Everything posted by SteveTheElder
Photography Thread
Skoda Connect site shutting down email
Seems odd that released today is an update to the My Škoda Essentials app (iOS).
- Slow reaction from front parking sensors
Electric Park brake malfunction
Crikey! I'm all in favour of strong passwords, TFA, etc but that seems a bit OTT to change a set of disk pads. Guessing it must be to do with the overall capability of ODIS type systems.
Automatic headlight adjustment for driving in mainland Europe
If you have the standard LED headlights as I do, then no, there is no automatic adjustment. That is, I believe, only available with Matrix headlights (or Full LED headlights as described in my car manual). I have used the Eurolights deflectors on mine but they are a real fiddle to get in the right place. Last but one trip I noticed that they were not doing the job - moved them down no more than 4mm and were fine. Snag is, they fell off the next day cos the glue had lost the stickiness - and I didn't get of photo of them in the right place 🙄. I just lowered the beam height instead so as not to dazzle oncoming traffic.
TICO
Also, IIRC, the mileage is displayed briefly in the Virtual Cockpit (behind the steering wheel) after turning off the engine.
Octavia iV High Speed Handling
I've had my 1.5 SEL FE Estate for over 3 years now and yes, it can feel a bit floaty at times. I've put it down to the suspension compensating for high tyre pressures; the recommended pressures are a lot higher than on my previous Škodas (2012 Mk2 Octavia, 2014 Mk2 Superb) - I might be wrong in my assumption here. Not noticed any dive to the right over bumps at high speed but I did read, in another thread, of a number of cases where nearside shock absorbers were a bit iffy. Sadly I can't find that thread at the mo but could be worth getting your shocks checked out.
HAD ENOUGH
Thanks for clarifying that
Update to Version 1969
Version 1969 refers to the software version of the Infotainment system. Since launch, Mk4 Octavias have had issues with the system. 1969 is the latest; 1941 was the version that stabilised a whole load of stuff, notable repeated reboots of the system after starting the car. Do you need to do anything? Arguably, only if you have issues with your car; and then, if under [extended?] warranty still, ideally get your dealer to update it and check for other updates whilst they're at it.
HAD ENOUGH
The SW could be updated to 1941 or later without the SOS module - but not all cars have had that issue. I guess there was a dodgy batch of units that got installed in some cars whilst good units got built in to others on a parallel build track. Mine has hardware H56 and is fine, performance of the Infotainment system is good too, was notably/frustratingly slow early on, seems the Škoda code writers found a way of streamlining it. Make sure that all this tech stuff is covered by the warranty, which IIRC it will be with an Škoda Approved Used vehicle - but you'd best check rather than take my word for it.
HAD ENOUGH
Yes, there are fixes for the issues in earlier cars, I've lost count of the number of hardware and software updates mine has had! But as @PoloPaul mentions after the update to SW 1941 all is good. The version prior to that had some issues (repeated reboots of the infotainment system); other than that mine has been fine for quite a while. The challenge is making sure that ALL the possible updates are applied to the particular vehicle you're interested in. Building good rapport with the local dealer Service Dept is useful essential in this regard. I got very close to the point of rejecting mine but it was the rapport with the service dept that helped me through - and I'm very pleased I stuck with it. It's a very practical, comfortable and economic car. I love it. There are others here in the Mk4 forum with recent cars which don't have the issues of earlier builds - other than needing the update to SW1941. Thus I reckon you can be confident the car will be fine subject to the updates being applied.
Hello! 2024 Octavia SEL 1.5e Estate
Welcome to your new Octavia. Hoping you enjoy it as much as I do mine, also in Petrol Blue - IMO the best colour for the car.
Infotainment System Restarting endlessly
Prior to update to 1941 (dealer, last July) the Infotainment System in mine would reboot several times each time I started a journey. I'm a CarPlay user so wasn't only an AA issue. Thankfully, since 1941 no problems.
Octavia iV Estate - no power - red blinking break lights
There might be something useful in this thread...
Learner drivers - will newly proposed UK rules become law?
Must admit I expect it will become law but I doubt it will make any difference. What is needed is better enforcement of current laws - driving dangerously, irresponsibly, drunk, etc is just that whether you're a new driver or not.
- 2068282 Digital instrument panel (FPK) - flickering indicator
If you can try recording a video of the symptoms and share it with the dealer, that way that have evidence to justify warranty work which might help.
Where has Apple CarPlay gone?
Sounds like the Home Screen(s) have been reset, possibly due to an update of maybe a bit of a glitch in the user profile. Sometimes if the iPhone doesn't connect the CarPlay icon/app appears as SmartLink. Use that instead and reconnect the phone. If that's not the issue, the you should be able to edit the home screens, a long press should bring up the edit screens where you can add and remove elements, and create additional screens. CarPlay and/or SmartLink should be available in there. All that typed from memory, hopefully I got it close enough...
Seat Position Linked to Key / User Profile Not Working
I've occasionally had one or other key lose its association with the seat memory; could well have been related to a major s/ware update but hasn't been for all big updates. As yet I haven't updated to 1969, its working happily on 1941.
MySkoda (Essentials): No longer providing either data or control
I can only assume it’s Android specific, works fine on my iPhone. Is the web portal ok for your car/account? If so, perhaps reset the app or reinstall it.
20mph speed limits in Wales deemed as very unpopular.
I certainly agree the 20mph limit needed reverting on some (many?) of the roads. But what annoyed me was the reported rationale for changing back was [paraphrased] ‘it shows we are listening’. Never a mention of ‘we got it wrong’.
- The cabin light is switching on and off on its own
- 18" Tyre Recommendations
Anyone any good with Apple CarPlay???
Or connect the iPhone to the car before turning on the ignition.
