PCV valve? 2011 1.2TSI 105 BHP FABIA 2.
Sorry for delay, PM replied to. Looks like you may have a non-standard arrangement there.
I'll start a private message conversation with you in a sec. Would be good to know reg or VIN in order to look up correctly part. 🙂
I'm wondering if there's a different version that goes with DSG gearbox, does your car have that?
Reset Trip Recorder
The way to get a message to admin is to tap the 3 dots in top right of one of your posts. Then choose 'report post' then select the relevant option. In this case 'posted in wrong forum'. You can then help them out by specifying the correct forum.
Oxygen Sensor problems - P2237 error code
The oil can come from elsewhere, wicking along in the spaces between wire strands, within insulation; counterintuitively. Coolant can end up in strange places by the same mechanism. Just thought it was worth mentioning, cos I had noticed oil in the sensor connectors on mine but hadn't thought it would matter, until I saw that bulletin and found that it really does!
Fuel guage showing full all the time? Mk1 fabia 1.2htp
VCDS Lite, free download from ross-tech.com plus a cheap generic KKL cable works for most stuff on mk1 Fabia, and even mk2 up to early 2010.
The reason I ask is from recent frustrating experience of a wideband sensor fault on our Roomster. Eventually, I found this, which solved it once I had replaced the worst affected bit of wiring and connector on the car loom side. See https://www.ngkpartfinder.co.uk/assets/Uploads/Sensor-oil-contamination-ver2.pdf
If you have VCDS you can probably see fuel level in measuring blocks of module 17 (instruments). You could then see if that changes if you jack up the rear of the vehicle.
Any sign of oiliness within the plug/socket connection of the oxygen sensor?
Might be a dry joint on the cluster circuitboard, where the input from the sender potentiometer comes in. Not sure if open circuit would give a full or empty reading, but probably one or the other. Pin 15 springs to mind, but memory isn't to be relied on.
- Power steering failure
Torque To Yield Subframe Bolts?
It's not super-clear, but from my experience on mk1 Fabia platform, you have an 8 each side, a 6 each side and two 5s each side?
Go here, use ctrl-f to find the various pages for 'assembly carrier', then pick the right diagram depending on your engine code. The bolts may be the same for all, dunno. Car Parts Catalog - LLLParts
Alarming news : no alarm in Octavia 20-21 ?
Our 05 Fabia doesn't, but you may regard that as something silly. This thread revealed a much more recent Skoda example: https://www.briskoda.net/forums/topic/529835-missing-anti-theft-fuses/
Would need to know the VIN to check. It may well be that some markets didn't fit an alarm as standard, but it would surprise me a lot if no Octies at all had alarms over that period.
EA211 1.2 TSI Engine Mount Bolts
I wouldn't be afraid of re-using the existing bolts, if this is the first timing belt change. I wouldn't be so happy to use them again if I knew that they had been out and back in again once (or more) times already. A Skoda dealer may be not as expensive as you think for these items, for example, for items 18, (19) and 19, the recommended prices in the UK are about £2, £5, £3 each, plus tax, so for the quantities required of those ones, you would expect to pay about £23 including tax at a UK Skoda parts counter. Approximately £12 for the 3 horizontal ones; if I'm correct about those.
Not surprised you were finding it hard to identify the correct items. Not super-obvious even with VIN filtering. The ones labelled 4, 6, 7 in the top part of your diagram are easier, corresponding to items 18, (19) and 19 here: The horizontal ones attaching console (20) to engine are a bit more confusing: Slightly less weird when you notice that items 20C and (21) are the same part number. If there are three screws (item 2 in your image) with two long and one short, I guess you have to get two of the M10x75 and one of the M10x55mm? The greyed out items don't suit your VIN.
Please help with Coolant temperature sensor problems
Excellent, thanks for showing us the damaged area.
Could also be that the original sensor suffered a perforation failure which caused coolant to go into the connector pins, and may now have travelled along the strands of the wires to the ECU connector. If you find wetness at pins 52/53 you will know for sure.
@Samoht26 on your car there is a G83 as well as G62. G83 is described as Coolant temperature sender at radiator outlet, so I guess it is near the bottom hose connection to the radiator. Wiring to each is as follows: G62 pin 1 red/grey wire to engine ECU pin 52 of the 60-way connector G62 pin 2 brown/grey wire to engine ECU pin 53 of the 60-way connector G83 pin 1 yellow wire to engine ECU pin 37 of the 60-way connector G83 pin 2 brown wire to engine ECU pin 38 of the 60-way connector Is there any sign of wetness inside the loom plug for G62? Let me know if a pin diagram of engine ECU connectors is useful, although they are usually marked on the mating face, I think.
PCV Valve gasket fell in
Well done, good result. No, I wouldn't worry about what is left. It will probably end up in the sump soon, may come out with the next oil change.
Leaking fluid from engine mount
Managed to magnify your second image to see that the part number fitted is 2Q0199262BJ, which is a current (not superseded) part number retailing at £192 + VAT. No indication in the parts catalogue that it is RHD-specific. Are you certain that the fluid isn't coolant, from the reservoir that seems to be immediately above that area?
My A4 had a hydraulic engine mount one side. It had an electric valve that controlled its stiffness depending on operating conditions. It had leaked too.
Or just miscommunication, left side engine mount rather than LHD? Pictured one being right side.
