Remap issue?
Maybe I should start a new thread to enlighten us all on how they are faring. Probably get a lot more responses from, dare I say it, a golf mk6 forum though just because of the population of cars....
  • Replies 77
  • Views 7.9k
  • It is hard going when fobbed off. Maybe they would of responded differently if you said you're brining it back in for a refund and remove map...unless they wanted to help.   If £200 is all i
  • john999boy
    john999boy
    I'd have thought that the first thing to do would be to take it back and let them scan for fault codes - then take it from there.
  • I don't think you really can practically speaking, if you don't want to pay for replacements, then you just have to see how it goes. A problem will be obvious if annoying!
I guess this would be very good to keep it on eyes. To 2.0TSI I do not have detailed info, but according file atached with printscreens from ETKA, updates March 2017, you will see what "Deutsch Ordnung" they have at ETKA ... Data for 2011 Skoda Octavia, Passat CC and Audi A3, focused on CCZA engines.
What is obvious, during May/June 2011 they changed from pistons with 21mm pin to pistons with 23mm pin. What are the actual pistons+rings fitted before that time is an Enigma as all parts mentioned at ETKA are still available. When you compare that with 1.8 CDAA and the problematic pistons 06H107065BS, those are dropped without direct replacements, just other parts can be used as solution ...
Look at piston rings too, each brand recommends for CCZA something different.
As I mentioned, TPI surely describes not the first modification. Currently have no other for CCZA. Just as info to compare with, 1.8 CDAA had at least three pistons/rings design (suffixes BS, CP, DF) and yet the latest one came in 2015 after EOP (suffix DL) ...
What I know I would not want to be one of the technicians at VAG these days :cool: ... If you have someone at VAG with access to ETKA, ask him/her to look at it for you accross VAG brands. Same engine code must have same internal parts at any brand ...
CCZA.pdf
CCZA .docx
Edited by rayx
Thanks for looking. Seems very messy and inconsistent.....:)
