Amundsen MIB2 Firmware Update
Hi @pab567
Do you have update for my car?
I see on Facebook group something like this, can you do this in my car?
  • Replies 4.6k
  • Views 768.2k
@pab567
Can you please help with a new firmware for my newly bought Octavia Combi from 2017, it would be much appreciated :-!
On 18/05/2021 at 12:28, Bazmanian said:
@pab567 please can you help advise if there is an update?
Also my DAB stopped working when I did the 0411 update but i use dab via my phone as it works better with waze :).
Skoda Octavia 2013
Nope, this is the latest firmware
On 22/05/2021 at 14:49, schnappata said:
Hi pab567,
you do a great work for Skoda community ... so I will benefit from it ;-)
My system:
Amundsen Gen2/MIB2 (Yeti 2016)
Part number: 5L0035680E
Hardware: H30
Software: 0353
Is there any new firmware available?
Is it possible to activate SmartLink and/or SmartGate?
Thanks a lot !!!!
On 22/05/2021 at 14:54, schnappata said:
... additional question:
normally MIB2 need an 16GB SD card for for navigation data, latest update (VW side) is V13 (2021).
now there are several offers to get a 32GB SD card with save or new (V14) card updates - do you know anythink about this topic?
Are these offers fakes or do Skoda offers now 32GB SD cards for Amundsen MIB2 for actual and future updates?
Thanks.
schnappata
There is no newer SW update available (although there were manufactured units with SW up to 0363).
You can have SmartLink activated by your Skoda dealer or the unit must be hacked.
Yes, I beleive from end of 2019 there are 32GB original navi SD cards available, e.g. 5L0051236BJ
All check your PMs
Is there an update for my system?
Hi @pab567,
Great to see you helping everyone here. I've been facing some Bluetooth issues in my Octavia. Request you to please check if there's a firmware update for the system. Attaching screenshots with the version details. I'm based in India.
Many thanks for your help!
Any new firmware for my unit?
11 hours ago, floydianik said:
Hi @pab567,
Nope, this is tle latest SW I know :(
Nope, this is the latest version
All others check you PMs
Hi @pab567
Any updates available for my version? Thank you
Thanks for the quick response pab567! In this case, do you have any suggestions on the error / issue I'm facing. The problem is that the while connecting my phone over bluetooth, the Amundsen system over a period loses the phone name (e.g. OnePlus 7) and starts showing some sort of a alphanumeric code for the phone name. Any ideas on how to solve for this?
1. reflash your unit with the same firmware, using Manual SWDL (select all to be updated)
2. try another phone
3. if problem still exists then it's probably faulty BT module inside the unit
As earlier, many thanks for the quick response and for the suggestion?  Any ideas where I can get access to the same latest firmware and also if there's a quick guide on the manual SWDL process. Thanks for all your help!
Download link sent via PM. Update procedure has been described multiple times, pls use search.
Hi can someone tell me if there is a new software version for my superb 3
Hi @pab567 is there an update for this please? PS - do you know if the VW satnav map updates work on this (if I can find them) seems ages since Skoda portal was updated
Links on PM. You can use VW map update use Bettle then Discover Media
Cheers @pab567- much appreciated
Is the process for putting the VW maps on the same as the process for Skoda ones - extract files, backup old files on map sd card to pc, delete old files on map sd card, copy new files to map sd card?
Edited by whooshvrs
hello, is any reason to update this radio?
Hello. are there any updates for my device?
Yes. Please tag @pab567
who will be hopefully be able to help
To confirm - yes it is, though for the v13 maps the big one will go on a 16Gb formatted with a 4096 sector size, to get the v14 on you need to delete other languages
Hey Guys!
So, I have a fetish for the "easy entry" feature (The one that slides the chair backwards when you unlock zhe car!)
The option has been coded and should work but it does not, nor does the "easy entry" option show up in the display.
I suspect this is because I may be running old software?
@pab567 Pretty please help!
PM
