Amundsen MIB2 Firmware Update
On 10/08/2020 at 16:22, pab567 said:
@bladerara you have the latest SW
@asavvyman check you PM for latest SW. I don't know if your unit has been reworked and with what solution but basically for having AU maps on SD without changing folder name you must recode byte 03 in 5F from 01 to 08. If this doesn't work then additionally license for AU maps shoudl be installed.
To have the colour folders instead of the monochrome carousel is not a piece of cake - it requires hacking of SW download and then updating with hacked 04xx SW.
pab567 You're a champion! Thankyou for your generosity and sharing not only updates but knowledge... I'd love to learn what you know.
  • Replies 4.6k
  • Views 767.2k
Bonjour,
@ pab567, pourriez-vous m'envoyer le lien pour une mise à jour du système de mon O3 FL RS 230?
Je vous remercie chaudement.
Edited by Adam642
Please only use English. :thumbup:
Sorry!
""Hello,
@pab567 could you send me the link for a system update of my O3 FL RS 230?
Thank you warmly"
Hi @pab567 Can you please check and see if I need a firmware update.
PM
Edited by pab567
Is this for me?
Yes, you got the link on PM.
Hello,
When I try to update, my SD card and USB stick do not work.
I unzipped the file to the root of the USB drive.
Then on the vehicle I go to the information and I try an update.
He searches and then tells me that there is no source.
However, when I insert my SD or my USB, a message appears.
Can you help me?
Can I pleas software update. I have H30 0351
3 hours ago, Adam642 said:
Hello,
Can you help me?
Please push the Menu button twice and use this secret menu to update from the SD card.
Is there an update for this version?
Il y a 2 heures, gerstemann a déclaré:
Veuillez appuyer deux fois sur le bouton Menu et utiliser ce menu secret pour mettre à jour à partir de la carte SD.
Merci beaucoup!
C'est bon.
However, I had to keep my finger pressed on the "Menu" button.
Edited by Adam642
Hello,
is there an update for my system?
thanks for your help
All check your PM
2 minutes ago, pab567 said:
All check your PM
thanks for your fast support
Anybody who can help me with an update?
Last is 0252.
Hello, can you guys help me if there is a newer firmware for this device and if there is than does that firmware contain the hungarian voice for the navi?
Thank you in advance for your help.
Hello,
Please provide me, if available, the new firmware versions for the device in the photo.
Thank you very much in advance.
Good day @pab567,
driving Seat Leon 5F MY2020, can you send me a firmware update, please?
also do I need to do something specific if it’s for a Seat? Thanks!
On 21/08/2020 at 08:27, markus1986 said:
Hello,
You might want to update your maps - they are from 2015/2016 - we are now on 2020/21 maps!!!!
http://updateportal.skoda-auto.com/
is your place to download the latest maps from
hi, i have a skoda rapid spaceback 2014 model I hope to find a firmware update this way, not so much for my navigation. I am having problems with the bluetooth pairing unfortunately.
PARTNR: 5JA035192L
VERSION: 0410
System hardware version: H76
Navigation part no: 3AA919866
Navigation info version: vers: 0055
i would really appreciate if someone can help me :)
Hello everyone,
I would like to update my radio as well.
I hope this will solve my time problem, because it is always displayed wrong.
Thanks in advance
Ricky
On 21/08/2020 at 03:56, pab567 said:
All check your PM
Hello pab567. Thank you for you amazing help. Do you know if there is any update for my Bolero MIB2?
Thank you 🙏🏻
