logiclee
Everything posted by logiclee
  1. logiclee replied to thamestrader's topic in Skoda Karoq
    Have you set up an account and become primary user? I've seen what you describe happen if there are no users registered and only a Guest account.
  2. Half the time mine reports the car is unlocked when it isn't. A lot of gimmicks that most wont use. If it was £10 I might renew but it's not worth what Skoda ask.
  3. Is this happening on Evo2 Manuals as well?
  4. Well collection day today and yes I do have a GTW figure so an aftermarket towbar can be fitted. Talking to the service manager he more or less stated the obvious, ensure the dedicated wiring is plugs and sockets only and no cable splicing of existing looms. If any defect occurred that was the fault of the towbar it would be at my cost. I didn't get into a deep debate around the extra cooling mods included in the towbar prep, I've seen this discussed on many VAG forums across the main four brands and even Porsche. It gets really messy very quickly but legally as long as your are not exceeded the four plated weights then the manufacturer cannot void the warranty. How that would ever be proven I don't know but this has been a topic for VAG cars for decades.
  5. To be fair most manufacturers will say the same with aftermarket towbars and I certainly agree if bypass relays are used and cuts to wiring are made. It is a grey area, if Skoda have given the car a GTW figure then it is homologated to tow that weight whatever Skoda may say. Dedicated vehicle specific electrics should not require modifications to wiring looms. I'd run it by my local dealer who we've had 16 cars from first. I doubt there'll be an issue.
  6. Thanks, That's not actually my plate, it was just for reference. I've seen a few Octavia petrols with 0 on the GTW plate which means aftermarket towbars cannot be fitted. I pick my Karoq up on Wednesday but totally forgot to check the GTW figure. Worryingly the brochure states.
  7. Hi all For those with the 1.5TSi facelift and without towbar prep. Do you have a GTW figure on the weight plate? Second large figure on the weight plate. (Plate for reference, not actually mine)
  8. I've since found a post of a guy that bought a GR Yaris new with high first year tax and sold it before 6 months. He received a refund of the £190 component but not the full 1st years tax. So it would seem any second owner just pays the standard 2nd year cost.
  9. List was around £35k with the options added so I won't be in the £40k+ bracket.
  10. I initially thought that but I'll loose a month refund on the tax on my current Yeti which is more expensive so I probably loose out. I bought the Karoq a week ago but had to leave it 7 days + to wait for the logbook back for my Yeti after number plate swap.
  11. Hi All, After 15 Skoda's including 4 Yeti's I will pick up a 6 months old Karoq 1.5TSI DSG SEL on Wednesday. One thing I'm confused on is the first years Road Tax is £270 and second year onwards is £190. So at 6 months old what do I pay for a year? Anyone done similar?
  12. Towbar preparation being standard is interesting. Skoda UK have been complaining about the situation especially with some of their used SUV stock never being able to tow.
  13. As described above. Sound like diff failure rather than haldex engagement issue. Haldex engagement is electronically controlled via an electric pump on the Yeti. Did the garage doing the Haldex change do the service? Sounds like a cover up. You are not the first and wont be the last to have a diff fail because of an incorrect service.
  14. Yes very common. You could try. https://www.satnavsystems.com/diagnostics-repairs/
  15. What were the symptoms? Noisy from the rear? It sounds like whoever did the service on the haldex drained the diff.
  16. On a dry clutch DSG DQ200 there should be no creep with a firm brake pedal press as the clutches should be clear. As the brake pedal is lifted the engine rpm should increase slightly from idle and the clutches should move to bite point and you should get creep. If hill hold is activated you will have to wait until it releases. For Wet Clutch models creep more significant but the basic principle is the same. My DQ200 history isn't promising. Fabia 1.2TSi. Replaced clutch pack under warranty due to Judder. Yeti 1.2TSi. Replaced clutch pack under warranty due to Slip. Yeti 1.2TSi. Clutches slipping but returned on lease before repair Octavia 1.6TDi. Clutch Pack, Flywheel, Mechatronic and gear lever replaced under warranty. Our current Fabia 1.0TSi is OK for now. Over the last 15 years I've also owned four wet clutch models. (3x DQ250 and DL501) over 250k miles and not a single issue.
