Sat Nav problems and fitting line out
Just got a Fabia vRS SE and then i found a sat nav unit originally out of a superb laying around at work fitted it installed the gps aerial put in the disc and it receives the satellites signals and comes up with the cordinates and put me on the map in the right place but when im moving it stays still until i stop and turn the car off and reboot the system
anyone got any ideas? is there something im missing for the fabia for this to work or is it a problem with the unit?
if anyone could help that would be great!
Edited by adamweal
Do you have the "plug & play" wires? Search "plug and play mfd" on eBay for a reference
i dont have this no is it something that has to be done?
Yeah, you`ve done the same as me I think, just had the two stock connections in the bottom (black & brown) and the little GPS aerial at the top, it was picking satellites up no problem but wouldnt show me moving on the map. There is a plug & play kit this goes between the black connector and goes in the socket half way up (long thin one). Once i`d plugged this in it took half hour or so driving then it was spot on. :thumbup:
Link to the kit I got > http://www.ebay.co.u...#ht_3175wt_1185
ahh thats great! ive now ordered a kit thanks! :)
just out of interest where did you put your aerial?
got another question! im trying to wire up a line out i dont know if you have done this matt1chelski ive got the wires from work just gonna put them into the original connector block here's the diagram on the stereo to tell me whats what
obviously
rr = right rear
lr = left rear
rf = right front
lf = left front
the little switch with the plus = switch wire
not a clue what com means
but where are the + and - for each output? :wonder:
or am i just being a total fool and its actually really simple?! haha
does it have a disc changer output/input on the back?
Yup the plug has the cd changer in use but the line out and display sections are free
