Taylor93's Mk1 VRS
It'll be fine! Still not seen your cone hitting footage from Bedford :)
That's because I haven't used the Fiesta since and pulled the SD card out.
  • Replies 480
  • Views 36.6k
  • Working hard, looking happy. The smug look when after doing a head gasket it starts first time...
  • Took it to Brands Today   Positive comments all round, loved driving it, Yoko AD08's really do stick! like poo to a blanket.   Very happy with it, although i wore a hole in my Arch Liner and a Ca
Ahh :) not been using it as a daily? :o
Probably a question for another thread, rather than Taylor's Fabia one.
Yes sorry Taylor
exactly my thoughts as I was ready the comments lmao
looking forward to tomorrow just need to get some sleep but a wasp nest in the roof is and has been keeping me awake at night for a while :/
Doing Brands in the new one?
No still in the 04 plate (old one)
im actually going to call TPS on monday as its taking the mick that the inner, outer track rods still havent turned up and i ordered them the day after combe!
also need to find the source of the extra diesel consumption.
No EML, running around 40mpg all the time. Might be boost leak but i havtn found it yet!
So has 05 one gone back for the work or still in South England? Whack it on a smoke tester for the boost leak :). If you want to clean the headlights up I've found that cheapo Halfords rubbing compound and a polishing pad for a drill work wonders! TPS by us are quite good but then that is trade! I give up and use ECP normally
i dont have a smoke tester, was going to go for spray bottle +  water and watch for bubbles
That'd work :) the 90* angle is the common place for a leak iirc. Could the sidemic be blocked up with dirt?
lol the system is full of 90 degree bends :P
as in internally or the fins?
Fins mate! I've seen a few absolutely caked in crud causing it to run not as well as it should!
Egr valve?
Egr valve?
i cleaned it a bit, but not brilliantly, so its still quite dirty. I know blocked/stucked EGR's can drop mpg by quite a bit.
Blank it ;) yeah I'd give it a quick check mate if not then SMIC or boost leak
There you go Steve!
Sorry wrong thread
well this friday is booked off, i now have two track rod assemblies sitting on my dinning table, just need to fit them!
hoepfully i can do it with some mole grips as i dont have a 34mm Crow foot spanner to tighten it.
I've done it with mole grips and an adjustable on a few vehicles prior to buying a tool :) TPS got their act together then?
Edit - remember to get it tracked too :) I couldn't get one I did into a tyre shop for a week so had a lot more tyre wear on it!
Edited by Toxicvrs
TPS didnt, they had no record of my order, so went to ECP and picked up two Lemforder arms.
Hadn't paid yet had you? Yeah I was in ECP too today :(
Changed both Track rods, one side was quite worn.... however the sound is still there.
guess who needs a new steering rack?
Same as a standard Fabia?
dont think so, IIRC the rack is geared quicker for the vRS.
£90 + £140 surcharge
Shame I know where there's one knocking about
Guest