  17. Try these https://www.satnavsystems.com/diagnostics-repairs/
  18. Under the bumper foglights were never a factory or dealer option for the XR3i or RS1600i The Mk3 XR3i and RS1600i did have metal bumpers but the optional spot/driving lights came with "L" brackets. Four pre-drilled holes in the front crossmember and the lights bolted to the bracket sticking out just above the bumper. ie In the 80's myself and three other mates bought an XR3i each, all identical. I fitted above bumper driving lights to all four cars.
  19. Not in Borg Warners opinion. Moving torque rearwards before slip has occurred using input from sensors and lines of code is classed as pre-emptive. It's not reacting to slipping wheel when traction is already lost. That's no different really to the many different modes in more off road biased 4x4's where torque is distributed depending on mode selected and input from sensors prior to wheel slip. As an Electrical Engineer working daily with code Pre-emptive systems are common place whether you agree with the terminology or not. Definition In this case the software Prevents "Forestall" Slip by taking advance action before slip occurs.
  20. Correct. If you are in first and ask for 85% torque with your right foot chances are the Haldex ECU will give you some rear axle assistance before the engine can give you what you've asked for. But some steering lock on a wet low grip road, low grip tyres with 25% torque demand and it may well be reacting to that slip. And even with a 50/50 split of torque front / rear torque you may still get some spin on that inside front that the traction control has to try and brake. We are not talking 3 locked differentials here. On the rollers. Gen 5 vs Torsen Quattro
  21. Gen 1, 2 and 3 were reactive. Gen 4 and 5 are pre-emptive and work with the cars stability systems to pre-empt a loss of traction and move torque rearwards before slip occurs. This can be a high torque demand from launch or launch control activated, input from steering angle, yaw angle sensors and engine torque demand. The parameters are even changed if a trailer is attached as long as it's correctly coded. The post from Muddyboots assumes that haldex is either fully engaged or not engaged. This is not the case. For Gen 4 and Gen 5 the ECU can adjust the pressure on the wet clutch plates which allows slip. This adjusts how much torque is sent to the rear axle and also allows speed differential between the front and rear axle which avoids windup. For the reactive part of the system Gen 4 and Gen 5 can send 50% of the torque to the rear wheels within 1/8th of a revolution of slip on the front wheels. Have a look at this A3 the rear is squatting on launch before the front looses traction. https://www.youtube.com/watch?v=vbmenMq7jWU
  22. I'd rather pay for a recommended alignment specialist to carry out the works and insist on a before and after printout of the geometry. Incorrect alignment can destroy how the car drives as well as ruin tyres and stress components.
  23. If you follow tyre reviews on youtube or his website he actually runs Premium Summers in summer and All Seasons in winter. His thoughts are that is the "Optimal" setup for 95% of the UK. Personally I did the Summer and Winter swap for around 15 years but now find premium All Seasons have reached the level of performance that I'm happy to run with all year. But I understand what dale is doing.
  24. logiclee replied to 55VRS's topic in Skoda Yeti
    Detailed across three pages of the manual. Standard on higher spec 4x4's. Optional on lower specs.
  25. I have Cross Climate on our Octavia, Cross Climate+ on our Berlingo Van and Cross Climate 2 on the Yeti. The one area where I thought the Cross Climate and Cross Climate+ was just average was on snow and Ice. So much so I went with Goodyear Vector 4 Seasons on our other Octavia. (I live near to and drive through the Peak District. I was all set to buy another set of Goodyear's until I saw this years reviews and the Snow performance on the CC2's has been drastically improved, now beating the Vector 4 Season Gen3's and even the premium winter tyre on test for snow traction. Time will tell, I'll find out in the next few weeks.
