VCDS options on Superb III
Eyelashes only could enabled on cars with dynamic light assist. Without dla, there are no eyelashes in headlights.
  • Replies 2.5k
  • Views 826.8k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
The car has SLA but despite taking the coding it would not light them up with DRLs.
I had had similar problems with a Kodiaq, but eventually they came on
Anyone has a complete VCDS log of a Skoda Superb 3V with Smartlight xenons? Feel free to make a PM, if needed i can pay for the log, I am getting headaches on coding issues..
Do you know that the Ross-Tech forum has this   Reference Scans and Maps of Non-Broken Cars ?
I have channel maps of all controllers. My car is with smart light assist.  Which controller you need ? This ?
https://drive.google.com/open?id=0B-9PIQDeL8PyLXItLWN3X3hEeUk
Amazing, thanks. Any chance for a full autoscan and adaption channels from 09?
How to enable open and closing sunroof with fob.
So no one has managed rain closing have they?  I got the menu up, but it doesn't work sadly...
Did you set it permanent? I remember there are options for it
I found instructions for a Golf, but it won't let me do the coding in the central electronics module and I can't find an appropriate adaptation there
Rain Close can drain your Battery since the Car won't go into Sleep mode, that's why it is not used anymore.
I see.... thanks!  I'll stop trying then!
Rain closing would never function without Changing Hardware. Dinge MY2015 in all Cars of vw or skoda
Rain closing working only in module 5Q0955547 for 2015 MY, but it not working an another RLS module-example 5Q0955547A...
Dinge=Since.
In Superb 3 is Never a Module without an A or B at the end drin factory. Because of that, without changing Rain/Light Sensor no rain closing is possible
Hi all, what's the fewest / cheapest combination of options I'd need to add to an L&K spec car to get all the A5 camera goodies?
If I just spec an L&K, does this come with high beam assist as standard and will that then allow me to enable lane assist, travel assist, and smart light assist in VCDS?
Thanks.
Thanks.
The A5 camera is std on the L&K (99% sure lane assist is std... mine has it and I did not spec it)
HBA can be coded
SLA needs to be added (£100) as it requires different headlights
TSR can also be coded
Great, thanks for the info!
Also - do you happen to know if the ACC on the L&K includes stop and go / traffic jam assist as standard? If not, do you know how I'd go about spec'ing it?
Edited by Participant
Yes, if the car has DSG.
I am not sure if I have already asked this, so apologies if I have but I did check my post history and couldn't find it...
Has anyone looked into the possibility of activating the puddle lights under the rear vision mirrors when in reverse?  I'd love for them to come on so I can see the kerb when reversing in the dark.  I know Beemers and Mercs activate the courtesy lights under the handles for this reason and I think its a great idea.
 The mod to disable stop/start seems to create a DTC on MY18 Superbs.
The DTC certainly shows up using the latest beta of VCDS, I honestly don't know if the diagnostic software that Skoda garages use will detect it, I suspect it will.
Chassis Type: NP-SK48 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 4B 52
         5F 6D 75 A5 BB BC
VIN: ****************   Mileage: 252km-156miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0443999625
   Coding: 032C0C060F
   Shop #: WSC 33361 790 00158
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3E26347380F6CF37637-806A
   Sensor Controlled Power Rear Lid:
   Subsystem 1 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84507735
1 Fault Found:
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 248 km
                    Date: 2017.07.23
                    Time: 09:11:52
  I thought people should maybe be aware that this is happening.
 Changing the setting back to it's original state gets rid of the DTC.
Edited by Derek_Mac
This does not have anything to do with the coding.
The voltage on battery was low, so it went to restricting less important functions to save the battery.
Mmm, the engine was running at the time with no lights or heating or A/C turned on.
 As I said, the DTC disappeared when I changed the setting back to its original state, I'll give it another try later and see what happens.
I thought the purpose of the coding was to make the ecu 'think' there wasn't enough voltage to use stop/start, which is exactly what the DTC message is saying:
"1 Fault Found:
65794 - Function Restricted due to Insufficient Voltage"
Would anybody be able to advise on the issues I'm having with enabling HBA? Really want to get that working :sadsmile:
thanks
