Improve Throttle Response - Superb 125TDI 4x4 (3T)
I tried the solution mentioned at http://www.briskoda.net/forums/topic/380829-superb-mkiii-vcds-adaptations-tried-and-tested/#entry4611928 but sadly there were no selections available ...ie: No Audi, Skoda nothing....
After much searching I found a possible solution by way of adding a 'Throttle Response Controller' for AUD$299. My thinking is that if a box can apply some sort of electronic wizardry then maybe there is some coding that may address this issue???
My VCDS knowledge is very limited and I was hoping one of the Briskoda techno experts may be able help??
Can anyone help??
I'm fairly sure that V1.0.6.24 is a paid shareware VCDS, not the free download. So start by checking your VCDS version number.
Got an autoscan or screenshot?
If you're not using the latest VCDS release, you might be missing the label file :)
The latest version of VCDS is 16.8.0, so if you're not using that then download and install it now to get all the latest label files - assuming you have a genuine Ross-Tech cable...
Edited by PetrolDave
Here's my first Autoscan...
Tuesday,16,August,2016,18:04:56:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: TMBMF93T2F9027151
Mileage: 14820km-9208mi Repair Order:
Chassis Type: 3T (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 2E 36 37 42 44 46
47 52 55 56 61 62 6D 72 77
VIN: TMBMF93T2F9027151 Mileage: 14820km-9208miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RS HW: 03L 906 018 MH
Component: R4 2,0L EDC H28 5357
Revision: 41H28--- Serial number:
Coding: 001D0032042701080000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01103L906018RS 003003
ROD: EV_ECM20TDI01103L906018RQ.rod
VCID: 0C103C1FA758F05E31-8058
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 016 D HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4013
Revision: 05653104 Serial number: 00001409040719
Coding: 0000020
Shop #: WSC 33361 790 00078
VCID: 1526597B3C9231969E-8040
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 863D601609240001610C06E9901A0092A1015023
VCID: 0400143F8708B81E79-8050
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0345823220
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G.rod
VCID: 377AB3F38E5E2386AC-8062
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 CE HW: 3T0 907 044 CE
Component: Climatronic H19 0709
Revision: 00001009
Coding: 0010000003
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 77FA73F3CEDEE3866C-8022
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 AN HW: 1K0 937 087 AN
Component: BCM PQ35 H+ 112 0771
Revision: AF112771
Coding: 48190ABCE85BF1C0400800C0310089EC497100AE676D85F08081C704A041
VCID: 7DF661DBE4E2C9D636-8028
Subsystem 1 - Part No: 3T2 955 119 B
Component: Wischer 07091 26 0700
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 061014 05 54 0403
Coding: 0630ED
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J791) Labels: 3T0-919-475-V2.clb
Part No SW: 3T0 919 475 D HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0005
Revision: -------- Serial number: 56231425901153
Coding: 149302
ASAM Dataset: EV_EPHVA2CAS46X0000 001003
ROD: EV_EPHVA2CAS46X0000.rod
VCID: 3E74A6D7A16412CE6F-806A
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 3T0 959 655 D HW: 3T0 959 655 D
Component: J234__LDQ VW10 HI 2518
Revision: 26020000 Serial number: 003LEPJW6R7P
Coding: 0017489
VCID: 428CD2271D9C762E0B-8016
Subsystem 1 - Serial number: 6332MTS647302664
Subsystem 2 - Serial number: 6342MTS609602674
Subsystem 3 - Serial number: 6351HTS66KA36DKJ
Subsystem 4 - Serial number: 6361HTS6PCD66DKJ
Subsystem 5 - Serial number: 63727TS6FM3H2DKJ
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 DT HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140929301985
Coding: 1002140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 010E1D2B901AAD3652-8054
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F
Component: E221__MFL-PR6 H05 0130
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 3T2 920 841 M HW: 3T2 920 841 M
Component: KOMBI H08 0811
Coding: 111E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 071014F1001208
Coding: 359303
VCID: 7F0A9BD3EEEEDBC624-802A
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4586C93B0CB241162E-8010
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H08 0811
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADC5A878D6C4E6EE3-803E
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000260308003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 306888EF6B30F4BEED-8064
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666660927
Coding: 010100
VCID: 2B529F834A169766D8-807E
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 139
Mileage: 0 km
Time Indication: 0
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 14505 km
Time Indication: 0
Date: 2016.08.09
Time: 07:18:40
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 E HW: 3C8 959 760 E
Component: Sitzmemory H05 3101
Revision: 00H05000
Coding: 00003B
Shop #: WSC 12336 024 394758
VCID: 377AB3F3865E2386AC-8062
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 S HW: 3T0 035 680 S
Component: RNS-MID H23 6276
Revision: AB001001 Serial number: SKZ6Z7P7261121
Coding: 00060002000000811000
VCID: 4088D82FD390643E1D-8014
Subsystem 1 - Part No: 3T0 051 859 P
Component: AUNZ V6 7920
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 155
Mileage: 13281 km
Time Indication: 0
Date: 2016.02.23
Time: 07:55:19
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Revision: -------- Serial number: --------------
Coding: 011D0220DE01001000
VCID: 52ACE2670DFCE6AEBB-8006
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 196 3501
Revision: 00H22000
VCID: 397EB5CB704A35F65A-806C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0020586
ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
ROD: EV_AudioVerst10KanalBNO1.rod
VCID: 2858608F53E0BC7E35-807C
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
VCID: 51AEED6B08FA9DB682-8004
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 01CE00003F000000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_SK46.rod
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: 8E0000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: 8E0000
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 155
Mileage: 13281 km
Time Indication: 0
Date: 2016.02.23
Time: 07:55:19
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 330F785A
VCID: 71EE4DEBA8BABDB6A2-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H08 0415
Coding: 010C00200001001000
VCID: 50A8E86F03F094BE8D-8004
Address 6D: Trunk Elect. (J605) Labels: 7N0-959-107.clb
Part No SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG-Modul H11 0250
Revision: 41011001 Serial number: 262400423
Coding: 082301C002
ASAM Dataset: EV_HDSGSk462 301136
ROD: EV_HDSGSk462_SK46.rod
VCID: 3B72AFC3B27607E648-806E
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H08 0415
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666667639
Coding: 0201000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D76A1DBAC6209D676-8068
You have a MK2 facelift but the guide you're following is for a MK3.
The MK3 has very different controllers as it's MQB platform rather than PQ35 platform. I'm not sure if it's possible to adjust the throttle response on a MK2 FL.
Also, your VCDS software is out of date. Current version is 16.8.0: http://www.ross-tech.com/vcds/download/current.php
You can fit a pedalbox, this adjusts the signal sent by the throttle pedal so the car won't know it's fitted. It'll just think you're pressing the throttle harder than you are.
Thanks langers2k,
I'll find the MK2 facelift forum to find what options I can apply and I'll update my software.
I was hoping not to have to add a pedalbox device but from what you advise it maybe the only option I have.... is there a preferred pedal box I should be looking at??
I have now got the latest VCDS software and it appears the option is to adjust throttle response is not available...what a bummer!
Do you think this option would become available any time soon???
Sorry for digging up a slightly old thread. I came across this mod yesterday and had a look at it on my car (2012 CR170). The coding bit (0-2) is there for it in the long coding helper but it's set to 00 (not specified) and there are no options to adjust it in the drop down menu.
I pondered setting the value manually but I've no idea what might be implemented behind it in the ECU: it might work, it might not, or it might break something. The latter possibility is what puts me off trying.
Anyone familiar with how this might be implemented in the ECU on the Superb II?
