Amundsen MIB2 Firmware Update
For Amundsen MIB2:  MST2_EU_SK_ZR_P0456T   with SW version: 0456 what is the latest version of firmware? Thanks!
  • Replies 4.7k
  • Views 906.4k
MST2_EU_SK_ZR_P0480T
Thank you! Any idea from where I can download? :D
PM in next few minutes is where 👌
Is there an update for the MIB2 Amundsen in my new to me Octavia?
0253, so yes indeed.
 i have some times problem with full link.
MST2_EU_SE_ZR_P0368T my firmware.
Do you have update for this.
MST2_EU_SK_ZR_P0368T my firmware.
Current update is MST2_EU_SK_ZR_P0369T
You may wish to edit the link out of your post (private information?)
If you need update, I can send in a few hours, or someone may send.
Sorry sen a wrong firmware i have a Seat with next firmware MST2 EU SE ZR P0368T.
if you have you may send me private messages
thanks
thanks
Good idea, let me check in Seat collection.
MST2_EU_SE_ZR_P0369T available and being packed for transport.
Edited by varooom
thanks i will try it
Hi @pab567. I was not playing a lot with the media in my car, but recently I have found out that the loudness of the rear tweeters is very low. Even if I adjust it max high. The front is loud, but the rear are like there are not even there. There is a very small difference from high to low, but not even close as the front tweeters. There are speakers you can hear it if you put your ear close. I updated the version of the media that you send me the link. From MST2_EU_SK_ZR_P0245T to MST2_EU_SK_ZR_P0253T. Maybe the new version has this issue? I am not sure if it was like this before the update. Didn't test it. Thanks in advance.
@Baltazar This sounds more like a hardware issue, internal amplifier dying or a crossover in rear speakers (if that is what the frequency splitter is called)
i need an Update for the Firmwareversion MST2_EU_SK_ZR_P0245T.
Thanks in advance
34 minutes ago, Houdini said:
I need an Update for the Firmwareversion MST2_EU_SK_ZR_P0245T.
Thanks in advance
I will PM you MST2_EU_SK_ZR_P0253T in next few minutes
Thanks for the tip. I thought as well that the crossovers are the issue or the rear tweeters are not playing so high like the front. But still you hear difference from min to max on the rear tweeters but not like on the front. Front are really noticeable. Since the preamplifying is controlled with software digital to analog i guested that the software is responsible for that. Maybe if i install the previous version i can debug the issue. Eliminate the software as an issue perhaps and looking for the hardware issue.
4 hours ago, Houdini said:
Thanks in advance
Hi @Houdini Can i ask you to test one issue that i have before you do an update on the unit. Are the rear tweeters loud like the front? If you adjust to max you hear them loud like the front or not so? Thanks in advance
I have 0253 on mine and it's fine.
I can move sound to any of the 4 speaker's in isolation, and each has equal loudness.
Bass and treble are all correct.
Thanks for the fast feedback.
@Baltazar pls x-check with other car as rear speakers in these units work as background only, the difference between front and rear is typical and nothing you should usually worry about.
Hello,
I have a 5Q0035874B  with software MST2_EU_SK_ZR_P0361T - is there a newer version?
47 minutes ago, der2of6 said:
Hello,
Yes there is MST2_EU_SK_ZR_P0369T
Thanks - do you have a link?
Allow 5 minutes or so, I will send you PM
A little help with my unit too, please.
I would like to update my unit and then patch it for smart link. (Couldn't get an offer via email form 3 dealers for activating smarrlink).
And do you think doing an update would i benefit from wireless Android car?
Thank you!
