VCDS options on Superb III
anyone knows if this works via obd11 or if the script is correct to code
Traffic Sign Assist Activation
Select Control unit 5F (Information Electrical)
Adaptation
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Değer = Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Değer = Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_threshold_high
Değer = Active
Control unit A5 (front / advance camera)
Security access
Access Code 20103
Control unit Long Coding
Byte 1
Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
Select Control unit 17 (Dashboard)
Byte 5
Bit 2 Aktivate
Adaptation
Select: channel numbers indicate end of speed limit.
Importance to the utilities. Valid suffix
View Channel. Valid suffix
Corresponding value adjust default: 00100111
  • Replies 2.5k
  • Views 826.8k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
20 minutes ago, rtj70 said:
If he had the necessary headlight units for SLA he'd already have SLA and not need to enable it :) But since it needs different headlights then he's not going to be able to enable with VCDS. Since he enabled HBA then I conclude he did not order the car with Smart Light Assist.
Agreed, but this question keeps coming up with owners believing they just need coding as they think the black strips (whiskers) are LEDs... they are not.
anyone knows how to do this ?
Fortunately no.  :D
Just because you can doesn’t mean you should
It looks crap (like you have a bad earth) and would be illegal in the U.K. anyway
Does look awful and number plate lights flashing too :wondering:
Lol. That’s even worse than the alternating DRL/indicator people were doing on the Mk3 pre-FL Octavia.
if only forums had bots that could auto-respond to questions (the same one) that have been asked over, and over, and over........and over.........and over!!!
save u from repeating the same key-strokes (Ctrl-C, Ctrl-V) :)
crickey!!
maybe have a sticky glossary too - so people can read the definition, and more importantly, the differences between HBA, SLA and DLA!!
lol
I thought the S3 don't have right rear foglights?
Anyway, it's seems painful and confusing having to watch those lights. Sure way to attract road rage :)
just enabling the both rear fog lights would be awesome i wonder if its possible
I think it has been discussed before and it wasn't possible (I tried adaptations from the octavia forums with odbeleven anyway, didn't work).
Maybe it works with long coding but who knows what bits you need to flip ...
Nope, no LED’s in the ‘other’ fog light, if you want twin fogs then you will need to buy a LHD light unit (then possibly run extra wires or at least code the car)
Guys, is there anyone who had their drl lights coded to so called audi style drls using vcds prior to getting headlights recall done? Did the software update influence the drl settings?
Whats audi style drls?
  • 4 weeks later...
You only really notice the difference in your rear view mirror.  They are typically MUCH closer than any other types of DRL :angry:
Lol
Hi. I’m due to get a 2.0l DSG Diesel SE Technology next week.
Has as anyone tried the carista obd2 adapter and app?
It’s £15 on Amazon and with the purchase you get a full month of premium services. They advertise as being capable of changing the VCD options via the app.
Any successes?
Is there now a definitive list of what can be enabled via VCDS? I know a lot of the original posts relate to the Octavia III, but wondered if any new options had been discovered.
Has anyone already find out which option is to disable remote boot opening?
HI folks,
Just curious what is currently the cheapest way of changing options via the VCDS on the Skoda Superb 3 (66 plate)?
I checked the map but there doesn't really seem to be anyone near me (who is active anyway).
I just want a few things like the speed limit icon etc
Can you upgrade firmware on the controllers using VCDS? I wonder if anyone attempted that. I'm sure newest firmware has fixes and improved stuff that comes handy
Last night managed to get easy entry drivers seat function working (although because of my driving position and height it doesn’t move back all that much!)
Also enabled rain closing which has appeared in the menu but I’ve not tested it yet
And I’ve changed the warm white interior colour to cold white
From what I've read, only the very early models of the Superb mk3 had the Rain light sensor that supports rain closing.
Subsequent models were fitted with a different sensor.
If u do a VCDS scan, u can see which rain light recognition sensor u have.
If it's the "RLHS" version - then the rain closing feature won't work.
