent.
To my disappointment I saw the voltage across batt terminals dip to 13.8 in that last high-load condition at warm idle, popped up just above 14 with a few revs. Room for improvement there.
Roomster running again so I had a quick look at VCDS on the alternator load subject. Initially found - by searching - a measuring block entry called 'alternator load' but that read 0 no matter what. Then just looked down the looong list of advanced measuring values until I spotted 'generator load'. That's the one. First pic, just radio and blower on 1. Second pic, radio plus blower fan on max. Third pic headlights added. I'll pop out in a bit and measure voltage across battery posts in last condition, like I should have done at the time!
@briscaF1 Anyone near you with VCDS? Are you anywhere near me? Swindon or Oxford? 70K does sound low for worn brushes, I would agree. Nevertheless it would be interesting to see what the alt load is showing at idle.
Trust me. Can your OBD diagnostic thing look at measured values of things in real time? If so try to find a channel in engine ECU that shows alternator load percentage. (I'd look up which using VCDS on our Roomy, but it's in bits while I change the front pipe at the moment). Monitor at idle and higher rpm. It shouldn't max out at idle and cause the output voltage to be pulled down, unless you have a lot of loads switched on.
What do you mean by CM?
Voltage regulator should make the output voltage independent of rpm, so not sure what's going on there. Suggests that alt isn't able to output enough current at low revs to maintain its setpoint, with minimal load. Possible indication of too-short carbon brushes. What mileage on car?
Spec sheet of the aftermarket version of the voltage regulator on these alts: ARE3010 | Alternator regulators Voltage set point is 14.5V.
Measure directly at the alternator to see if there are any losses in the connections between it and battery. Red meter probe on alternator output stud (careful not to short to any nearby earthed metal), and black probe on alternator body. Compare with reading across battery poles in same conditions. There's a temperature dependency which means the value at alt should lower a bit as the engine (and so the alternator) get warm. Yes, those numbers you quote are the nominal territory to be expected.
air con blower
Nice one.
Crank, no start; very jerky crank though...
Oh, no. It was a very destructive, hacksaw job to get in deep enough to even see what type of motor was in there. One of the options offered by GSF was just the pump part of the overall assembly - described as 'fuel pump swirlpot', but even that would be too much hassle for me to get involved with while there was an open petrol fuel tank, something you need to be very careful of and get closed again as fast as possible. Full, drop-in, pump plus sender was about £90 after discount. Various, unbranded aftermarket ones are on ebay for around half that. I needed a same day solution though. ECP had one at £214 which didn't tempt me at all! 😆
