Amundsen MIB2 Firmware Update
2 hours ago, gerstemann said:
Why is none of them working? How do you try to update your MIB? Did you try to use the Update button on the screen shown or did you use the update function shown when you push the menu button for 10 seconds?
If I check the Skoda update site, there are no updates for my car available, which is strange because my car is not updated in the last 5 year, so at least there should be something. From another forum I understood that the firmware from Volkswagen and Seat are the same as Skoda, but you have to know which cars have the same media/navigation systems. The Volkswagen Golf, until 2015 seems to have the same system as my Skoda Rapid (NH), but that firmware does not work.
How I tried to update my system:
- Clear original sd-card (after making a backup
- Extract downloaded firmware on the sd-card
- Insert locked sd-card into the car and see what happened
So far system only complained about wrong data (can't remember the exact message).
  • Replies 4.7k
  • Views 907.1k
The Skoda update site doesn't offer firmware updates, only map updates!
Best way to get a firmware update (if one is available) is to contact @pab567
On 03/06/2022 at 17:36, luftwaffle said:
@pab567, i have been looking everywhere for a patch to activate android auto and carplay as well as the other SWaP features in my firmware, do you have a patched update compatible with my US firmware MHI2_US_AUG11_S0533? Also, do you know where I can find a maps update for the US?
Unfortunately I cannot help you 😞
On 04/06/2022 at 20:25, StariBluzer said:
I have a problem.
I used new USB stick, formated it in FAT 32, extracted 7z file on it a plugged it into USB port in Superb.
And this error came up...
Please advise
1. Use SD, not pendrive
2. Start update from SERVICE menu, not from SETUP / SYSTEM INFORMATION
@Tom360V you have download link on PM
On 02/06/2022 at 17:17, pab567 said:
Need part number and current CW version
ok
this?
Yes - I will send you in the evening.
thaks
Thanks for your answer, I thought both where the same as in if you update your firmware you also get new maps.
Actually I'm looking for new maps for my amundsen system, do I have to update my firmware to use the latest maps?
@pab567 Thanks a lot!
Will try, thanks again!!
@warlock87 check your PM for download link
On 14/01/2021 at 07:59, pab567 said:
Ciao Pab, per la mia versione si può fare qualche cosa?
Hello @pab567
Would you be able to provide a software update for the following? Many thanks.
@Idol pls check your PM
Hello Pab567,
My Skoda has firmware 0472 running is there a new firmware?
I have problems with android auto, always getting communicaton error 8.
Did everything, checking time, play services update, AA update, etc
Hope the problem is solved with a new firmware.
Thanks for your answer!
Hi Pab,
can you send me the latest for mine please?
Hello
can
MST2_EU_SK_ZR_PD241T
0241
5Q0035874A
M25.14.35_STD2Nav_EU
be updated
Many Thanks
Dave
HI @pab567. Sorry to bother you also. I am trying for more than a week to update my system and maps also but it does not work out for me. Can you please take a look at my configuration and let me know if you have any working firmware update and maps ECE A1 2023. Thank you in advance.1655581538501-800.thumb.jpg.4f098e8e79233a3b99fd746151f90cf9.jpg1655581538486-800.thumb.jpg.ba37d4f866e8c0a086d97b360a806937.jpg1655581538514-800.thumb.jpg.4682879d8ad4fbcc2e9fd6e79fdf9600.jpg
You do it from th ewrong menu - it should be service menu (long press menu item).
All check your PMs
Thanks for the fast respond @pab567.I didn't check that way. Can you please send me also the correct firmware and maps update if you have. I will be very grateful.
12 minutes ago, pab567 said:
@Baltazar you have download link on PM. For maps pls visit Skoda Update Portal
Thanks @pab567. I appreciate your help.
It start good but end up not so good. Can you please help me with the errors and the modules that were not installed. It is good that it is still working but the update was not completed. Or maybe I reinstall the version MST2_EU_SK_ZR_P0245T if you have it. Any help is welcome.
1655664312841-800.thumb.jpg.4933ffa0eb90010aafbeac6f114b25d0.jpg1655664312827-800.thumb.jpg.2b35cafe409545d1c212cbddb3fdcbc8.jpg1655664312812-800.thumb.jpg.f5b357cca52cdf92ac426cf0a14f34da.jpg
