My new diesel smells like burning rubber and/or the fan stays on after engine is turned off
This is why I love this forum. My Octavia done this for the first time today, smelt hot rubber, loud fan after pulling onto my drive and it felt hot outside my driver door. Felt a little bit panicky that something wasn't right. However reading this has completely put me at ease. Many thanks all.
  • Replies 270
  • Views 248.8k
  • Or we could get skoda to write it on the steering wheel of every diesel
  • Forget this myth of passive regeneration, it simply does not happen under real driving conditions so no amount of long runs will clear the DPF out magically, only the blood of a unicorn can do this .
  • As I understand it, idling will increase soot levels ............ Let the car do it's thing, I've had no DPF issues, and the only ones I am aware of are due to something else failing. Sent from my H
Apart from the fact you then know the cars been over fuelling to get more heat into the DPF .... That used to really irritate me.
To force a regen
3rd gear @2500 to 3000 revs for 30 mins down a motor way , once you start dont stop no matter whats going on around you .
If you have to break , start again .
My VRs TDi was all ok until 200,000 miles then got lazy with regening ,
Changed all 5 sensors including the one in the turbo body,
Ok for 5 weeks then started again. Regen light again ,
Sold the car and went back to petrol .
@Andrew245
So a Manual TDI & a Motorway required.
Yep and should regen
8 hours ago, e-Roottoot said:
@Andrew245
yep , mine ran over with fan and aux water pump running , its ment to under normal conditions , it has an elec water pump to circ going for engine cool down
@Andrew245
I had a 2016 TDI DSG SCR Alhambra until last November.. Never raced or rallied, well not on the road.
After 2 years it had enough of the occasional week where it only did a few miles for maybe 5 days in a row and the blocked DPF light started taking longer and longer to go out.
It would happily sit and do a regen while parked until people passing would be scared that it was going to catch fire.
Still sitting unsold at a Dealership, someone has dodged a bullet with that car.  Good for around near 60 mpg on runs and not 20 mpg if used for 5 days and maybe only 20 miles.
Edited by e-Roottoot
  • 2 years later...
I have a 2013 2.0 5E TDI CR Elegance and was under the impression it didn’t have DPF. I have the same thing and sometimes even after a long journey. I am have been trying to find out the feasibility of upgrading the car to Euro 6 as I live in Bristol. Some say it’s possible but neither Skoda or DVLA will accept it. I was also under the impression that the DPF sometimes required servicing which could get expensive. Any assistance/advice would be gratefully received.
ps: just can’t afford to change my car, love Skoda Diesels but even second hand are out of my reach as a pensioner.
You can not change anything about how they have your 2013 TDI which is as a Euro 5 emission car with a DPF, and not a Euro 6.
You could remove the engine and fit a Electric Motor & big battery so converting it to an EV.
Probably replacing it will be simpler / cheaper.
You might get a Petrol car for the money your diesel car is worth.
Edited by toot
Thank you, I sort of thought that otherwise lots would be doing it!!
  • 4 months later...
On 02/01/2020 at 15:17, silver1011 said:
Be aware, modern petrol engines are being equipped with particulate filters too, Gasoline Particulate Filters (GPF).
Petrol engines run hotter, get up to temperature faster and the GPF's operate differently from DPF's so are thought to be much more reliable.
They are still relatively new though, and as with all new technologies, especially emissions related ones they will potentially end up being problematic at some point...
https://www.whatcar.com/advice/buying/what-is-a-petrol-particulate-filter-and-how-does-it-work/n19953
I bought my GPF-equipped EA888 in July 2020 and have only put about 8K miles on it in the last three years.
I have not had even a hint of a GPF problem, but I do take it for a run down one junction of the M42 at least once a week.
I haven't heard of any GPF-related issues, other than it's thought they take the edge off performance a bit.
If you have particulate filter worries, petrol is definitely the way to go IMO.
Around now & from now on will be when there might be more on GPF issues, you can not know how things will be at 5 years and beyond until you get to 5 years and beyond.
It would be interesting to know how much Main Dealers want for a replacement GPF if one is needed and fitted by them.
http://briskoda.net/forums/topic/508126-2019-mk3-high-idle-problem
http://briskoda.net/forums/topic/479195-car-behaving-strangely
Edited by toot
  • 1 year later...
http://www.natef.org/NATEF/media/NATEFMedia/VW%20Files/2-0-TDI-SSP.pdf
I see this link posted all over but the link is dead. Where can I actually find that .pdf today in 2024? (several other forums have also posted the same link and obviously same result)
I also wonder how people normally will get enough rpm without wanting to go full race mode in daily traffic especially when after a software update from the dealer the sport mode on the DSG doesn't change the rpm anymore. Only the responsiveness is altered, and before this the rpm would increase and generally be higher than in D. Obviously I can decide to shift gears "manually" but it would be nice if I did not have to. You should be able to get the car into a suitable rpm range while doing normal cruising, except I see now that is hardly the case.
You can put the car into a suitable rpm range simply by knocking the gear lever sideways into manual mode & then selecting 1 gear lower than  auto mode would choose.
So you somehow only read that sentence, and not the one before it...
  • 4 months later...
Thank you for this thread.  My Octy has periodically run it's fan after stopping with no real rhyme or reason, except that I've sometimes thought it's possibly connected with a short journey (or three!).  Getting the sensor hot to burn off deposits (which is wouldn't do after a number of short journeys) and then running the fan to cool the process after the engine has stopped would entirely explain my experiences and at long last will stop me worrying about it when it happens - which I have done.  It would appear to be 'by design' which is actually good news.  I am really glad I have finally spotted and read this thread.
  • 3 months later...
Anther thing i have read is that if you switch the engine off during a regeneration, it can dump fuel into engine oil, thus contamination. Something to keep in mind.
If you park up and notice that the rpm doesn't drop, stays at 1000, chances are its doing a regen.
Just leave your engine on for a while if you can so it can finish, or drive on so it can finish properly.
Recently, the regen happened to my car 24 hours after the car had been parked, though I had moved the car 2m forward from its parking position 4 hours before I heard the regen. Is this normal?
  • 9 months later...
Interesting
Interesting
  • 2 months later...
On 11/01/2014 at 23:58, Dempsek said:
If you are reading this post do not despair!
The horrible burning smell coming from your new diesel car is OK.
When you stop and turn the engine off and the fan stays on and the engine seems to be super hot, the car is OK.
The above are clear signs of an active DPF regeneration and is normal for your new diesel Skoda car.
To comply with the latest emission levels diesels have to capture the large soot particles and burn them up into smaller particles which are kept in the DPF, this process is called regeneration.
A lot of regenerations take place during normal driving where the exhaust is hot enough to burn the soot in the DPF and are unnoticed and are known as passive regeneration.
When the temperature in the DPF is not hot enough for an passive regeneration, the ECU injects diesel into the DPF which burns up the soot and is known as an active regeneration.  When you stop the car part way through an active regeneration, often the car smells like it's burning and the engine fan will stay on to cool the car.
Mods could you please edit this thread (if needed) and make it a sticky or just delete, thanks
Thanx
