What did you do to your Skoda today pt2
fitted some new climate control knobs
  • Replies 637
  • Views 53.8k
Hoovered it and cleaned all the interior plastics...   A 9 and 12 year old can make a lot of mess...
Took it to get new brakes fitted today (Pagid discs and pads all round). Garage phoned me and said the rear calipers are seized so it's going to cost more than expected to fix, bummer!
On the plus side the brakes should be better than they have ever been once it's all sorted.
Sat in it for an hour with the air con on full blast.
The only way I could get cool.
Doing your bit for global warming ;)
I like to help where I can.
Chopped it in for a mkIII Scout!!!
Changed the oil, oil filter, pollen filter, air filter, sump plug and new pads and discs all-round :)
Thanks to Tech1e for his top tip on disc removal when the locating screw is welded in :hi:
Took the kayak off the roof and then put it back on the roof after 5 hours fun on the sea.
Left it on the drive whilst I went to collect an RSPCA rescue rabbit in the civic...
Kerbed one of my Pictoris alloys...
Feck.
Washed both cars
fitted front ops
bloody big project i have to say,took me a full day.
Checked to make sure it was still there. Other than that absolutely nothing. Just remembered I has a new shiny black gear knob insert. Fitted that which took all of the last 30 secs. Took longer to write this post :)
One of these
Edited by Mikek3111
Wonder if that's why I've been smelling raw fuel, after a drive, for the past couple of weeks?
Not visible in the picture is the fine mist that was being sprayed from the tiny pinhole in the pipe; gently misting everything with the contents of the tank.
:swear::@
Guess she's just jealous the truck's been getting all the attention. :rofl:
Took the citigo for a jaunt down the motorway with the small man to collect the missus from the airport.
i have to say, despite the wind, it happily sat on (indicated) 135kph the whole way down to cork and gave about (indicated) 45mpg - 6.2l/100km. Other than a lack of torque to keep the momentum goimg on the bigger hills it was a comfy drive. Swmbo drove home sat on 120kph and twas avg at 5.7l/100km when we got home. Overall a nice indicator of what that little 3cyl 60broken-donkey engine will do :)
Investigated flashing glow plug light and intermittent limp mode fault turned out to the a connector on the fuel pressure rail being loose found by chance, Had no codes come up either thought it was dpf at first phew! :)
Took the car in for it's first MOT at the work's garage.  Passed with only an advisory for rusty discs at the back (scored), the dealer had suggested replacing them before MOT but the car stops fine.
Had the Superb serviced yesterday.
fitted front ops
Nice job  :clap:
2007 and so close to be run in  :D
14729388_10154520954890761_1740012968765
hovered it out - kids can't half make a mess...
Brought the octy for a couple of messages yesterday. Had tge little lad with me, so got it jet washed while getting diesel - his first time in a car while it was washed , the look of intrigue and confusion wjile the windows he could see were being powerwashed and then snow foamed was well worth it. And its looking 100times better on the outside now!
I'm a few days late, and also a day early. Last week I had a new hub and sensor fitted to the rear. Tomorrow, it's going in for B12s to be fitted :)
Now onto ebay to look for a load of silver/grey cable ties to make sure they don't come off!
Mike - should have some the right colour for you, if you want to avoid buying a load you might not use :)
