My new diesel smells like burning rubber and/or the fan stays on after engine is turned off
I think I must have had more than the regens that I have noticed it's just that most of them must happen and complete during a longer journey of which I do a few occasionally.
  • 4 weeks later...
  • Replies 270
  • Views 247.2k
  • Or we could get skoda to write it on the steering wheel of every diesel
  • Forget this myth of passive regeneration, it simply does not happen under real driving conditions so no amount of long runs will clear the DPF out magically, only the blood of a unicorn can do this .
  • As I understand it, idling will increase soot levels ............ Let the car do it's thing, I've had no DPF issues, and the only ones I am aware of are due to something else failing. Sent from my H
you have no idea how relived i was when i came across this!!!
knew about the DPF but not about what would happen if you interrupt the process.
cheers .
WOW - I NEVER knew this.  My previous car was a Mazda6 Diesel with DPF.  Nothing about this was mentioned to me at handover, nor was it anywhere I could find in the manual.  But often, the car smelt like burning rubber.  I would often get out and start bending down sniffing each of the tyres, thinking there was something wrong with my alignment - I can't imagine what the neighbours thought of me watching me do this!
This was an ongoing thing every couple of drives or so, during the 3.5years I owned it, and through several sets of tyres.
I wish I'd known right from the start.....
Is there any way to get Regen info on the Columbus Unit?
Just think if the regen cycle is displayed, we can actively drive that little bit longer to ensure we get the full regen cycle complete before shutting off the engine?
For instance, if we can see the cycle is at 80% complete, take the car for another 5-10 minutes drive and by the time you get home, the DPF has fully regenerated.
I hope There is a way to show it on columbus Would be much better
I can't deny how much of a smile it puts on my face to park my Focus ST3 petrol up and not hear the dreaded fans of doom.
I'd much prefer to drive a diesel but DPF has killed the industry.
RIP.
RIP.
VAG have already announced that Particulate Filters will start being fitted to PETROL engined vehicles too, so we all better get used to dealing with them...
although I've experinced few regens already, never heard the fans blowing when I stopped the car..
However there is another indication thata ECU gives you, beside Start/Stop,revs, when driving in city the gear shift indicator asks you to stay longer on first gear and asks you to shift later to the next gear from second up.
Particulate filters won't be an issue with petrols as they burn so much hotter. It will be the extra sensors and electrics to go wrong that will cause the problems.
This has now happened twice in a week? is this normal and as a novice ( still haven't found the starting handle) I feel uneasy about locking the car and going in the house if this happens frequently
The things that make it more frequent are :
- start/stop system
- fast accelerations, pedal to the metal, specially when cold
- city short diatance driving
- fuel quality
- scheduled regens (fixed)
when you see it regenerating give it another 10 mins driving with load and constant pedal push. Like a dog, give it some time to pee :)
Found another dependent thing...when car is about to do a regen it asks to stay longer on first gear, shown in the display. I assume it wants more load to heat up faster and then regen..
I do a lot short journeys and most time when I just about pull on drive or to my destination regen starts. I have to either interrupt regen or get it back on road to get it completed.
Am I correct in assuming that this is the best course for DPF health, provided your circumstances allow it at the time?
Realise that VAG do not appear to recommend it but do warn against consequences of repeated interrupted regens. Well the only way to avoid interupted regens is not to interrupt regens
one thing I couldn't find answer for...
when RPMs go high and it's an active regeneration,not due to high power or heat consumtion (you find this usually car ask you to stay longer on 1st,where usually asks for second) :
1. does the city driving in traffic makes any sense
2. does it help to leave it parked idle for 20-30mins
As others have said, it doesn't complete regen if left sitting at idle. Just let it do it's thing and act as the manual states if you get the DFP warning light.
I've done 10k in mine now, never had the DPF light come on and have been in heavy traffic. In actual fact I've not noticed one in weeks even though I sit in the M25 car park regularly on the journey home
For what it's worth without starting a fuel argument I have used vPower diesel religiously for the last 2 months.
Edited by davitc
I'm at 17k miles and never had the light come on. My commute is 8 miles each way. Interrupted the regen plenty of times, but never had a problem. Just let the car do its thing.
did you see any corellationike this city driving + cold weather (below zero)?
I see it does regen (active one,not forced,no light) every ~200km. No matter,driving style, fuel type.
My MkII greenline hardly ever did an active regeneration even from new. My daily route is about 10 miles, usually at 60 and this journey seemed to provide the ideal conditions for a passive regen.  With my new MkIII greenline, it's doing this all the time and sometimes bizarrely when I get home?
What has changed? The route is the same, my driving style is the same. What has changed is compliance to Euro6 regarding Nox emissions Now the only system that VAG employs to reduce is total reliance on the EGR (no Adblue yet? (taking the P**s)).,
Is it that the EGR is working a lot harder, dumping more dirty carbon rich exhaust gasses through the engine which the DPF has to get rid of by excessive active regenerations.(Why can they not take the supply of inert gas from downstream of the DPF?)
Is this the long awaited solution to the emissions scandal? and will owners of Mk II diesels accept this deplorable outcome?
Also is this the reason that normal driving consumption figures are abysmally below those quoted by Skoda?
This suggests that the quoted/ published MPG figures were obtained in the lab, not only on a rolling road (no wind resistance) but using a car not equipped with either a DPF or a EGR?.
Perhaps Skoda could come back to us withy some answers?
I think Ron may have hit the nail on the head - this is Diesels emissions scandal 2.
I'm getting non stop active regens, other folk doing the same commute in other diesel cars are not.
I covered this when I had my TDI vRS a while ago Clicky.  When SWMBO had the car for a while we got 13mpg due to constant regens.
I'd love to know if the new Mk3 FL has this issue.  I was told (no idea how true this is as it was a dealer that told me) that SCR systems have much less issues with DPFs as the adblue allows the engine to run much hotter and create much fewer particles.
I do wonder if diesel is really just coming to the end of it's life when it comes to emissions.
They do take egr from the clean side of the dpf, this is called low pressure egr, unfortunately to meet euro 6 they also have to use high pressure egr which is taken straight from the exhaust manifold so you will be pleased to know that the euro 6 engine has 2 egr valves!
Edited by MrAdamwood
Realising now that the big differences regarding regen behaviour experiences in Octavia 3 might be down to Euro 5 v Euro 6.
I had thought Euro 6 was better to go for - A bit more power, slightly better official economy figures, cheaper road tax. Now realise the earlier Euro 5 might be better if you can live with a slightly older car.
I had thought Euro 6 was better to go for - A bit more power, Slightly better official economy figures, cheaper road tax. Now realise the earlier Euro 5 might be better if you can live with a slightly older car.
(Replacing the above as no edit available)
After 2 weeks of ownership & around 280 miles of driving, I've experienced my first active regen.
I came back home after a 12 mile round trip, switched the engine off & the cooling fan stayed on.
Was only on for 5 mins max, but glad to know it's nothing to worry about.
A quick question, if I may. My commute is basically 20 miles motorway and 5 miles A and local roads. In the cold weather, I often get the faint aroma of what I assume is the burning rubber smell in the cabin, when I have been on the motorway for 10 miles. Is this normal?
many thanks
