VCDS Tweaks for O3
Yep, without memory seats there isn't anything to store the position. All I can see is that it dips the mirror a pre-determined amount from whatever position it was in before you engaged reverse. So, not the same as memory mirrors where you store the position, it just dips it x degrees from wherever it was before.
Better than nothing though!
Wouldn't mind this on mine.
Also really miss the 'last drops' wipe of the front and rear wipers i had on my mk2.
  • Replies 79
  • Views 35.6k
  • Utterly pointless, but I know I'd want it enabled.
  • Theres a great thread going on the Golfgti forum here - http://www.golfgtiforum.co.uk/index.php?topic=260248.50   ive no idea if these will be different on the octavia but theres a few of interest i
  • I can't take credit for these, most have been taken from  stemei.de .VCDS Codierungen .Codierungsservice .Webdesign - Stefan Meier - VW Golf 7 - VCDS Codierungen, Webdesign   GolfGTIforum.co.uk - A
Has anyone come across where to code the led number plate light option?
Tia.
P
Sent from my Nexus 5 using Tapatalk
Found this on a German G7 forum maybe it will help
Aktivierung der LED Kennzeichenbeleuchtung
Im Bordnetzsteuergerät haben Sie die Möglichkeit beim VW Golf 7 nachgerüstete LED Kennzeichenleuchten freizuschalten. Somit erscheint keine Fehlermeldung mehr im Kombiinstrument (Schalttafeleinsatz)
Folgende Codierung ist anzuwenden:
  1. STG 09 (Bordnetz) auswählen
  2. STG Zugriffsberechtigung -> Funktion 16
  3. Freischaltcode 31347 eingeben
  4. STG Anpassung -> Funktion 10
  5. (1)-Leuchte25KZL HA59-Lasttyp 25 auswählen
  6. Wert auf 43 anpassen
  7. (6)-Leuchte25KZL HA59-Dimmwert AB 25 auswählen
  8. Wert auf 127 anpassen
Anmerkung: Beim VW Händler durch Maßnahmencode 381AA ebenso freizuschalten
That roughly translates into (Google Translate):
Activation of the LED License Plate Light
in the wipers you have the possibility in the case of the VW Golf 7 Unlock retrofitted LED number plate lights. In this way, no more error message in the instrument cluster (Schalttafeleinsatz)
the following coding to be applied shall be:
STG 09 (on-board) select
STG Access -> Feature 16
unlock code enter 31347
STG adjustment -> function 10
(1)light25Kizie HA59-Load Type select
Value 25 to 43 Adjust
(6) -Light25Kizie HA59-Dimmwert Select
value from 25 to 127 Adjust
Note: In the case of the VW dealer by measure code 381AA as well as unlock
Has anyone found any settings related to the electric power boot for the estate? I'd be interested in being able to close it from the key-fob, not just open it.
me too :)
I'm testing a lot and got this list at this point:
1. How many liters until full tank
2. Login Code Module 09 ( Central Electric)
3. Seatbelt reminder on / off
4. CH / LH through the fog lamps
5. Adjusting CH / LH time up to 90 Sec
6. Displaying the remaining battery charge status
7. rain Close
8. Beep when opening and closing
9. Needle sweep
10. Retracting the mirrors at close
11. XDS Activate
12. Courtesy lighting to fold in mirrors
13. stopwatch
14. Adjusting headlight washers
15. Mirror tilt switch at rear
16. Adjusting Comfort flashing ( 1 .. 5 flashes )
18. Oil temperature display
19. Tail lights with DRL
20. DRL with handbrake
21. DRL only in auto mode
22. Make DRL set in MFA
24. Warning tone off key password
25. consumption Correction
26. Adjusting Duration heater
27. Seat Adjustment remember
28. Adjusting Seat heating time from level 3 to 2 ( default 10min )
29. Adjusting Seat heating time of stage 2 to 1 ( default 10min )
30. Show Turn Indicator
31. Microphone sensitivity
32. Threshold speed cornering lights ( standard 32km / h )
33. Display Parking Sensors in Navigation Screen
34. Customize activation tone parking sensors
35. Distance sidewalk in automatic parking ( standard 15cm )
36. Adjust speed when off parking sensors
37. Adjusting Hill Start
38. THE eject button ( block )
39. How fast handbrake when moving off
44. Time heated rear left on
45. DVD Unlocking ( only special software)
46. Electric tailgate open and close with the AB button( under investigation)
Some things works on the one en not on the other still testing
Hoping for light assist and traffic sign recognition coding. ;-)
P
Sent from my GT-I9505 using Tapatalk
Problem is, it isn't coding for most things anymore, it is changing settings on adaptation channels.
Until Ross-Tech finish documenting them all (and in English instead of German!) there will be a lot we won't be able to do.
Also, Component Protection is active, so some modules need a Security Access code, and some changes will flag up SVM (Software Version Management) which means a trip to the dealers to be hooked up to VAS for them to accept and permanently store the changes, otherwise things just stop working.
From what I am hearing, VCDS can't do a variable service reset properly on a MQB yet! (according to the Golf forums)
What's an AB button?
fob and cluster button I think.  they are labelled a,b,c in the manual
Woo, I would love it for the fob button to work!
Hello Antera,
About that standard is maxim or minim? And you managed to activate cornering?
me too!
me too!
And me!
Hello Antera,
Changing to any speed you like. I didn't test it at like 100ml/h because its hard to see iff it still works on the higway :-)
And iff the car don't have Cornering function. This option is "out off range"
Looking for the option to activate Cornering lights i didn't find it yet. I think you must activate this in adaption somewhere
The Keyfob button indeed
P
I did this coding to but it didn't work on 2 O3's wich have this not standard. U think because there is no Camera for it
Edited by Antera
It is possible to recode the electric trunk to open and close wicht the remote and the button in the car.
Also the warning sound you can disable
Just like the S2
If it is possible, how do you do it then?
  • 2 years later...
Hi, does anyone know the VCDS password / access code for the MY 16 Octavia 3?  The one quoted in this topic - 31347 -  did not work for me.
Warrior193.
Warrior193.
What module?
What module?
Module 17 (instruments) was one - I would also like to get into comfort flash and dipping passenger on reverse. Does each module have a separate access code?
Warriort193
Yes most controllers use a different log in code, some modules (ABS for instance) use multiple codes depending on what you want to change.
For 17 - Instruments try 25327 or 20103
Great, thanks Gizmo I'll try that.
Warrior193
VCDS usually prompts you with the correct access code for adaptations for each module in my experience? Sometimes it takes a second or so to appear though.
What version of VCDS are you using?
Hi Skodaphile, I was using V15:7 when I first tried - but I have recently updated to V16:8. I didn't see any prompts given for the access code, but I might have simply missed it, I will look more closely next time I run it. Does anyone know if rain closing, enable SOC meter, dipping passenger mirror (non-auto seats) and change convenience flash (lane change) are all achievable on MY 16 units?
Warrior193.
