rocker cover gasket - fabia sdi 2003
  • Sponsor
2 minutes ago, richardwalker said:
Could the way I blocked the EGR, simply by blocking the hose that goes from the Exhaust gas recirculation valve -N18-  to the Mechanical exhaust gas recirculation valve, cause any untoward problems?
I think not. The hose is effectively blocked when there's an EGR valve diaphragm on the end of it, so as long as what you've changed hasn't resulted in air being able to get into the N18 valve that way, it shouldn't have any effect on the vacuum system.
  • Replies 52
  • Views 6.4k
  • You should check that you have a good vacuum between the pump and the servo, a hard brake pedal suggests an air leak somewhere. Remember that the vacuum pump does not need an air supply since it is ev
  • See if gaffer tape improves matters? Get a photo of the splittiness first though.  They're often split worse on the underside, where it's harder to see, but phone cameras come into their own.
  • @richardwalker - Well, the 1.9 SDi and 1.9 TDi all use the same rocker cover, which is also in Audis, Seats and VWs.
I simply blocked it off with a pencil that has a eraser on the end :)
It seemed to work OK, it is only with these recent problems, I am starting to think it could have been the cause, but I don't think it could cause any air to go into the N18 valve.
Edited by richardwalker
Update - The brakes are now working fine. The hose from the airbox to the N18 valve (the one that was supposed to be repaired) was still blocked. After replacing that piece of hose, the brakes are now working fine. I have also had no more leaks from the valve cover, so everything is good. :)
Thanks for the advice - You are all legends.
