Fabia mk1 1.8T RWD
Love this thread man! Going to be interesting to see how you get on with the RWD conversion, what parts are you using again mate??
  • Replies 675
  • Views 87.6k
  • Slight progress. Don't have the time I used too as after over a years court case I finally have my little lad living with me, some of you that know me personally will already know. Despite lack of tim
  • and the brace is finally painted and on
  • This is a great project for sure  I am having to buck my ideas up a little with the mongrel to keep up
Avo coilovers arrived last night hopefully these will do the trick, TD05 is now ready to collect from Midland turbo after a complete rebuild, progress is slow until i pull the interior and loom out over the bank holiday then i can start cutting the a few bits out the chassis and start mocking up how the engine will be mounted
If you're scrapping your old block do you have a spare piston floating about please?
I have one I'm sure I could donate too a fellow 1.8t fabia owner if he was to cover the postage
This sounds even more interesting than before Ben, liking the regular updates and can't wait to see this on the move again!
PM me with your paypal details :)
That looks awesome :)
Cheers dude its getting there, Midland Turbo have done a good job certainly looks the part. Hopefully the manifold I will be making will be as sexual
so it seems a slight bump in the road.... the lovely lovely CG motorsport clutch won't fit the quattro gearbox as the input shaft is the same size as the 02M box found in the fab VRS. So after steering at it for quiet some time, came to the conclusion that i need a new pressure plate of some description, whilst i'm at might as well change the box for a proper one which also allow me to use the correct diff so my final drive isn't either too low or too high. Entry the Mazda rx8 gearbox.... Parts are cheap due to the short life of the Rx's engine, comes with a lsd from factory, has been proven to withstand some rather serious power (more than i will be running). Plan now is too stick with my Darkside G60 flywheel, the VR6 CG pressure plate, CG rx8 friction plate, rx 5/6 speed box/LSD diff, i will have to machine up an adapter plate for the rx box which should't be too much trouble.
Problem number 2 is that the scooby rear end has become un-workable for several reasons. So will now design the rear subframe/diff cradle around the rx diff and golf vr6 front hubs. This is allow for a simpler design and use of VAG parts which certainly seem to be a lot cheap than Subaru ones. Despite progress seeming rather slow an awful lot of head scratching is being done
Sounds technical, lol. Looking good mate, should be a weapon when finished :)
all seems very familiar. Almost ready for cutting
We can send Danny up if you wish, he's good at cutting up Fabias. :D
Busy afternoon, been and cut a transmission tunnel from a rx8, got the 6 speed gearbox, prop shaft, diff, shafts and tank. Fabia no.2 is off to a new home tomorrow after sorting it out.
Well done Ben looking forward to seeing this monster! Going to be a lot of fun!
Its getting there Steve next part is mounting the block as far back as possible which hopefully I will start soon
slight development over the weekend, the sea green shell will be replaced with the legendary fantasy green shell
Whats the reg of the fgf? Not my old one?
Was yours GJ02CKU? That one went to Tom Kidson on the Briskoda FB group
all i know is that it has a roll cage,  other than its green
I think yours was the Copart Cat C that donated the bootlid to Y1 FGF
honestly don't know any more than you. You know more than me about it Jack
1.8t in Fantasy green! There common as anything :)
the only FGF one to havae a roll cage is the Santa Pod special we never finished... has a massive hole in the back already cut out for you Ben ;)
